dikman
Everything posted by dikman
  1. I bought a used set a few years ago (genuine Triumph), they needed a bit of repair work - stitching, rivet replacement etc - but they've served me well since then. I noticed at the time that the leather looked "funny" at some of the edges but didn't worry too much. In the meantime the leather has slowly cracked and torn at some of the folds and looks a bit like thick cardboard separating at the breaks. Hard to describe but nothing I've seen before. Anyone have any ideas what sort of leather it might have been? I've just pulled them apart to salvage any useable bits as they were past being repaired.
  2. The mice are very well done, something that's a bit different.
  3. Very nice indeed! Looks like a lot of work went into it.
  4. dikman
    New stuff
    A set of carved holsters and gunbelt would look impressive as a display (most people would recognize what they are but would rarely see them in real life).
  5. Gosut, I admire your tenacity! Me, I just got a suitable container, poured in some vinegar from the supermarket and threw in some steel wool. I did wash the steel wool in petrol first, my token effort at a "scientific" approach!! End result was a useable vinegaroon. It's now a couple of years old (and brown) so I suppose I should try it again sometime and see if it still works.
  6. A rather strange, and vague, question. It's a pretty simple matter to look up clothing on the internet.
  7. dikman
    New stuff
    The saddlebags are particularly well done. Takes a lot of leather to make them. HS, due to our overly restrictive firearms regulations here in Oz the demand for holsters, rifle scabbards etc is small. Not likely to be things you could sell easily at a market stall.
  8. I had an old industrial frame that I was determined to use so made up a table for my Pfaff 335. Naturally, it's heavy and the only way to fit castors was to weld them to the bottom of the legs! This raises the whole thing up, including the foot pedal, and consequently I need a taller chair because the frame's not height adjustable, of course. I also had to add a piece of bungee cord to the back of the pedal for extra support due to its weight. This machine doesn't get used a lot but I'm not sure how comfortable the setup would be for extended use.
  9. Ahhh, I forgot red things go faster! If you wait long enough, and keep looking, I'm sure one of the old cast iron frames will come up, but from a practical using perspective the setup you've got is probably better.
  10. In their own way clutch motors are very nice motors, well-built and almost bullet-proof! Considering the machine only cost you $150, I reckon you should be able to treat it to a servo motor (best thing you can do for it).
  11. Very good job on the rebuild. Yeah, the colour's a bit "in your face" but hey, as you said it's your machine to do with as you wish. Given the rust on it I'm surprised the table top hadn't suffered water damage.
  12. I'd agree with it being a Singer 111. Trying to figure out exactly which model can be tricky as they tend to look alike! It looks like it might be fitted with a piping foot?
  13. In answer to 2, because it was in the movie. At the end of the day it's simply a holster, functionally no different to many others out there. edit:LittleF beat me by a whisker!
  14. If money isn't a problem then I guess it would be nice to own the Adler, but realistically there's nothing wrong with owning one of the brand-name clones and saving a bucket-load of money. There are many on here who own clones and in general have found them more than adequate.
  15. I made a notebook cover but didn't want to dye it so gave it a coat of NFO and left in the sun for a couple of days. It darkened slightly to what I think is a lovely looking "natural" patina.
  16. Well, I'll be the odd one out here - I don't particularly like the look, it doesn't appeal to me (guess I'm more of a "traditionalist" ). But I'm also not a fan of basketweave either, make of that what you will.
  17. Viva la revolution! Gotta love the French! What about waiting to buy when you move to Spain? Have you looked into the prices/availability there?
  18. I do as KGG suggested but if it's critical to start at a particular point I remove the thread from the needle and sew forward three holes, re-thread the needle and then sew back to the start. This way I'm at the starting point I want.
  19. Looks nice. Hopefully KGG should be along, he is pretty knowledgeable about the various Juki models and should be able to help you.
  20. In my case one was from a second-hand shop that had a lot of tools and stuff and the other was from a junked piece of equipment. I had to fit a sleeve to the spoked one as the shaft hole was too big. I keep my eyes open for used ones as they're pretty expensive to buy here.
  21. The one made from cowboy boots looks great, the colours/patterns give it texture.
  22. I would definitely pass on it if I were you. At the very least you would need to buy a servo motor, so more cost. Keep looking.
  23. I found this some time ago and made one (never used it but I just wanted one). There is another instructions file but the site says it's too big to upload, it's 1.3 MB. EDIT: Added Instruction FIle Ammo box.pdf Ammo box instr.pdf
  24. You're right, because of the angle my eyes didn't see it as a loop.
  25. Nice simple, understated design. In the first photo what's the bit sticking out on the left side of the belt?
