dikman
Everything posted by dikman
  1. Considering you already have the servo it makes sense to use it. Plus it will be a better motor than the little one.
  2. This is the final version. The pedal is the usual arrangement, what I like about many of the servos is the control "box" is a separate unit so doesn't have to be mounted with the motor so is simply mounted underneath.
  3. Sounds like the little motor could be a no-go. This is what I meant by a top-mount servo.
  4. Yes, replacing the flywheel with a large pulley will help, but the best you might get is maybe 10:1 with a 10" pulley, which probably won't be enough based on what Wiz has said. Can you mount the servo on top of the table, behind the head unit? One or two have done that.
  5. No big deal, really. If they won't replace it then as Sark said squeezing it in a vice should straighten it. Might not come out perfect but it will still work. It's unlikely that the metal will be anything special, just ordinary steel.
  6. It's pretty obvious that a bigger motor (more hp) will draw more current, particularly when under load, and a brushless motor should be more efficient but if you're only a hobbyist then realistically neither of these will make much of a difference (particularly if you're using a speed reducer as well). It stands to reason, however, that if you can then always buy the bigger hp motor, as the price difference often isn't that great. I have both 550w and 750w motors and, coupled with speed reducers, I can't really tell any difference when using them.
  7. Wow! That is impressive. Very nice carving. And, as mike said, very clear photo.
  8. The Techsew and the Toledo appear to be the same motor. The downside, imo, to all of them is that you have to get underneath the table to adjust the speed. Of course this is only a problem if you're constantly varying the speed setting, I suspect many of us generally work out the optimum setting that suits our needs and leave it set at that. If you have to keep adjusting the settings then one with a knob speed control will be better. Needle synchroniser - if you intend sewing fast (or long runs) then it may be useful, if you're sewing leather at slow speed then it's not necessary as you will have sufficient control to stop where you want to. Be aware that many of them won't work if you're using a speed reducer as well. Getting a smaller 2" pulley with the motor is always a good idea as well. In short, any of those motors should work fine for your needs.
  9. No worries, Yin. The dark centre of the mass doesn't feel damp, but it's obvious that it can't be completely dry yet. It has formed a pretty solid lump, though, as it can be screwed along the rod without any of the discs coming loose. I'm going away for a couple of weeks so I'll let it stand, open at both ends.
  10. It has now been 16 days since I clamped the rawhide discs, and it looks and feels dry. I cast a brass disc and turned it down to fit on the end, threaded it and Loctite'd it to the end of the rod. To do this I had to remove the clamping piece and when I did it was obvious that it still hadn't dried in the centre!! I still had a tight mass, however, so I screwed it down the rod so it applied pressure to the brass while the Loctite dried. I removed the other clamping piece and I guess I'll just have to leave it open to dry off more. (Note to self, I think I'll stick to making them out of plastic milk jugs!!!!).
  11. The limiting factor is the type of material and the settings used to burn in. That logo I did was scanned from one on a police notebook. When I did a trial run on cardboard the detail was quite sharp, but burning onto leather lost a little bit (not much) detail, due, I guess , to the fibrous nature of leather. Burning a photo image onto leather it would certainly be recognisable but don't expect it to look like a photo.
  12. Yep, sounds like you definitely need another one! I'm not overly interested in making too much for sale, it's too much like work! The only reason I'd do any is that it's an excuse to make things.
  13. I'm not sure how you've reached this conclusion, given that it's unlikely very few have actually used such a system to comment on it. The good thing about a pedal/linkage system is that it's easy to adjust so that you can have either minimal travel or longer travel to actuate the motor (or engage the clutch in the case of clutch motors). I suspect that most are quite happy with this system. Personally, I can't see too many (if any) manufacturers being interested in designing/implementing such a system. Why would they want to?
  14. Scarve didn't work, but I don't like the simple interface anyway. Guess I'll just work with what I've got. The customer liked the folder so now wants me to make him one. This time I'll leave it as "natural" colour, neatsfoot oil should darken it just enough to give it that warm look and let the engraving stand out. This one should be quicker now that I know what I'm doing. He said others might want one too but I said any more will cost more than I'm charging him! This engraver might be "cheap" and have flaky software but I'm impressed with what it can do (it can also cut stencils out of card, so that's got me thinking).
  15. Are you sure that's been done with a twin needle machine? The two rows of holes don't line up that well.
  16. Thanks for that, turbo, very interesting to see how they're made. Wiz, I just had a look at her site - there's an awful lot of videos to watch!!!!!
  17. You probably won't need that many holes for the vacuum to hold it down, another way might be to use a thin cut-off wheel in the grinder and cut a series of thin slots instead of holes? It would be quicker and easier than drilling lots of holes and should work. Looks like Lightburn is a no-go, it can't recognize the device. I mentioned Scarve before but that looks like it's an even simpler bit of software than what I have! Guess I'll just have to stick with what I have, while it has its limitations it's not too bad - when it works.
  18. Thanks mate, I was about to make a similar comment about the detail in the emblem. There's NO way I would even attempt that if I didn't have the engraver. Likewise with the name etc, my stamps are all too big. While I like the idea of something being entirely handmade, realistically cost can sometimes become an issue. I have no qualms about using modern technology within reason, although I must admit I still like handstitched items compared to machine stitching. I've been looking at Lightburn, but I'm not sure it's designed to work with these little engravers as it requires specifying the hardware/firmware being used and I have no idea what this thing uses! I have found some software called Scarve so I'll try that.
  19. I honestly can't remember , but I've made a lot of assorted handles so probably did.
  20. My three awls. The one on the right I made (can't remember what I used for the pointy bit) the other two came with the heap of stuff recently given to me and are probably 40-50 years old. Like I said, an awl doesn't need to be fancy (unless you want it that way).
  21. Something I just tried. Our police carry an official notebook (for taking statements etc) and are supplied with a "folder" to hold it, which is your basic cheapy vinyl thing. When I had my recent firearm safe inspection the officer mentioned this and asked if I could make a leather folder for his notebook. When he came around to discuss it he asked if I could make one for a colleague who just got promoted and could I stamp her name on it? I said I could probably engrave it and to leave it with me. I thought I could do something a bit better in that case so did a bit of basic stamping and engraved the SA Police logo and her name, number, station and group (I blacked out her name and number). The engraving went well and I dyed it with Tan dye, in the photo it looks light but in reality it's quite dark and tends to make the engraving a bit hard to see but I thought it was more subtle that way. I machine stitched the edge in white but didn't really like it so removed the stitching and hand stitched it - looks much better. All this waffle is to say that the little laser let me do something that I couldn't have achieved otherwise.
  22. Guess we'll have to wait for the next installment.
  23. Thanks Brian, I'll have a read through there later. I did find an alternative bit of software but it wouldn't work with my engraver. I have a little project that I have to finish first (before Easter).
  24. What happens if you turn the shaft by hand?
