dikman
Everything posted by dikman
  1. That's very nice, Darren, and the sort of thing I had in mind.
  2. Now THAT is what I call Customer Service (something that appears to be slowly disappearing in this day and age). I am currently embroiled in a dispute with a very large internet service provider here (4 weeks so far), and their customer service is non-existent, exactly the opposite of your experience - the (non)help desk is manned by Indians (NOT US-indians) if that means anything! It is very refreshing to hear of such excellent service. Kudos to Cobra Steve.
  3. Guess you definitely need a discount coupon with that one.........
  4. That's a standard clutch-type motor you have there. If you have to do long stitch runs then that will make it fly - once you learn to control it!
  5. You Americans are so used to "promo" codes that you think it applies everywhere. There are some things where they don't need to provide them, this is one. You'll still enjoy the machine.
  6. $75 ?!! Bargain! 1/4 HP motor? Sounds a bit small.
  7. That's ok, the memory starts to go as you get older .
  8. Rocky, on my 335 raising the doo-hickey (technical term) on top doesn't have any effect on the outer spring, as the spring pushes against the top of the housing regardless of the doo-hickey's position. All it does is change how much additional tension can be applied via the inner spring. Gregg, what you say makes sense, although I don't know if that's what they do.
  9. LD, a pretty compact solution, all that weight should make it quite stable. Mess? What mess? Evo, that is also an interesting stand. Great solutions, people, I love seeing what others come up with.
  10. . Well, I'm prepared to give it a good home where it will be appreciated and let it see the light of day! Anyhow, I got curious and just had a closer look at mine. The outer spring is fixed and is non-adjustable, the inner spring provides the adjustment (not that it seems to make much difference in the normal setup). The mod you did, however, can allow the inner spring to have more effect. By raising that "sleeve" it reduces the tension applied by the inner spring when the adjusting screw is all the way out so when you adjust the top screw it should have more effect. Of course, to get the best out of it an awfully long screw will be needed . Seeing that I haven't really been able to find a screw with the right thread size I might run a tap through to use a more standard size and then make a decent adjuster, now that I know how it works.
  11. Poor little machine, all neglected and lonely in the dim dark recesses of that storage container.
  12. Well done, sounds like a good deal! I found this link, might be of some use?
  13. Sharp eyes, Yetibelle! I ended up with a few welt-type feet, so I ground one set down to give me flat feet. Quicker than waiting for delivery from overseas.
  14. I went shooting last Saturday and we were sitting around talking. One of the guys said he's been looking at/researching sewing machines (because of what I've been telling him) and is slowly coming to grips with the terminology. I laughed and told him to be careful as they can become highly addictive!
  15. I reckon you did real good! Trust me, you really need to ditch that motor for a servo, that thing is rated at 3500 rpm and even if you fit speed reducing pulleys it will be far too fast for a newbie to try and control. Trust me, I've been there, done that (and mine was rated at 1725 rpm!). As for the needles, depending what you want to sew they may work fine for you, no harm in experimenting.
  16. It was pointed out to me that the pressure screw was missing on my 335 when I posted pics here, so I found something that would fit to replace it. Funnily enough, it didn't seem to make any difference to foot pressure, so I figured I needed the correct screw. From what Uwe said it now appears it was missing because it didn't make any difference. Now I'm curious to find exactly what, if anything, does affect the foot pressure.
  17. Uwe's right about cheap, of course, possibly a poor choice of word on my part I should have said relatively inexpensive. On the other hand, if you want to experiment with chopping up feet then cheap ones are a good way to go, in case it doesn't work out. He makes a valid point about changing stitch length, if you are likely to be changing often then it can be a bit of a pain with these machines as it's basically trial-and-error to set the length that you want, although I don't find it an issue. If you already have a heavy-duty machine then I guess the 211 might be the way to go, as it's a bit more "modern" (just)? Bottom line, of course, is how they sew - do they pick up the bobbin thread every time, no dropped stitches, consistent stitches and tension and, perhaps most important, no play or loose rattly bits! Having said all that, I bought all of mine without even trying them!!
  18. I have a 211G166 (I don't think there's much difference to the 165), very nice machine and obviously later than the 155 and will handle up to #138 thread. From what I understand the 155 could probably handle slightly heavier work and is considered quite desirable by many (I'd like one), although it doesn't have reverse. Both use the same feet so they're readily available and cheap. Can't comment on the Pfaff, but as long as the Singer's are in working condition you can't go wrong at that price. I guess you may need to factor in buying a servo too? If I saw them here at that price I'd probably buy both, but that's just me .
  19. Thanks mate, it just looks a bit "cheesy".
  20. This is the stitch change "knob" (I have an identical spare that came with it). It sort of has reverse, but the needle doesn't move much when it's engaged. It's spring loaded and engages in the slots on the plate.
  21. That looks to be in very good condition. Just wondering what the screw and locknut, to the left of the stitch length adjuster, is for?
  22. Eero, I have a similar problem with my (old) Pfaff 335. It has a manual tension release - see lever next to tension disc - so I thought I'd be clever and fit a pin to make it automatic. Unfortunately, every time the foot comes up during sewing it releases the tension. It has me baffled, because I can't see any adjustment or, in fact, anything that looks either wrong or missing. So I've had to leave it as a manual release. I'm curious to see what responses you get. I haven't seen this type of release on any Pfaff 335 photos anywhere.
  23. That stinks! As the first person to show an interest you should have been given first right-of-refusal. Doesn't say much for the integrity of the seller, imo.
  24. So basically you're turning it into a needle-and-inner-foot feed only?
  25. This is it, pretty well finished except for fitting the tilt hinges (I don't have the right size bit yet to drill the rebates). I couldn't get it to sew reliably, it kept missing stitches (hand cranking only). It didn't matter how I tweaked it the hook wouldn't always grab the loop. The needle was an original style that came with it and didn't have a scarf so I changed to an equivalent with a scarf and after re-adjusting the needle bar it worked much better. After all that effort I'm now thinking maybe I should try and sell it.
