dikman
Everything posted by dikman
  1. What Bert said, clean, neat and functional.
  2. It would certainly be easier if you had a machine designed to handle #207 thread. Most upholstery-class machines are, in general, designed to handle #69 although some can use #138. Anything above that is problematic. And it sounds like you WILL need a heavier-duty machine for your next stage - or hand-stitch it! You mention that thread is slipping between the tang and the needle plate locating slot? If we're talking about the same thing then something's definitely wrong as the thread shouldn't go anywhere near that slot.
  3. If it's a gift, as Northmount said what is the person on the receiving end going to be making with it? And what is your budget?
  4. dikman
    Tote Bag
    Very nice job, looks great!
  5. With a bit of modification I don't see why it shouldn't work. Reinforce the table top, possibly with an angle iron bar underneath, and the cross bar at the bottom may need to be lowered to place the pedals closer to the ground for comfort. I'd keep the machine as close to the right as possible to keep the weight over the table winding mechanism (I'm assuming that the total weight of your setup is within the load capability of the winder?).
  6. I've noticed that the sewing machine collecting bug tends to bite people on here! Should keep you out of mischief for a while.
  7. You're fitting a belt cover? The first thing most of us do is remove it (if it's fitted).
  8. If that's a used machine it appears to be in very good condition.
  9. As long as the cat likes the mods..........
  10. Yep, you did a very nice job on those.
  11. Nice. From the outside it looks to be in very good condition.
  12. Looks great to me, yes, the handle is pretty "hefty" but given that it carries petanque balls it needs a bit of strength. It's not meant to be a ladies handbag.
  13. Blood?
  14. Read Wiz's sticky, it's THE starting point to understanding leather sewing machines. Note that if you want to make holsters with a sewing machine then that straight away puts you into the heavy machine class, usually a 441 clone.
  15. I bought an open frame too because of the flexibility of sliding things under it, unfortunately I soon realised I needed to enclose it and use an exhaust system because of the fumes!!!!! Mine didn't come with software, normally I tend to find free software that generally works but in this case I ended up actually paying for Lightburn and consider it money well spent, it's an excellent piece of software for laser engravers with lots of user guides on youtube. These things have lots of creative potential for leatherworkers.
  16. That's what I did, so I could move the lifter pedal to the left of the go pedal - but it took a bit of fabrication!!
  17. If it uses brushes then there should hopefully be some sort of screw fitting where the brushes are mounted, there will be two on opposite sides of the motor housing.
  18. That's a shame, but I can understand you being wary when it comes to very old machines as parts can be a problem. Me, I would have grabbed it as walking foot post beds aren't exactly common. But then, I can be a glutton for punishment!
  19. Have a close look at the motor, if it uses brushes then yes, a simple speed controller should work (although I would suggest an electronic controller rather than a simple rheostat), if the motor doesn't have brushes then it is an induction motor and the controller WILL NOT work. Vintage sewing machines used brush-type motors to allow for rudimentary speed control.
  20. If you have an ac motor belt sander (most likely) then no, a dimmer switch or rheostat will not work. There is no easy way to control such a motor. Variable speed grinders/belt sanders generally use a 3-phase motor with a Variable Frequency Device (VFD) used to control the speed. These can be run off the single phase household supply.
  21. Very neat solution.
  22. Awww, what a little cutie! Patch cutter - when loading a black powder muzzle-loading rifle a cloth patch is placed over the barrel, the round ball is put on top and pushed/tapped down to just below the end of the barrel and the excess cloth is cut off before the ball is rammed down the barrel.
  23. A walking foot post-bed for $250! No mistake, I reckon you've done well! Just ditch the clutch motor and you'll be laughing.
  24. I've always said the worst thing you can do is having to deal with customers.
  25. "I basically need a sort of one shot machine that can do most things." Ahh, the mythical unicorn of sewing machines. Every leatherworker who uses a machine would like one of those. Paradoxically, the machine that comes closest is also one of the biggest/heaviest, a 441 clone. Using a modified needleplate/feed dog, as made by a couple of members on here, it can sew using very heavy #347 thread down to #69 (if you can find the right size needle). BUT they are big heavy machines!
