1961Mike
Everything posted by 1961Mike
Will Ghormley pattern pack
1961Mike replied to JDG's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Hi I think its ok to assume that Will is still in business since his website is being updated. I have used one of his pattern packs and it worked great with the exception that I used leather that wasn't thick enough to be stiff. Working on Hand of God now. Later -
Brown dye from household materials
1961Mike replied to Nowandagain's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Hi Did the original poster ever try vinegaroon a second time? I've made at least 2 and I think 3 batches. They all worked great. I took a break from leatherwork this year for various reasons. I use the following procedure to use Vinegaroon: 1. Tool the belt and let it dry fully, or at least draw the guide lines and tool the belt after dying. 2. Put the belt in the Black Tea Tannin Solution for 2 minutes. 3. Put the belt in the Vinegaroon for 6 minutes. 4. Put the belt in the Baking Soda solution until it quits bubbling. This shows that the vinegar has been neutralized. 6 minutes also works well. 5. Rinse with Cold water. 6. Let the belt dry flat, this takes at least 3 days. 7. Coat the front and back of the belt with Extra Virgin Olive Oil (from Extra Ugly Olives) or Neatsfoot Oil, and let dry. 8. Put on a second coat of EVOO and let dry. 9. Use a couple of coats of Tankote (shiny) or Bagkote (less shiny) on the fur side of the leather. 10. Use multiple coats of Gum Tragacanth on the flesh side of the leather, smooth it with a glass deal and let try. 11. To get Really Shiny finish on the fur side of the leather, use Gum Tragacanth on that side too. Let it get mostly dry and them buff it out. 12. Mix Resolene half and half with distilled water and put on several coats. -
Dye woes
1961Mike replied to Yellowhousejake's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Hi, for the color you showed above, the easiest way to get that saddle tan color is to carve the leather, but don't glue it up or sew it. Put a couple of coats of EVOO (extra virgin olive oil) on the holster and put in your dashboard in the sun. When it's dark enough, finish with Tan or Bag kote and then Resolene. Later -
Hi I've HEARD of this being done, but haven't needed to try it yet. You can glue and / or sew a strip of leather, roughly the height of the sight, for the sight to ride up and down the holster when drawing and re-holstering. One strip on each side of the barrel. again, HEARD of it. it would be worth a try though, use scrap leather for the first try. Later
Olive Oil is what the Cowboy Action leather workers recommend. The leather will almost always turn grey when you dye it, let the leather dry all of the way before you put the olive oil on it. I use the following procedure for making black belts and probably holsters: 1. Tool the belt and let it dry fully, or at least draw the guide lines and tool the belt after dying. 2. Put the belt in the Black Tea Tannin Solution for 2 minutes. 3. Put the belt in the Vinegaroon for 6 minutes. 4. Put the belt in the Baking Soda solution until it quits bubbling. This shows that the vinegar has been neutralized. 6 minutes also works well. 5. Rinse with Cold water. 6. Let the belt dry flat, this takes at least 3 days. 7. Coat the front and back of the belt with Extra Virgin Olive Oil (from Extra Ugly Olives) or Neatsfoot Oil, and let dry. 8. Put on a second coat of EVOO and let dry. 9. Use a couple of coats of Tankote (shiny) or Bagkote (less shiny) on the fur side of the leather. 10. Use multiple coats of Gum Tragacanth on the flesh side of the leather, smooth it with a glass deal and let try. 11. To get Really Shiny finish on the fur side of the leather, use Gum Tragacanth on that side too. Let it get mostly dry and them buff it out. 12. Mix Resolene half and half with distilled water and put on several coats.
Hi Actually I have or at least HAD a Maroon Permanent marker. I was BORED Xmas of 2023 and stenciled cheapo canvas bags for reusable grocery bags. Later -
Hi I have a quart of beet juice to try and make a dye from. it MIGHT make Burgundy, I mean its sort of a dark purple in the jug. Later -
Seeking Input on Sheath Design
1961Mike replied to rktaylor's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Hi, PERSONALLY I agree with DieselTech's first comment and you covered that. Whether or not that's ENOUGH coverage for everybody, or TOO MUCH coverage for someone else is a whole new ball game. Hope y'all had a great Christmas. -
Hi, your leather carving skills are great. On the other hand, I think you'd find more sales providing another venue for your artwork. I'm not in leatherwork sales, but even a leather butt pad would have to go $30 US. I'm not sure how many shooters would bother paying that for a 1/8 inch rise is stock height and art. Another addition to the butt pad could be to fill in the crescent shaped metal (brass or steel) butt plate. Americans are larger now than in 1873. You might get more sales with something that is more useful to shooters. NCOWS shooters that are in the working cowboy (1 pistol and 1 rifle) have to carry their equipment including ammo, cleaning equipment, etc without a cart like SASS uses. The saddle bags would have two flaps that could be decorated as well as the connection between the two bags. Just thinking out loud.
