Everything posted by Tugadude
I have the other iron from Tandy also, the 2mm in a 4 tooth and 2 tooth. They are very similar to the Craft Sha irons, I believe. I think they are pretty good, not as pretty as the one above, and chunkier, but I use them a lot. I will measure the SPI and let you know.
I bought the 10 tooth model #88055-10. Would have bought a two tooth to go with it, but they don't make one. I did a watch band recently and 9 SPI was the result. Here's a pic to show the marks. This is the smallest spacing and the teeth are very skinny. I used very fine thread in comparison to what I generally use. Results were decent though.
Where To Find Strong, Thin (About 1Mm?) Veg Tan Leather?
Tugadude replied to jeremyqmartin's topic in How Do I Do That?
Thanks for the heads-up! -
BTW, if in doubt, pick up the phone and call the folks down there. They are very friendly and helpful! -
They have this at Springfield Leather Co. Might work for you. What you are looking for is 2-3 oz. leather, closer to 2.5 oz. -
Welcome! Be sure to check out the "How do I do that" forum for tips. When you want feedback, post a project on the critique forum. We're gentle and very supportive!
Cue the music, there's gonna be a showdown at the O.K. corral!
Security Forces
Tugadude commented on LuckyRabbitsFootLeather's gallery image in Gallery- Our Leatherwork
I'll be interested in other opinions, but when leather is really thin and pliable, burnishing doesn't work. You need friction/heat and that is hard to generate when the edge is moving all over. If you want the best chance of success, a mechanical burnisher is worth a try. Lightly run the edge against the rotary tool and make sure the edge is moist first. If the leather is very thin, perhaps folding the edge over would be the best approach. This is commonly done on garment leathers which for obvious reasons don't lend themselves to burnishing.
Kidskin Wallet
Tugadude replied to rawcustom's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Nice! Good contrast in color going on there, while starkly different they go together nicely. -
Don't know if this muddies the water even more but Tandy has a conversion chart on their website where I found an old model 441, not preceded by a "D".
BTW, forgot to indicate that the verbiage above came from the Blanchard site. I'm taking no stance on whether there is a "need" for a left handed iron, just trying to be helpful!
Inverse irons (sometimes referred to as Portmanteau or reverse irons) have teeth running at the opposite angle to our regular irons. Normal Stitch Mark Direction: \ \ \ \ \ \ \ \ \ Reverse Stitch Mark Direction: / / / / / / / / / You'll need reverse irons when punching through several layers is impractical such as with really thick leather or several layers of leather. Punch holes on the top side of your first layer and then use the reverse iron to punch on the face of the bottom layer. As long as you take care to match up the holes and you'll have a clean bottom side of the stitching to match your clean top side stitching. Reverse irons can also be used for an aesthetically to have stitches from different directions angle towards a center point.
Walt and Linda Sippel are the proprietors. Maybe they are members here, or you could ask them through their website. It could be a Hackbarth, some of those were similar.
second tooled weekender bag
Tugadude commented on MonicaJacobson's gallery image in Gallery- Our Leatherwork
Couple of thoughts. First, your work is beautiful. Love the use of color, not too much, just right. I admire people that put their hearts into their work. You obviously have a passion for firefighting and your pride is reflected in your designs. I looked at your website, nice story there. Your prices are very reasonable, putting handcrafted gems into the hands of your bretheren. Good stuff!
Good looking strap there! What is the backing material, felt?
Introduction And A Question About A Little Tool Problem
Tugadude replied to BuckeyeGuy's topic in Member Gallery
They should just replace it for you. Good luck on your new hobby! P.S., if the blade came off because it is getting hung up in the leather, it needs to be sharpened most likely.
