LatigoAmigo
Contributing Member
Everything posted by LatigoAmigo
  1. ...and here it is. I hadn't compensated for any volume inside the bag (sorry that my poor pea brain works this way, only one step at a time), so here is a revised front.
  2. And this is what the back (to that front) might look like... This image doesn't look like it will match up to the front piece (because these are slightly different resolution JPEGs, but if you'd like I can post PDFs of these parts so you can print them out and see how close they match up. This design is still in the rough stage, and may need to tweaking, so please keep that in mind.
  3. There are darts, and the piece might look something like this...
  4. Apparently you are not the only person who loves this bag. I found the source of the photos you've posted, and they include a very telling photo of the inside of the bag. If you haven't seen this series of images, you should find them very revealing. https://the-gadgeteer.com/2017/07/26/saddleback-leather-thin-front-pocket-backpack-review/
  5. This is foundational for leathercrafting, so with a little effort you should be able to figure it out. You might start out by going to a thrift store and purchasing a cheap handbag, then taking it apart to see how all the pieces fit. Take measurements before and after, to get a senst of proportions and seam allowances. That might help you to get a sense of what makes up the shape of that handbag. What is challenging (as least for me) is how "big" something really is. The sling bag pattern is pretty easy for an experienced leather worker to visualize, but is the work really begins when creating the exact pattern, with the proportions that you want. The various parts have to fit together (length, width, height), so, for example, the back/flap piece has to wrap around the body of the bag, and end up creating a the look you are after. The body has to fit just right so that the volume of the bag makes sense to the user. I have picked up various books on handbag construction, some at the local Joanne's Fabrics and Crafts, and others from Amazon. There must be many U-Tube videos on the subject, and I'm sure some Google pattern-making searches will bring you fruitful results.
  6. I think the real problem is pressing the rivet. The setting would get crushed. Would something like a Chicago-screw meet your needs?
  7. The adhesive will only stay where there is leather for it to stick to. No need to cut both.
  8. You might change systems. Spell checkers come with Microsoft Word and Adobe InDesign, and they do not always agree, plus InDesign lets me add my own words. So we can legitimize "sprayless" if we want to. I love words and dictionaries, and especially how words change their meanings over time.
  9. No, you would cut out your filigree, lay the adhesive sheet over the backside of that leather, then iron/press it on. Next you take the colored leather and place the colored side up against the adhesive, and press those two pieces of leather together... no fuss, no muss. All of this depends, of course, on the type of leather that you are using. I have not had success with some "oil-stuffed" leathers. You have a big advantage over me, as I am using a simple iron, and that makes it hard to apply an even temperature.
  10. I used to live in a remote area, and encountered similar experiences to yours... for gas, clothes, etc. Isn't that the price you pay for the peace of mind that you might get from living near the beach in France? Just sayin'... If you were to ask me, and I know you're not, I'd say "bite the bullet" and order the product from Amazon, you will be happy. Well, maybe, but what life is worth living without rolling the dice once in a while?
  11. I just can't get over what a beautiful job you have done on this bag. I have also made a "Birkin" bag, only to see what it would take to make, much like you. Your end result is truly breathtaking.
  12. Maybe I don't get out into the real world enough, but can't you order it from Amazon or some other online supplier? https://www.amazon.com/gp/product/B000XAMYXI/ref=oh_aui_search_asin_title?ie=UTF8&psc=1
  13. You might consider using something like HeatnBond iron-on adhesive. I find that it is less messy than spray adhesive, although it requires iron your leather, which may or may not be workable. You iron the adhesive sheet onto the top piece, and when you pull off the backing, the adhesive evenly covers the backside of that piece of leather. Then press the colored leather against that, and iron the pieces of leather. I've used this process on a variety of projects, and have had varying results, but it should work well on veg-tan leather. This probably works better with a "heat press" than an ordinary iron, but I wanted to share my thoughts on the topic.
  14. What do they look like?
  15. You might take a look at this site: http://www.lzpattern.com/. They offer a variety of patterns, and you just might find something to get you started.
  16. So here I am, one hour north of San Francisco. I go into the local Home Depot, and right there in the open is the culprit that's causing so many problems for so many people... absent any Prop. 65 warnings. Go figure.
  17. What a wonder... maybe you should take out a banner ad on this site so this product doesn't get lost in the shuffle.
  18. That concern points out the importance of proper ventilation.
  19. I found a stiffener that you might find interesting, as it is made out of real leather. That might just help it behave more like the leather that is it being bonded to. It is called Leather fibre board, also known as leather board, bonded leather or Salpa, and it is available from a company in the Netherlands. Here is a link: https://www.hollandindustries.nl/en/products/shoe-materials/leather-fibre-board/
  20. For point of reference, here is the bag where I used some 1.5 mm economy grade veg-tan as a stiffener on the front and back (but not on the sides). I like the result, so would look forward to finding Bontex/Texon that could be used instead.
  21. If you try it, I would like to know how it turns out. The product I have is called Texon, and may not be exactly like Bontex, although it is supposed to be very similar. I purchased it at a Tandy store, and it came in only one weight, 2 mm, which is pretty thick. I am interested in what you are using, as it may exhibit different properties than what I have.
  22. I face the same issue with most of the bags I make. On my last bag I Barge-cemented a piece of thin veg-tan on the inside of the body's front and back pieces, flesh-side to flesh-side. It provided the needed support and has held up very well. I use Bontex to keep the bottom of the bag stiff, as it is very cardboard like, and I wouldn't expect it to work very well on the other parts of the bag, at least in my case, as it could get bent or damaged, and not retain its original flat shape.
  23. It isn't always an either or situation. Latigo is both veg-tanned and chrome tanned. Typically veg-tanned can be tooled after being "cased", if that might help your determination.
  24. Believe me, I would be as annoyed as you (probably more so) if that is what I was seeing, but I'm just not running across the warning here that often, and I'm at Home Depot at least three times a week. Because you are out of state, it could be that the manufacturers' lawyers are posting the warnings even when the items have not been properly evaluated, just to cover their butts. The purpose of Prop 65 was to help make living healthier for those of us living here. It was passed by the voters (not the legislature) in 1986 when the smog was still thick in Los Angeles and San Jose, a fair amount of herbicide was being sprayed in our forests, and people in general were worried about being exposed to unnecessary health hazards. Probably not a perfect solution, and now the warnings run amuck, as you've pointed out. 33 years later it is probably pretty hard to stop that train. And certainly, no one here in California can do anything about the warning labels being applied in Nevada. So sorry!
  25. I have some veg tan that is 1.5 mm thick that I can spare. Will that work or is it too thick?
