LatigoAmigo
Contributing Member-
Everything posted by LatigoAmigo
They are not the same. Getting an decent edge (i.e., polished smooth with a finished look) on chrome tan is very challenging, so edge paint is a common solution, with the burnishing done using a heating iron (but not always). Beveling the edge is an option, but not commonly in use, as it makes painting the edge more difficult (my opinion).
If my memory serves me well, when I started working leather in the late 1960's, leather was marketed as being either oak-tan or oil-tan. When I came back five years ago, the terminology had changed to veg-tan and chrome-tan. I have some chrome-tanned and hot-stuffed Horween leather that just about drips oil, so I can see where that terminology comes from. To answer your questions: I almost exclusively use non-veg-tan leathers in my work. Because they are vat-dyed and come in rich and wonderful colors, they are very good for wallets and such. I almost always clean my leather with saddle soap, and finish with a oil-based conditioner. There are many finishes available, so I take that into consideration. I typically use a Dremel tool to burnish my edges, and often with some edge coat along with a wax-based conditioner (not sure what Yankee wax is), but, again, it depends on the particular leather, and of course, the look I'm going after. But I must confess, I use a laser to cut the leather, so my edges come out of that process somewhat burnished.
This reminds me of something I've learned in advertising, that the seller could contend that it is a "printer's error."
I can only address your rivet question. The other questions are a little too open ended for me. You might want to check out a few websites to see the specifications for various rivets. They are typically measured by cap width and post length, and that should be clearly stated in the description. Since rivets are produced by many different manufacturers, I tend to buy from one supplier so that I can mix & match when necessary. My favorite is The Buckle Guy because of the way the rivets are packaged. This site advertises other suppliers who, I'm sure, are just as good.
- 2 replies
- pres-n-snap
- dies
(and 1 more)
Round braids can consist of 3 or more strands. You might check out Bruce Grant's book, "Encyclopedia of Rawhide and Leather Braiding." It is available on Amazon, and will answer any braiding questions you might have.
This is the largest cutting mat that I have been able to find. Not as big as you are seeking, only 3" x 5", but it has been a good mat. I found it available on Amazon: https://www.amazon.com/Sullivans-087168-SUL38233-Table-White/dp/B006JJG6D6/ref=sr_1_1?ie=UTF8&qid=1547741618&sr=8-1&keywords=sullivans+36''x59''+gridded+cutting+mat+for+home+hobby+table
You might try is site: http://www.lzpattern.com/patterns-sewing-patterns-bag-pattern-leather-patterns-stitch-patterns-crochet-patterns-leathercraft-leather-craft-leather-crafting- leather-carving-leather-art-leather-working-leather-tools-leather-craft-tools-leathercraft-tools-handmade-tools-CSL-08?search=hermes&description=true&category_id=60
You will be more likely to get help if you can post some pics of the rivets in question.
That is where to start. Some more books on leather are available (maybe even at your local library), and the various authors will help you decide what tools and supplies you will want to stock up on. Good luck.
If you can afford to gamble, you might consider ordering something to see what you get. Personally I would be hesitant, as there are imperfections in most hides, and if what you get is not to your expectations, it will be a lot of trouble returning the item and getting a refund from what looks like an offshore company. I would say "buyer beware."
You have provided quite a lesson on laser cutters/engravers. Wow. Maybe you could put it into a document that people could download. This information is not readily available, and can easily get lost in the abyss of postings here on the website.
I'm feelin' ya. Most of us are not following a "business model," and do this more for fun than for money. There are people on this site who seem to be profitable, but they have extraordinary passion and drive. I'm retired and just "making art," and pricing in the art world is a whole different animal, that is why I said "whatever the market will bear." When I factor in my overheads, materials, time and depreciation, I am making minus dollars per hour, but boy, am I having fun and leaving a leather legacy.
Exactly. What ever the market will bear.
I completely understand. Mine is a homemade laser (not by me), and I always wonder if it is performing at its best. Thanks for the clarification.
Any problem I've ever had with setting rivets was the result of setting it by hand, and not being able to align the rivet/leather correctly, or applying too little or too much pressure, resulting in poorly set rivets (and snaps) and a lot of frustration. You might consider getting a bench mounted press like the one available here: http://www.campbell-randall.com/product/italian-twist-press-no-2. This machine has allowed me to set rivets perfectly, and at a very reasonable price. It can also be used to set snaps and grommets. Dies are sold separately and can be purchased from other suppliers (like Ohio Travel Bag).
I'm floored. I use a 100-watt CO2 laser, on 5-6 oz. leather (which is 2 mm), and must make multiple passes at 75% and 20 mm per second. So my cutting (I don't cut veg tan) takes me much more time. Do you have any tips for me that might help speed up my production? Slow, or not, I am very happy with the results of this machine.
I experiment with various leather conditioners, typically a beeswax/neatsfoot oil blends, with things like pine pitch, etc. What I've found is that some leathers allow for penetration, while with other leathers the conditioners stay on the surface. You mentioned plant vs. animal fats, and I was reminded of a friend in elementary school who didn't have any neatsfoot oil for his baseball glove, so he ended up using olive oil instead. The olive oil penetrated the leather, but did not reside close enough to the surface to offer much protection, then over time the oil turned rancid, his glove began to smell and look terribly dark and discolored. Not sure if I would be willing to try vegetable oils (or fats).
40W Chinese Laser - Engrave and Cut Leather - Discuss
LatigoAmigo replied to Billy Hell's topic in 3D Printers and Lasers
Very nice. Do you get much personalization business? -
Glad to hear. Do you show your work? -
I have owned my 100-watt CO2 laser for several years now, and am still figuring it out. However, I have had a bit of a breakthrough with this latest bag, which is laser cut and engraved.
