CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. I don't know if they did anything to it.BUT checkout what they did to a Seiko.Not only does it have 13/16" lift it also has square feed.
  2. I recently sold a machine to a customer who wanted a fine looking stitch in English bridles & used a #14 with size #69,it looked great! A size 20 will make too big of a hole & won't look nice.If it isn't real thick leather use size16
  3. Good deal,can't go wrong @ that price!
  4. The 43-5 is a cylinder arm version of the 42-5 they have different shuttles.
  5. Try some #138 in your CB4500 it should w/o much adjustment & be the right size for what your sewing.
  6. The factories are shut down until Feb 28 & then the air planes aren't flying there anymore either.
  7. Curve needle shoe machine BUT I don't know the brand or model#
  8. I've been told that the Polyester thread is made from many short strands,so if you use it where it rubs against something like the inside of a belt it pulls some of the strands off the thread giving a fuzzy look after a while.Nylon doesn't do this since the strands are alot longer & stiffer.
  9. There's 2-screws one in the front & one in the back @ the same place.
  10. No,at this time the tariffs are still in effect & it is 25% now,they started out @15% & added on another 10% later.
  11. Great info & pics ,should helpout a lot of people in the future.
  12. This is one of the many ways it can skip.But it's better to look for things like this before you start turning wrenches. Lower the needlebar all the way down & make sure the spring is pressing against the thread like it should,once in a while a piece of thread can get caught in there & hold it open,sometimes they just get bent & need to be replaced.Also do you have enough pressure so the leather is being held down?
  13. You should be able to sew up to around 20 oz for leather BUT this machine does NOT have needle feed,it has feed dogs with teeth that will mark the bottom of the leather & it also has teeth on the bottom of the feet.But they can be ground off so you won't get feet marks on top.
  14. Standard High speed auto-oiler machine for sewing clothing,draperies & other light material with lightweight thread.
  15. I've had 2-calls in the last week from people that bought one from Tandy & they both want to trade them in.They won't sew heavy enough & are marking the leather.I was nice to them & mentioned we do not have a market for this machine & don't want it on trade.They weren't very happy about it & now are probably upset with me since I won't bail them out.I'm willing to bet in a few more months Tandy will stop selling them.They are better suited for sewing vinyl for upholstery,sails or tarps.
  16. Tony,Yes,I can get the bearing.
  17. Ok,I thought you meant 3-5 mm from the end so I thought it had a short shaft,which some people have tried to use.
  18. It is the one in the back where the rod comes out which has the sliding walking foot adjustment on it,the cam is inside the head on the top shaft & has 2-screws in it to loosen so you can rotate it on the shaft.
  19. You need to get the correct bobbin winder w/a longer shaft.
  20. Sounds like a lot of fun.Yes,the wicks you have will work.On the Singer you have to mill down the top of the hook basket so much that you hit the screw that holds the upper bushing in,if you got a different hook saddle from a Consew or Juki a large bobbin will work w/o any work but you will still have to mill the small bobbin one from either brand.
  21. IDK how many times we tried different bobbins from different suppliers for the 1541 & finally found some that are consistent.The black steel ones seem to be the worst.
  22. Make sure there's no play in the feed cam,there's little screws & you can adjust it with,be sure to unlock them first with the locking screw,if you get them too tight you won't be able to change the stitch length.
  23. I missed this before but that sure is a nice Chrysler the 300's were a great car!Alot faster than my Falcon!My GTO though might be a different story.
  24. If you grab the needlebar & push it front to back is there any play?
  25. I would guess someone had the handwheel off & didn't put it back on the groove where it should be ,easy fix.Loosen the handwheel screws (down in the belt groove) & re-install. Sometimes in this type of machine w/o a walking foot the stitch length will shorten if your sewing leather,put a piece of paper or cardboard & see if it gets longer.
