fredk
Contributing Member
Everything posted by fredk
  1. I've never used the 'professional' - just their regular acrylic dyes [C30] In my first days of making leather stuff I accidentally made a 'medieval' style belt bag with a 'distressed' look As I've said elsewhere; Never, ever tell a client/customer you messed up What happened was; I made the bag up, then the customer chap [c-c] said he wanted it black. So I started dyeing it. The dye was coming out streaky so I wet a cloth with methylated spirits and started to wipe it off - only it didn't, it thinned the black look on the main front, rear and flap surfaces and the raised surfaces, but it stayed black on most of the gusset and around the sewing and latch. The c-c happened to see it like that and liked it very much
  2. I have leather that is pre-dyed that sort of colour; its called 'raspberry crush' I also have a 'neon pink', various bright greens and bright blues and a lavender. I've used up all my purples; they were popular for a while. I got my coloured leathers from Le Prevo. I'd think most tanneries will have such coloured leathers in stock
  3. The jacket and bag are fashion items; the 'distressed' look is carefully spayed on finish The boots on the other hand [?!} have that look after years of hard use [possibly] You could try using un-dyed veg tanned, and doing a partial dyeing on it, not too heavy
  4. Firstly; check that it is fully leather. Take a small piece, hold with pliers and apply a flame from a match, candle or lighter. If it burns quickly and gives off black sooty smoke its not leather, if it burns and curls up and smells like burnt flesh or burnt meat it is leather
  5. fredk
    Hungary
    reading what is not there I guess the OP wants to know what to put on next to weather proof the bag Firstly; Remember - it can not be made totally waterproof - it can only be made a bit weather proof Buff the bag, buff it some more, then apply some neatsfootoil, followed by a few coats of diluted Resolene. For most things I find that does the job, along with beeswax polished on. Or use a few coats of Snow Proof Paste Make sure you get plenty of either the beeswax or Snow Proof into the leather joints and the sewing - thats where the rain water will get into the bag
  6. I use a sponge, as a/ It can be guaranteed I have a clean one handy b/ I can squeeze it out easier c/ I only dab it on the leather to apply water, I don't wipe it or swipe it around
  7. I only use acrylic paint for colouring-in details. As acrylic paint only stays on the surface of the leather I don't consider it best for over-all colouring. For a coloured bag I use dye or pre-dyed coloured leather
  8. to re-inforce what has been said already; I have some 1.5mm/2mm cow veg tan which I can rip apart like cloth, but I also have some 0.6mm/0.8mm deer skin leather which I cannot rip apart at all
  9. Never Ever tell a customer/client you messed up! Bluff it out and say you are thinking of this design, ask his opinion; if he says he doesn't like it then offer to do it differently In leather work, as in Art, things don't always work out how we intended them to; they're not wrong, they're not failures -they're just different I think; not only should all the tapers match but the ends of the inner should be a lot shorter, cut back to between the third and fourth hole from the left, or to the fourth hole, and the other side to match
  10. >> a one-card wallet with a key chain attached. Sew two pieces of soft thin leather together; each just slightly larger than a standard credit/debit bank card. Cut one top corner off at an angle on one piece of leather only, on the opposite top corner attach a chain or something with a split ring attached to that - or use a sail eyelet and attach the split ring right to the wallet. You'll need to fettle the design to get it to work out >> more coin purses, and more coin purses. if your price is right you'll sell plenty. I have the plans for a simple semi-circular coin purse. One piece is circular, another piece is semi-circular; sew or lace together. A simple popper holds the unused semi-c to the attached semi-c for closure >> hot cup wraps. a patterned or worked leather piece for a disposable coffee or tea cup [the type you get in Starbucks or McD] to sit in
  11. Try LePrevo in Newcastle, England. Email them, they're very helpful http://www.leprevo.co.uk/ 2/3rd down are the solid rivets; [Saddler's Copper Rivets] http://www.leprevo.co.uk/rivets.htm
  12. I disagree on the strength of rapid rivets. The guige strap of this shield is held at each end by a rapid rivet thru the wood holding a short strap, then the main strap itself is held to that via a brass loop, that strap is closed by a rapid rivet. The shield weighs about 7 kilos [15.5 lbs approx]. Under test one of my team whirled this shield around his head by the guige strap; he did this for several minutes using great force. The test lasted nearly an hour, testing the security of all the straps. After this the rivets were inspected - they were still holding solid, and they continue to do so. All my shields have been in full contact battles and not one has failed in any way, and certainly not the ready rivets
