Everything posted by Hockeymender
Thanks for the info. So it sounds like TriFlow is not something that would be ideal for just basic machine lubrication. My machines operate at a very slow speed, so I'm just curious how often would the TriFlow need to be applied to maintain the proper level of lubrication? I guess my main interest is would using TriFlow in a slow speed machine extend it's life as opposed to using standard sewing machine oil?
Seeing that TriFlow has been brought up in another thread as a lubricant for sewing machines, I'm just wondering how well it fairs in doing that task? If those that have experience could comment on how it compares to the clear or "white" oil many of us use. Having done a little research on the subject, I mixed a little STP in with my sewing machine oil and that has produced some very good results. Having never considered TriFlow as a lubricant, hope those that use it can enlighten.
Hey Harry, I have watched quite a few of your vids on YouTube.....good stuff.
- 5 replies
- juki 1541
- name that part
(and 1 more)
Need Imput On The Consew 227R-2 !
Hockeymender replied to onathread's topic in Leather Sewing Machines
I concur with what Tramp said, I use this machine almost daily sewing some rather heavy stuff. It takes all I give it and keeps coming back for more. Very durable and easy to service. One of the better machine purchases I've made. -
Eric, Thanks so much for taking the time to post a "step by step" narrative of your dealings with this machine. I am always learning something. I would really like to see your shop at the factory, that I'm sure is a very interesting place. Again, thanks for sharing your expertise with us!
Sold
Which Sewing Machine Is Best For Making Purses
Hockeymender replied to Mariel's topic in Leather Sewing Machines
http://leatherworker.net/forum/index.php?showtopic=61804 This is the type of machine that would be best overall to make purses with. -
For a start, I would check the tension on both the upper and lower threads. Then I would look at the hook timing. I've had issues like that before, and it was usually a tension problem but as stated the jam could have pulled the hook out of time.
Bump
Used one for many years, great machine. I always try to buy the biggest machine my budget will allow. That gives room to expand what you can do. If you don't grab it, there are several here ( me included ) that would love to have a shot at it.
Omac 69-373 E.o.s. Sewing Machine
Hockeymender replied to MavericKLeathers's topic in Leather Sewing Machines
Direct copy of the Adler 69-373 right down to the color. Can't speak for the quality of the "Omac" brand, but the genuine Adler 69 is a great machine having used one for many years.- 2 replies
- sewing machine
- italian
(and 1 more)
Eric, Thanks for the insight you bring to this forum. Been at this for over 20 years (and am by no means any kind of expert) but I find I learn something from most of your posts. Had never given a thought to the hardened screw issue, now I will. Thanks again for sharing your knowledge.
Now that's a real beauty!! Wonder how old??
If you still need this manual, send me a PM. I can get a PDF version to you.
Selling this Pfaff 335 machine. It is complete with table, thread stand and servo motor. $1700.00 OBO. Prefer local pickup. Located in the metro Detroit area. PM with questions.
Wonderful, wonderful!
Toledo industrial sewing machine sells the flatbed attachment for the CB 4500. I have one and it's great, two machines in one. I believe the flatbed setup is less than $100, but double check that figure.
Mine sits most of the time. However, that said there are certain projects that come thru the door that I would have to refuse if I didn't have a patcher. I think I a lot of cases it's a niche machine, you need it when you need it. I agree that I would not drop a large sum of cash on one, unless the work your doing falls into one of those niches that only a patcher can fill.
In my experience the best thing you can do is, if possible, go to where the different machines are and sew on them. Take some of the material and thread that you will be using and put them thru their paces. This will allow you to decide which machine will be the best choice for you and your work. I have reached a point where (with very few exceptions) I won't buy a machine I can't sew on first.
How Do We Like Sewline Sewing Machines?
Hockeymender replied to The Mean Tambourine's topic in Leather Sewing Machines
The service and expertise you would gain for the extra $ by purchasing a Cowboy from Toledo sewing is well worth it. The guys there set my machine up for exactly what I was going to be doing with it. The time saved right there is worth the extra IMHO. Also, Bob and Bobby are always there to help if needed down the road. Just my 2cents.- 17 replies
- sewline
- cylinder machine
- (and 3 more)
Need A Little Help With My Pfaff 335
Hockeymender replied to Gabriel Babin's topic in Leather Sewing Machines
There sould be two screws that attach the hook to the shaft. Remove those and work the hook off the shaft. You may need to do a little gentle prying, as the hook can get somewhat stuck to the shaft. On mine, I turned the shaft and gently worked the hook from the end of the shaft. That should give you the required clearance to remove/replace the needle bar. -
Sold.
I think, given enough time Adler will rethink this decision. The only market they can really appeal to will be the very large companies and corporations that have deep pockets. That said, there is an excellent chance they won't sell enough there to make it worth the effort to produce these high dollar machines. If, as Glenn pointed out, the 205 is dropped that market (the smaller leatherworkers and other trades that require this type of machine) will belong entirely to the clones. Should Adler decide to bring back the 205, it will be very difficult for them to regain that market share, without dropping prices to be in line with what the clones are selling for. Just my 2 cents.
$1000.00 OBO
