dikman
Everything posted by dikman
  1. Here's my effort. It's a Tevo Tarantula kit (which is why it doesn't look neat and tidy as it's very difficult to run all those cables in a tidy fashion!). There are many kits available and a lot of them use perspex/acrylic for the framing pieces (which apparently works quite well) but I bought the Tevo because it uses extruded aluminium section for its framing. Rigidity is the key to using 3D printers, so mine is screwed to a baseboard, which also lets me move it around, and I fitted additional diagonal braces at the rear from the top to the back of the board. It's now very rigid. I've done a few mods, all the power normally goes through the main board (in front) including the heated bed, so I attached a box to one of the diagonals to use as a power distribution and bought a MOSFET unit to feed the heated bed (it removes that heavy current drain away from the main board). The Z axis was fitted with a universal joint, rather than the springy thing that was supplied, and I printed a gimbal joint, this allows for any slight mis-alignment in the shaft and removes any possibility of Z banding. I have a kit on the way to fit a second Z drive unit on the other end as there is a very small amount of vertical play in the bar carrying the nozzle assembly so this will make sure it can't shift. I may make a decent housing one day for the control board on top, but it's not a priority as it works well as it is.
  2. If something like that came up near me at the very least I'd grab the servo.
  3. Rustic, could you post a link to this $50 binder? I'm very curious to see what you're talking about. Your suggestion that a heavy binder could be made for $50 made me laugh. Even if Amazon offered the Cowboy binder for sale I doubt it would be much, if any, cheaper. For that to happen it has to be mass produced, but the market simply isn't there as it's too specialised a piece of gear.
  4. I thought it might be an idea to have somewhere that those of us who own a 3D printer of some sort can show a photo or two of it and maybe brief details - make etc and anything relevant? One or two people have expressed an interest in them and it might be of some help to them. I'll post a photo of mine tomorrow, the bed is off at the moment while I make better adjusting nuts.
  5. That pile looks like something for a model railway. Thanks for providing the file, what is the nominal slot width in your version?
  6. You have two options if you want to make "Western" gear - hand stitching or a heavy duty machine. The most common machine used is a 441-class, e.g. Cowboy CB4500 etc.
  7. The big advantage (for me) in using an electric machine is I can use two hands to hold/manipulate the material. Not having three hands (!) I've found using a machine manually has limitations. And Constabulary is right, a servo is great, a servo with a small pulley is greater and a servo with a small pulley and a speed reducer is the greatest! (Or a servo, small pulley and large handwheel). If a Tippman/Outlaw came along at a bargain price I'd have it, but if I have to pay full price I'd rather put more money in and buy a CB3200/4500, far more useful in my opinion.
  8. Cost is nearly always a factor, but if you have a market for your products then the initial outlay will be money well spent. If you're purely a hobbyist, as many on here are, then it can be hard to justify the expenditure. If all you're going to make is pancake-type concealed holsters then a CB3200 would be a great machine, but if you intend doing Western-style holsters then you'll really need a CB4500, anything smaller is not going to be suitable.
  9. As long as the frame isn't damaged it could be a good buy, tell them it's an unknown quantity because they can't tell you if it's working and the table looks pretty knocked around. Turn the handwheel and make sure that the needle bar/feet move up and down with no binding and there's no funny noises. If you get it at a good price but it proves to have a problem you can always sell it for spares.
  10. Do a google search on Juki 227, it will show quite clearly that the seller doesn't know what he's talking about!
  11. Yep, and no records have been found for the W machines. It seems when the factory was demolished the records went with it?
  12. Thanks for that, Alexander, it makes for an interesting story.
  13. That is a very old motor and clutch!
  14. Sorry, I just assumed that anyone using a forum knew what a "sticky" was. My bad. Thanks Wiz. Wiz answered your question with his first post. The maximum size you will be able to use reliably is #138 thread. It doesn't look too bad on a dress belt, but on gunbelts it can look a bit "small", likewise on a sheath. 3/8", by the way, is the maximum you can fit under the feet and still sew.
  15. Well, that explains the missing bits - if the crate was open then anything that was loose and not too heavy has probably been "appropriated". As Don said check the casing/frame very carefully, if it looks ok then you may be onto a good thing (even better if you can beat him down a bit).
  16. Ahh, holsters, if your friend wants to sew holsters with a machine then he's looking at a heavy-duty machine. A minimum is a 441-class. Don't even think of anything less.
  17. In my (limited) experience the worst thing that can happen with older machines is to have screws missing!! I have scrapped one or two older domestic machines and have a wonderful assortment of screws from them, but so far none of them have fitted any of the industrial machines that I have! Good luck.
  18. Advansite, have you read Wiz's sticky at the top? It is an absolute necessity for anyone starting out and wanting to use a machine to sew leather. Many newcomers who hand stitch ask the same thing, they expect to be able to use a similar size thread when machine stitching, unfortunately that is way beyond the capability of most of the machines commonly used by members here.
  19. If that's ALL that's missing it's no big deal, motors and belts are readily available and you can probably buy the correct table for it (or make your own or modify a used table if you can find one). If you want to make it "original" then you should be able to buy all these bits from one of the vendors on here - but you'll have to find out the cost first to see just how much of a "bargain" you end up with. Mark, I must admit it does seem a bit odd.
  20. Spare zipping??? Looks like you've got enough to run a zip from here to the moon! I have a few zips that I recovered from a tent I scrapped and it fits the large guide nicely, I just don't make anything that needs zips. Still, I might as well run off a few more, just in case. As for the nozzle clearance yep, I'll have to check it as when I set it last the weather was quite hot and now it's cold. In fact it's so cold in the shed where I have the printer that when I turned it on a couple of days ago the display was garbled and it said it was too cold to run!!!
  21. Thought I'd print out the zipper feet, just to see how they worked. Came out fine, although there's a slight deformation at the top edge of the rounded bits sticking forward. Doesn't affect how they work though, and they're a nice snug fit when they snap together. Pity I don't actually sew in any zips.
  22. So according to that chart my 51W59 was made before 1940 and the 111WSV77 in 1946 (that's assuming that the WSV's were included in the same numbering scheme, which I figure is most likely). By my reckoning that makes the W59 probably 80 years old at least.
  23. Brian, I reckon putting them all in one place (3D section) is a good idea. If you don't you'll soon have the Mods giving you a severe beating with a wet flannel!
  24. Thanks for the offer, Brian. I've printed out quite a few things before and never had this problem so it's obvious that my fiddling around with the file has caused the issue. The bobbin measures 25.67mm/1.01" D x 11.2mm/.44" high. I figure it needs a smidgin more diam. to fit comfortably. My idea is to maybe stack two or three bobbins per slot, which is why the lid will need a hole so it can be rotated to the stack I want and then just tip out those. Singer bobbins will obviously be a bit loose (smaller diam.) but should still work. I should have just made a new (solid) lid with a centre hole and 1 hole at the edge, I guess. I still want to try and figure out what I did wrong. It's an hour later and I found out what I did wrong! I used the "scale" function to lower the height of the cylinder significantly, which, of course, meant that it also shrank the bottom layer accordingly - down to one layer of filament!! I'm learning..........
  25. Thought I'd experiment with this. I started with a top piece so reduced the height and punched out one of the rebates to make a through hole. First problem, it only laid down a single layer before starting the rebates and as you can see it's not fused together (too far apart), second it warped when I removed it even though I used a heated bed, third the rebates aren't wide enough for my Seiko bobbins and fourth I seem to have introduced some distortion while messing around with the file . Back to the drawing board (in this case 123D). Wish I knew what I was doing .