Hi So, my latest batch of Pecan Hull Brown Dye, was less that brown. In fact, the color that came out after more than 10 hours was a light tan. The leather got MUCH darker with a coat of Neets foot oil and a day on the dashboard in the sun dammit. My new plans include a new batch of Pecan dye and a seven minute soak in strong coffee instead of a 2 to 7 hour soak in strong coffee. What I got after 2 hours was dark dark (add more darks) brown chip of some sort. EVOO did NOTHING to it. Later -
Hi The belt looks great. I've been to see wrestling at Kiel Opera House in StL back in the late 1960's or early 1970's. I think the Von Eric brothers were there, but I don't know which ones. If you go see wrestling live, don't get in the front rows. The audience is MUCH more entertaining than the wrestlers. I was no older than a Freshman in High school, but we could smell weed. We finally worked out who it was, a 60 plus year old lady in tight polyester pants and a gray bee hive hairdo with a long cigarette holder. Yes, this was when you could smoke ANYWHERE in public. There were at least 5 to 7 matches, an older guy (now my age) was yelling "we wanna see some blood, we don't wanna watch you make love." He was hoarse by the 4th match. Later
Hi, I live in Oklahoma, and there is a pecan orchard a few miles from home. I purchased a 25 or 50 pound bag of Pecan Hulls, a lingerie bag to boil them in, and now I have a dark brown dye. Walnut hulls also work very well. If you want DARK brown, almost black leather, use dark roast coffee that's been reduced by about half. It is HELPFUL to make some trial leather pieces to see how long to soak the leather in the dye. Later -
Holster Carved briar brown
1961Mike replied to Bawarrior's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Hi, I agree, that whole setup looks beautiful. I'm trying to learn how to carve like that. I'm better at straight lines and stamping the same border that you used. I've done enough of them, that I broke the Tandy version of the double meander that I had. Now I use Barry King's stamps. For anybody who wears something like that, are the lifted edges on the leaves and flowers a problem? Do they catch dirt, tear off etc? Thanks -
Confederate Waist Belt
1961Mike replied to BridleButt's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Dang it, I'm having too much fun trying to attach the Civil War version. Later -
Local (Oklahoma City) Tandy Leather Store
1961Mike replied to Brokenolmarine's topic in Leatherwork Conversation
Hi If the lady in the original post was gray haired, that was Barb. I took an introductory class that she taught. She's very good and knows what to get and what not to. Later -
Dang, please post front and back pictures when you attach the adjustable part of the buckle. At least that looks like the Civil War version as opposed to the modern version. I have various kinds of ways to attach the belt on the back of the cartridges, but I used leather that was too thick on the first one I'm working on. Blockade Runner has a lot of that sort of thing. Hi JW, Hanover Brass is where he got that one, Parsley Brass is also good. I usually by Tim Parsley's stuff. Later -
Hi I trial and error the distance between the two lines of stamping on the cut off end of a belt. When I get a spacing I want, I make the lines and start stamping. I find it helpful to start on the inside of the project instead of the outside. Later
Hi Realizing that I'm being Doktor Fronkenstine and resurrecting the dead, but how do the Brass and steel stamps last? I broke two Tandy Meander stamps, at $7 a piece and Barry's stamps are a lot more, but have already lasted longer. His are all steel. Later
Tried An Avenger Style For My Revolver
1961Mike replied to AzShooter's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Hi, you know, if you going to put the "swell" behind the trigger guard, you might as well use the extra space to put more slot area for the belt. Later -
Mexican loop question
1961Mike replied to dikman's topic in Gun Holsters, Rifle Slings and Knife Sheathes
HI Thanks everyone. I was looking for the whole how to make this work next time. I already have some Hermann Oak 9 ounce shoulder leather to use on the next ones. I also have a Slim Jim about half done that will be lined and had a loop that is tight on the cartridge belt. I may try the Concho and strap idea just so I know how to do it. CASCity mentioned using a Chicago Screw to attach the holster to the skirt. The holster pattern doesn't lend itself to bumping out the holster like in a Mexican loop setup unfortunately. Thanks -
Hi Dwight, this is more or less what Will Ghormley calls the Lawdog holster. I made one for practice out of crappy 6-7 ounce leather. I finished it with Neatsfoot oil and Skidmores after letting it get a tan in the sun for a couple of days. The holster practically jumps out of the strap when I draw it. How do you avoid that on this style holster? If I used Vinegaroon would the extra stiffness make it stay in place? Thanks -
Hi That looks a lot better than my first holster. What color of thread did you start with? I ask because it appears to have taken some dye. If you dye the leather first, the thread stands out more. You can still do the edging last and put more dye on the edges and finish. With your application, I'd have used a matching thread anyway. The white thread would have stood out too much for Alaska. Later
