Everything posted by dikman
Hand speed controller for Cowboy and similar sewing machines
dikman replied to Wizcrafts's topic in Leather Sewing Machines
Fred, such a speed reducer would have to be wired electrically into the motor, whereas Alexander's and LD's idea would be connected mechanically to the existing lever arm on the motor speed control. It's not something I would contemplate, better off leaving the existing electronics intact, I reckon. -
LumpenDoodle's idea of using R/C components is quite a good one, as they are relatively cheap these days. Only downside I see is that it would be a slightly complex mechanical construction, with a bit of electronics thrown in (but nothing too difficult). It would also necessitate a power supply. Alexander's, on the other hand, is a simple mechanical solution that would likely be easy to implement for most people (also less to go wrong). -
recomendations for a good heavy duty, walking foot, zig zag
dikman replied to mixmkr's topic in Leather Sewing Machines
That handcrank and handwheel look awfully similar to the those fitted to my Singer 201K (even down to the mounting arm). -
Further evidence of the old adage that there's not much that can't be solved by using a hammer! (Nice machine too).
Cowboy CB4500 vs Cobra Class 4 Comparison
dikman replied to Wonderboy's topic in Leather Sewing Machines
"well it is English Jim, just not as we know it .. " (To further paraphrase - "there's Cowboys on the starboard bow"). Yes, I've often wondered why Chinese companies that are manufacturing very good items do not go that one step further and have someone who can do a proper English translation of their documents. A mystery. I bought an EPS with one of my servos, as it sounded like a good idea, but I don't like it! As Mike said it had a tendency to sometimes put in an extra stitch, and while on clothing with fine stitches it may not matter if it happens on leather work with "big" stitches it's a pest. Besides, using a very slow speed, as I do, it's easy enough to control exactly where I want it to stop. -
" My wife already thinks I have too much into a "new" hobby ". Far from it, you've got off to a very cheap start!! A servo is pretty cheap over there and it will probably be the best investment you could make for the Singer. Get what you can for the serger, fit the servo and you'll be happy.
- 12 replies
- 111w155
- quick rotan
(and 1 more)
That is a well thought out solution. For anyone wishing to try making their own there are all sorts of hand levers out there, for cycles and motorcycles, so it shouldn't be too hard to find one that will work. I don't really need one, but I'm tempted to have a go just out of curiosity to see what it's like to use. Well done Alexander. -
Nice looking machine. From the look of that tension assembly it shouldn't take much to straighten it.
You can squeeze a slightly longer stitch by doing this, as there's no other adjustment that I could find internally. But it all helps.
Very fitting, a Singer in British Racing Green.
- 42 replies
- leather sewing machines
- what machine is used for leather
(and 13 more)
- professional leather sewing machine
- which leather sewing machine is best
- best machine for sewing leather
- sticky???
- sewing leather
- best antique leather sewing machine
- best new leather sewing machine
- leather sewing machines makes and models
- what machine do the pros use
- leather sewing machine reviews
- leather sewing machine opinions
- best sewing machine
- leather sewing machine question
Flatbed machine: space saver table and direct-drive conversion
dikman replied to alex11's topic in Leather Sewing Machines
Bit of a problem if trying to make a minimal table for a flatbed machine, due to the large cutout needed and the drip tray underneath. I guess a pedestal-type mount could be made, but it would be a bit more complex than that needed for a cylinder arm machine. All I can suggest is cutting down a standard table so it is no wider than the legs and perhaps cutting some off the back so it isn't as deep. I have to make a table (eventually) for a walking foot head I have and that's all I'll be doing. -
You don't necessarily have to buy a new machine, just one that is suitable for what you want to do. At least now you have a better idea what to look for.
Space saver table, where do I buy?
dikman replied to Jordanball33's topic in Leather Sewing Machines
My tables always seem to end up with extra holes drilled in them . -
I was about to say the same thing, Constabulary. I've seen it happen many times in forums, people need to keep this in mind when replying. That aside, fascinating stuff, Gregg, quite a mechanical contraption .
- 42 replies
(and 13 more)
- sticky???
- sewing leather
Brian, I found the same thing except I filed the bottom of the plate to allow the lever to touch the bottom of the frame slot (can't go any further than that!). I watched all the mechanicals to make sure nothing was touching where it shouldn't and everything works fine.
which to choose Consew 206RB or Chandler 67?
dikman replied to DavidRM's topic in Leather Sewing Machines
Not controversial. Clutch motors are great for high speed garment machines, not so good for the slow speed and control often needed for leatherwork. Someone who is skilled can use a clutch motor successfully on leather, but that isn't most of us! If you're new to this then a clutch motor can be a scary thing to start with, if you can get it fitted with a servo then do so, it will make your leather sewing much more enjoyable. Fitting a speed reducer with a servo will also give you increased low-speed torque, but that may not be necessary, just depends what you're sewing.- 7 replies
- sewingmachine
- consew
(and 1 more)
Download the manual and read it - lots of times! Try and clean out as much dust and dirt as possible, using a stiff brush and rags, before oiling it. If you can't get the Lily Oil then hydraulic oil (ISO 34) is pretty much the same thing. Make sure it turns over ok by hand, if it doesn't find out why (don't force it). Finally, if it's got a clutch motor be warned, they are scary things for a first-timer and hard to control for leather work. 225.pdf Manual.
I was just looking at the photos and thought "aha, the needle's in backwards" and felt pretty clever - then I found others had beaten me to the punch! Don't feel too bad, work9to5, you aren't the first to do this and you won't be the last. At least it's an easy fix.
If it worked before then the needle height should be ok. Did you insert the bobbin so that the thread is coming off in the right direction and is threaded correctly? You could try reversing it in the bobbin housing and see if it makes any difference.
That is one serious looking machine!
I've got one of these and it's a nice enough machine, for what it is. As Wiz said, the needles are what I would call an odd-ball size. I fitted a roller foot but haven't actually used the machine much (it was free, but took a bit of work to get it running). It should sew what you want, but If you're looking for your first leather machine this is probably not the right one to get (I consider it more like a second machine when someone already has a suitable leather machine). A bit of advice, if you think you'll be getting into leatherwork then seriously consider a walking foot machine. It will be much more suitable for leatherwork and as Wiz also said factor in a servo motor. You'll be struggling with anything less than this combination.
Odd Adler Cylinder Arm Machine?
dikman replied to Chuckydownunder's topic in Leather Sewing Machines
Chucky, as it's only $2000 I think you should buy it and then you can tell us exactly how it works and what it does. -
What I need to get Singer 111w100 up and running?
dikman replied to melancholycoyote's topic in Leather Sewing Machines
The motor looks ok to me, only down side with an all-in-one unit is that to change settings you have to clamber under the table to get to the controls. Had to smile at the "600w bigger than 3/4 hp" bit. Technically, yes, it's bigger than 3/4 hp but the difference is so small you'd never notice it! -
Beware of "semi-industrial" sewing machines
dikman replied to Darren Brosowski's topic in Leather Sewing Machines
Ah, but it's got a "new, powerful motor" . Quite a write-up they gave it, easy to see how someone new to the game could get suckered in. -
It's a fairly hefty poke to break a metal pulley (even if it is just cast alloy)!
