dikman
Everything posted by dikman
  1. Excellent! Thanks gr8legs. Perhaps if you post all the files in the 3d printer section, as anyone looking is likely to go there first? As for PLA, I've been surprised just how tough it is.
  2. Thanks Uwe. I just downloaded 123D, it's apparently not supported any more by Autodesk, but that doesn't matter for my needs. I found some tutorials on youtube and it looks pretty good as the learning curve doesn't seem too bad. If this isn't adequate I'll give Fusion a try.
  3. Looks like it's "double-stacked" in the 3rd and 4th pics. That's an interesting idea, I'm trying to get my head around it and wondering how (or if) it would work for CAS.
  4. Nice job! Good to see you've been doing your homework before jumping in. Fitting the smaller/larger pulleys is actually a great way to reduce the speed of the machine, and if you fit a reducer later it will just crawl along!! As for the pot control, it shouldn't be too hard to fabricate a suitable conventional foot control pedal? Any chance you might post the files for those pulleys? I tend to collect useful-looking files, just-in-case .
  5. Very nice! Out of curiosity I looked them up here in Oz but no prices listed, which generally means they scare people off!! I found a 2-year old unit (24) for $22,000!!!!!!! I doubt if I could ever make and sell enough items to pay for it, let alone turn a profit!
  6. I think for this to work the tensioner needs to have a fixed adjustment, for instance a sliding tensioner fitted with a screw adjuster to keep constant tension on the belt. Perhaps not as convenient as a spring loaded one but it would still allow slackening off the belt without moving the reducer or motor assembly.
  7. Don, I tried that with one of my tables where I swapped machines around but found it wasn't very successful. It looked like it should work but I couldn't get rid of "belt slap" so I gave up on the idea. I suspect that it was caused by having a very small pulley on the motor.
  8. You're right, Uwe, those instructions are particularly bad (even for a Chinese translation!). Yep, according to "the book" 500 rpm is the slowest it can be set. What's worse though is that you can't disable the needle positioner!! That is particularly poor design. The chances are that adding a speed reducer will throw the needle positioner out-of-wack, so to speak (it does on my particular servos). Best bet, as Don said, is a small motor pulley and replace the handwheel with a much larger pulley. This will give much lower speed, increased torque and shouldn't upset the needle positioner.
  9. Yes. Now that you understand all about needles it's time to get stuck into thread sizing!
  10. From Wiki - " The advantages of a brushless motor over brushed motors are high power to weight ratio, high speed, and electronic control". Which means they should be a bit more efficient than a brush motor, but honestly I doubt if, in the case of our needs, we would notice any difference. The main advantage I can see is that there are no brushes to wear out (but again, for most of us I doubt if that's likely to be a problem). As for "braking action" I doubt if they'll stop any quicker than the common brush motors many are using now - at least not enough that we're likely to notice it. Only reason I could see to change is if you wanted the "latest and greatest" , but I would also assume that they would come at a premium cost.
  11. You did well on those horse rugs, that first one in particular looked a mess! Not sure that I'd be interested in trying to repair something like that! Yep, those old Seikos are nice, well made and if looked after will probably still be working into the next generation (I'm sure there will always be someone who appreciates old machinery).
  12. The 335's are considered to be a very good machine for their class. Like most of them I see that it is setup with a binder, and while you can sew normally with the binder feet you will probably need to replace them with "standard" feet. By the way, I just read your OP a bit more carefully, and as Brian pointed out if you want to sew 12 mm you may need to go bigger. The 335 is designed to max out at 3/8"/10 mm under the feet. Depending on the leather you may squeeze 12 mm under it.
  13. The Cowboy dealers here also have some slightly lighter duty machines (3200, for example) that would probably be better suited to what you're doing and are, I think, within the price range you're looking at. It would have the advantage of being new and come with a servo. Steve's Industrial Leather Sewing is also located in Qld, so could be handy for you.
  14. I couldn't find a huge amount of info on it but the specs I did find indicate it's pretty close to a 441-type machine - which is heavy duty! It might be a bit too much for what you're doing. You didn't mention what size thread you're using. The RRP of $8700 is really pretty irrelevant in this case, as it's only worth what someone is prepared to pay, and considering a new Cowboy 4500 is about $4500 here in Oz if he hasn't sold it in 3 months then it's obvious that he's asking too much. It's the sort of machine I'd like, but not at that price. Plus it's got a clutch motor (!) which to me is a negative factor (as in more expense to fit a servo).
  15. There's something very classy about those old treadle stands. I restored one once, but sold it because a.) I realised I wasn't going to use it much and b.) I didn't really have the room to keep it.
  16. A goes with E = piping feet. C & D go with F = "normal" feet". Other bits - top is the part that the bobbin fits on to, bottom is the hook that rotates around the bobbin. The hook could just be a spare, or it could be worn out and was replaced but kept anyway.
  17. Very neat job, albeit a slightly weird design . You used lot of screws on that job Uwe.
  18. If the machine is adjusted correctly the reverse stitch will always be correct regardless of the stitch length selected.
  19. If you know you are going to have a market for whatever you make then just get a suitable electric machine from the start. It will be the most cost-effective solution in the long run and will likely save you some grief down the track . The most important thing, however, is to figure out exactly what you're likely to be making, as this will determine the size (and cost) of a suitable machine. If you're going to make western-style holsters you will need a heavy-duty machine.
  20. BARGAIN!!!!! Grab the other bits too, for $150 you can't loose! Nothing wrong with a servo with the control knob, it's simpler to operate.
  21. Top mounted bobbin is definitely easier to access!
  22. I guess a good place to start is with the 210 needle size (Needle style 16 x 257)? Put one in, turn by hand and see what the timing looks like.
  23. I see you've got quite a fluff collection in there. Holding the end of a vacuum cleaner next to it and using a smallish brush works well for jobs like that. Unless you've either got bags of money or have no idea which end of a screwdriver to hold it's a good idea to spend the time learning how to take care of it yourself. Basic adjustments aren't that hard once you understand the principles behind how it works, and the knowledge will be invaluable for when it (inevitably) goes wrong.
  24. At least the trip was worthwhile! Those machines should keep you busy while you get used to them. The 206's are nice machines.
  25. It's a direct-drive unit, so I would assume that all the electronics are mounted in that housing attached to the head and shouldn't need to be removed? Gottaknow (Eric) is probably the only one who could clarify this.