  13. With rapid rivets the stem should be 3mm to 4mm above the leather, eg on 3mm leather the stem should be 6mm long. Any longer than this and the head will want to go sideways as you blatter it down tight. You can get away with only 2mm beyond the thickness of the leather if you blatter it down real good and hard
  14. We just call it - 'elastic, the flat stuff'. aka 'Flat Woven Elastic' available by the yard in many widths in any haberdashery
  15. Exactly, no need to copy the pattern - in fact do not copy it. Adjust your stitch length for the thickness of your thread eg, a 1mm thread looks ok at 6 stitches per inch, 0.5mm thread looks better at 8 or 10 spi A stitching groove is handy, but only really necessary where the object will get wear on the thread area, eg on the soles of shoes. You can get stitching hole markers in various stitches-per-inch. Some tools have a handle with changeable spi wheels
  16. The green handled shears are tin-smiths shears Another picture 'unknown' ; and adjustable edger, loosen the knurled ring, the other part should screw up into, and down from, the handle, then use knurled ring to lock it in place
  17. The only way I know is to skive the end of the piping until it is paper thin
  18. 1. yes, it will darken it 2. Drill a hole in a bit of metal eg steel plate, counter sink if you can. Lace larger than hole. Wet leather and pull thru hole. Lace gets rounded 3. like this; IUI or InI, where the top of these is the outside 4. okee-doakly
  19. 1. Smoother lacing; pull the lace thru a cloth with very soft beeswax/neetsfoot oil on it. That will slick the lace. Not only improves the look, it makes it easier to pull thru the holes 2. Smaller lacing holes; match lacing to hole - round lace thru a round hole, flat lacing thru a slit hole. For a slit hole consider using an oval hole punch, they can be bought a : cheaply, b : in sizes to match flat lacing, eg 3mm x 2 mm A small selection of these covers most usual lace sizes 3. A wider gusset with the edges beveled and folded to meet the sides; either an outwards fold so there is a ridge line, or inwards bringing the gusset flush to the sides on the out side - a bit more fiddly to lace together tho 4. Smooth all cut edges of leather which is over 0.8 mm thick - that is, all cut edges. Even just a rub over with beeswax and burnished using a piece of denim or linen type cloth can make a real difference. 5. Try to cut lines in one cut; less likely to get stop-offs as can be seen top centre, forward. If you do get these a few swipes with 'sand' paper to take out the change in the cut-line, then slick. hth
  20. I would not support the use of the term 'anecdotal'
  21. The 'academic paper' dates from 1935 and only looks at shoe sole leather in one context I think you need to consider the longevity of the likes of horse saddles which have lasted 50 plus years, some in almost daily use. A good well made horse saddle, well looked after will last a very long time; probably out lasting several horses. At an estate near me there is horse tack which was made in the 1790s thru to 1820 approx, it is still in regular use - its been well looked after. Veg tan leather will absorb leather feed and oils, chrome tan will not, or not as much. I've seen chairs which are over 100 years old, with veg tan leather, still in use, and I've seen chrome tanned leather covered chairs scrapped after just 5 or 6 years
  22. a/ the blue, sometimes a silvery, look is the unabsorbed dye near the surface of the leather. buff it, buff some more, buff again and again That should get rid of the tinge b/swirl pattern; did you thin your dye? thinned dye put onto damp leather; the damp leather helps the dye to spread evenly and thinned dye can penetrate deeper before drying. A couple of coats put on this way should give you even colour with no application marks c/ only clean leather if you really need to, to get rid of any suspected contamination. Cleaning removes some of the leather's natural oils
  23. All the adhesives I use are general purpose ones Very often when something, an adhesive or tool gets 'for leather work' or another such label the price goes up. Right up. Eg. I wanted a pick-up pencil for picking up rhinestones. I also build plastic models. The pick-up pencil for 'plastic modelling' was £4.99 for one. I found some in ladies nail art - at £0.99 for 5. I could give you loads of other examples. If the 'general purpose adhesive works then use it
  24. Reading the intro I would suggest that the OP 's usual language is not English and the use of 'industry' is just a translation of 'work' As for using glue. On items to be sewn together I regularly use UHU contact adhesive on the seams. I even glue some small cheap-to-sell items together and not bother sewing them. I've tried the double-sided tape, but as KingsCounty has also found, sewing with glovers needles the needle and thread catches on the tape gum. With pre-made sewing holes there is less of a problem. I find glueing the to-be -sewn seam first keeps it aligned, one less thing for me to be concerned about I'm confused by the two terms, adhesive and cement - to me cement is made from calcinated limestone and sand to stick clay brick together in making buildings. All the sticky liquids I use in leather work are adhesive; some work on contact others are slower acting, eg PVA
