Treed
Everything posted by Treed
  1. I went to Duncan's and got there gun mold..... I have sold large numbers of holsters for this gun, the 460 Ruger Alaskan, and the Freedom arms guns. Very popular with hunters headed north.
  2. No I don't..... going to order one but just haven't got around to it......email and he should be able to send a picture. Web site Purdy Gear uses it a lot on holsters and belts as a boarder tool
  3. Use the 7-9 unless you want to line it.
  4. Great attention to detail and execution
  5. Great job.....love the hand stitching. I love recreating works of art from the past. The only thing that I notice is the strip that you have at the top to keep shell in is actually a strip that is under the shells to keep them up so that it is easier to get ahold of the shell for removal.... look at the last picture of the original belt with shells in it. Just turn the belt over. Great Job love it
  6. The picture is small and can't tell exactly but it looks like Bob Beards ram curl tool
  7. Great work..... I am the same, just got use to head and round knifes and it is difficult to use anything else. Bobby
  8. I am having a tough time telling anything from the pictures, they are too small. What little I can see I think it is one that was done by a saddle maker for private sale and not done by the military. Need larger pictures to be able to tell anything. Bobby
  9. I took some osb and made a cabinet 4' X 14" X 18" (this was the size of some scraps laying around). Had some old wire shelving from a closet and added it to the cabinet. On the backside I cut a small hole to accept a small ceramic heater with fan and temp controls I had laying around. Put in a thermometer and I can dry between 5 or more holsters at a time depending on there size at 120 to 130 degrees.
  10. That's an Item that you will have to go to someone like Texas Dies to have made.
  11. Just my two cents..... there is no way with that light of leather and the way you have constructed it not to get a pucker. The leather looks to be 2-3 oz. so trying to groove the spine area would be difficult for me to do. The construction for this type of notebook for me would be cut outer leather glue stiffeners to front, back, spine glue to liner glue front pockets on edges glue rear pocket for clipboard on edges sew add rings This will give you a more ridged notebook that will carry the weight of the papers better and keep them in better shape. For a softer notebook if that is what you are going for then cut outer leather glue to liner glue front pockets edges glue rear pocket for clip board edges sew add rings
  12. I do a lot of holsters and knife sheaths that are tooled and formed, the tooling is done before construction. The biggest thing to remember is that you will not get the same degree of forming that you can on a non tooled piece. A tooled project can not receive as much water when you do the forming process on a tooled item. I only use as little as possible, wetting only the inside as much as possible. I let the item dry considerably ( something you have to experiment with) before forming. When forming the item I only try to form a few key areas around the cylinder on revolver and the trigger, auto the trigger and the ejection port if you are forming by hand. I use no tools on a tooled project only my thumbs. This is where a vacuum bag comes in handy if you are doing any number of tooled pieces. Bobby
  13. I usually apply with a piece of sheep skin. Apply light coats at a time with a night or more between coats until I get the affect I want. The biggest problem is that people see one area that may have absorbed more than another area and they try to fix it at this time. Let the leather dry as the driest areas will pull oil from wetter areas and will even out with time. I have had pieces the have had dark oil splotches after oiling that I figured were ruined and through up on the shelf....after a week or more I could not find the splotches..... Don't Get In A Hurry
  14. During the years of the black powder guns the gun owners wore a belt with usually one holster, one knife and a cartridge box (this was for paper cartridges). After the advent of metallic cartridges and very few pockets on clothing they filled the belts up with cartridge loops. The cartridge loops didn't allow the slim belt loops of the slim jim holsters to fit over the filled loops. The Mexican loop holster was result as the size of the belt loop now expanded and now provided more secure way to fasten the holster to the belt. The fastening of the holster to the flap with one, two or three loop slots is mostly style but the more loops on the body the more secure the holster body to the flap. This allowed the moving and removing of the holster with out taking the holster apart
  15. Great looking holster.... How is the security being an outdoor holster without a strap for the gun? These chest holsters are the greatest for outdoor use, I have sold over thirty this month at sportsman show
  16. you hit it out of the ball park
  17. Great work.... I wonder also where you would be today.....keep with it you have real talent
  18. Great job...... a couple suggestions for the next time. The cut lines for the branches pop more than the stamped oak leaves and acorns and draws the eyes. I like to stamp the leaves and acorns, cut the branches and then with a small beveler bevel everything. This sounds like work but the benefits are worth it. It will really tie everything together and make them stand out. Try it on some scrap and also study casing leather. Keep up the great work an look forward to seeing some more of your work.
  19. Here is one that I made from a pattern out of the Al Stolhman's books. They are great for a lot of the early styles covering the move from single to double action and work great with the heaver guns and heavy use.
  20. Take your draw gauge and cut a long strip to width. Take the long strip and cut it up into the lengths you need. Place cuts that you need and place on zipper. This method you can cut different lengths and widths to fit any zipper and not have to have multiple dies. You can cut a dozen or more in the time and effort it would take to cut five with the press.
  21. What I do is find a small border tool, smaller than the one used on the outside of the basket and go around your makers mark. I don't have access to my pictures but will try to post one latter.
  22. Some Great classic old styles and you nailed it. Great job
  23. That's simple enough, never used the liquid acrylic antique will have to try it. Thanks Bobby
  24. I know what Fullmetalsam means. I have been looking and no one makes the old traditional basket stamp. The lines coming out of the new stamps are very uniform and give a very flat appearance between the stamping. The older ones the lines ran longer and were somewhat tapered this gives more of a rounded shape to the area between the stamps and a different feel when you run your hand over the stamping. I have been going to contact Barry or someone to custom order a more traditional stamp but have not done it yet. Bobby
