YinTx
Everything posted by YinTx
  1. Having never made a heat shield for a motorcycle, you can take my experience with a grain of salt. I usually cut, (tool if you are going to), dye, oil/nourish leather, resist and antique if tooled, seal (satin sheen, resolene, acrylic, whatever your preference), glue, edge, stitch, retouch edges and finish if needed. there is flexibility in the order in which you do things, so experiment and get experienced! YinTx
  2. Also the Design Artistry. YinTx
  3. Interested in Upholstery Techniques. PM sent. YinTx
  4. All good points, but sometimes I prefer knowledge. Consider living vicariously through other's experiences. Example: One can see others getting STD's and pregnancies and addictions, and avoid having to gain that experience directly simply by knowledge. I for one would not like to have to learn how to avoid such things only by experience, knowledge is sufficient for me, thank you. Single experiences can be detrimental or have long term consequences. When it comes to leather, it helps me to have knowledge before trying to gain experience. If I just picked up some tools and some leather and tried to do Sheridan work, I'd fail miserably and probably never pick it up again. Reading, watching others, gaining knowledge on how it is done (wait... you wet the leather? all this time I thought you were trying to keep water away from leather!) prior to gaining any experience was vital to any chance at a successful outcome. Improvement however required experience. And feedback, with more experience. Add to that additional knowledge watching others share good and bad experiences (gaining knowledge vicariously again) allows even more improvements. At a certain point, gaining additional knowledge provides little incremental gains. It's time to go into production! Just $0.02, thanks for letting me philosophize for a bit on a Friday afternoon! YinTx
  5. Dave, Thanks! I have about a dozen wallets that don't look nearly so good leading up to this....so I have a lot to choose from for my daily carry. Just pull one from the scrap bin! Thank you! Appreciate it. The belt was 8 SPI, the wallet was 9spi, both with 25/3 linen. Stitch up a couple of practice bits, then go to town on it! Your stitching seems decent enough to give it a go. I let things intimidate me as well, it slows me down a lot when it probably shouldn't. I have some things to make from Barenia, took me almost 2 weeks to get the courage to cut out a couple of bits yesterday. And if you want any advice on a buckle, don't bother with nickel plated anything. I made a lot of belts from some $8 Tandy nickel plated buckles, only to have the plating wear off in less than a year. Got to redo some belts for folks for free thanks to that. Now I only use solid stainless steel like this one, or solid brass, and the jury is still out on the solid brass finish. Sad when the buckle doesn't make it a year. YinTx
  6. Almost matching, but for different recipients. Both hand stitched with linen thread, both dyed black. Belt from Wickett and Craig 9 oz with 2 oz liner, Wallet from dry milled veg tanned Hermann Oak outer and Hermann Oak veg inner. Double cash slot, hidden pockets. YinTx
  7. I like it. This is a style I'd like to try sometime! YinTx
  8. I have the exact same model, and have been reasonably happy with it. Let us know how it does after you have polished and sharpened it up, I'd like to know if the issues I struggle with are operator errors, or something I need to alter on the tool! YinTx
  9. I can see it now. Looks great the way you did it. YinTx
  10. Those edges, tho! Nice! Fantastic color too! Stitching looks pretty spot on also. thanks for sharing! YinTx
  11. I like the texture on the leather. Also, how does that closure work? Seems like everything would be too stiff to pull the "tongue" out of the loop? or maybe the loop pulls out to allow the tongue to be freed? Well made, regardless! YinTx
  12. FYI, I've tried it with straight TanKote, no luck. Got all smeary and streaky and knarly and such. Your best bet is to tool a bunch of scrap pieces and try a dozen different ways until one of them or none of them work for you. There are those who refuse to antique, and some days I am one of them. YinTx
  13. Astute, to be sure. I missed that part. I've had decent luck with 2 coats 50/50 TanKote then the gel antique from Tandy. I only have one bottle of the Mahogany. Also seemed to do ok with the Pro Resist, but I had to be very careful not to let the pro resist get where I wanted the antique to be, which is a challenge on basketweave. This is what I did on the basket weave section of the rifle sling I made, if I recall correctly. The rest was 50/50 TanKote, so you can see the difference in penetration. No TanKote, and the leather turns almost black with that antique. YinTx
  14. Really neat, thanks for sharing! Did you do the tiny tooling on the strap you were wearing? For the brief moment it flashed across the video, it looked good! I have been doing some tiny tooling, but haven't been too happy with it yet. Would love to see someone doing tiny tooling to maybe see what I could change up to improve mine. YinTx
  15. I am confused: I thought the OP was using Fiebing's paste antique? I never had any luck with the Resolene approach either. Tried Bee RTC, it was better but still I wasn't happy. In fact I have probably tried more than a dozen different combinations of resists, number of coats, reduced resists, different brands/types of antiques, highlighters, etc. In fact yesterday for the first time I tried Fiebing's highlighter, over TanKote with so so results. Sad thing is I've done so many different versions I don't remember which one looked the best! I have however had some luck applying Tan Kote 50/50 water with two coats (wait like 4 hours between coats) and do the antique the next day. I think this was Chief's technique. Still, I manage to screw that up on occasion as well. Tried the Fiebing's Pro Resist a few month's ago, it was like 100% resist, the antique all wiped off, like I hadn't even used any. No penetration at all, but also no antique in the tooled impressions or cut marks. YinTx
  16. YinTx
    A Collage
    Oh, ok. I thought maybe a coffin or something, and I was a bit confused... YinTx
  17. Good to hear, thanks, I'll relax a bit... YinTx
  18. YinTx
    A Collage
    Well done, and cool color combination. Any reasoning behind the overall shape? YinTx
  19. Have you had any issues with it? I had read in a previous thread that you shouldn't store in cardboard because the chemicals in the cardboard binders would leach into your veggie tan and wreak havoc... so I have been all paranoid because I have some of my leathers stored in cardboard boxes and been wondering if I really really need to get them outta there...? YinTx
  20. Thank you, not sure I entirely agree, I seem to have sneezed a half dozen times while doing the scroll, and I couldn't fit a pear shader or any of the modeling spoons I had into the flower, fates it appears yours did not suffer. Having tried, I can comfortably say yours came out pretty well! YinTx
  21. That. Makes it all worthwhile. Awesome for you! And awesome set as well. That is a ton of stamping! and a ton of sewing. I bet your hands were so tired it wasn't hard for that archer to pry it away, even if you did attempt to resist! YinTx
  22. Uhmm... okay. So I drew this up tonight, and tapped it out. Not the best thing I've ever tooled, but the only thing I've ever sketched free hand for tooling. So there's that. Also, now I know why I don't practice flowers on keychains: waaaay too small! Not really practice! Entirely different beastie. I keep getting more and more respect for those capable of tooling Sheridan on tiny stuff like swivel knife sheaths! Quarter for scale. I'll get it dried and antiqued over the next week or so, we'll see how it looks when its done. YinTx
  23. Now why did it never occur to me to practice floral on keychains?? Nice! YinTx
  24. Sometimes, you have to tool it on a larger piece of leather and cut it out of that when you are finished. This gives you a place to set the weight without getting in the way of your work. Also, not sure, but possible you have placed the beveler 90 degrees off when using it, resulting in the "chatter" marks. Thickest part of the stamp should be facing your carved line, thinnest part pointing away. Pretty impressive taking on such a detailed object as a first piece, I rather like it! YinTx
