Stetson912
Everything posted by Stetson912
  1. Another idea, use the football pieces as an inlay on the body panel. You'd make a regular bag and can cut panels like usual and just inlay the football pieces where you like.
  2. Nice. I was going to say, kinda a waste to stitch one layer by hand for decoration haha. A machine tho, makes it worth it. Looks good
  3. That's a neat idea. Requires a lot of thinking and posses a lot of what ifs. For instance. What if... Ahem... You use the football panels for the side of the bag and just but them up best you can and use other leather to fill in the gaps between them? Or, what if... You use some vertically and where they have the gap in between use a panel horizontally? It's hard to explain in words. I hope you understand what I'm getting at haha
  4. Very cool. Them just one layer of leather or two? Machine stitched?
  5. I'd keep the larger pieces for journals and the like if you can. But smaller pieces you could make needle cases, coasters, any number of keychains(you can stamp initials in it too if you have alphabet stamps), coin purses, mutt mentioned the phone stand keychain(there's a pattern for it on here somewhere), I've seen cat toys made too (little pouch to put some cat nip in and a long tail) zipper pulls and purse dangles, small bags or pouches with fringe, inlay/overlay work, card wallets(very minimalist), braided items if you can cut lace, bracelets and cuffs (mystery braid), headphone wraps, leather conchos and buttons, lace for bleed knots... That's all I got at the moment haha
  6. Thanks Bob, I'm a subscriber to the leather Crafters and saddlers journal but just in the past year. I'll try and find your post on it here. Thanks.
  7. Wow, really stunning. Had the same mesmerizing effect(if not more so) as a well stamped basket weave. Simple but elegant (simple being used loosely here) I've been back and forth on a lacing chisel because I didn't know if I should get an angled or straight one, but I like the look of the angled one here so, I've made up my mind haha. Also, on the card pockets, is there something on the backside keeping the cards from slipping to the bottom? Or just two slots cut in the pocket leather?
  8. @billybopp thanks for the input. I don't know much about wood so, good to hear the reasons for and against. Thanks
  9. @DJole I was going to use a potentiometer but didn't have one. So I just did this. You could always add one in later haha. A rheostat will work too @WoodysWorkshop I can't think of a reason why pine wouldn't work. I'm pretty sure that's all this little drawer handle is.
  10. @northmount that is true. Perhaps with some clever gear ratio you can downspeed the output rpm? Just a thought. @alpha2, it was a fun little project. It is a good little motor for it too. Seems to fit the role just right. The motor new I believ is around $30 but, I happened to get the scooters free. Never know what you'll find at yard sales too.
  11. I'd like to know how you did the lining
  12. Yeah I'm sure that would work. Old vacuums have motors you can use too. They are noisier but it'll work. Washing machines and treadmills do too. Some of those may be more complicated and ahem... "Over powered" haha. Like there is such a thing
  13. Thanks! I'm sure it can be done with a variety of motors salvaged from lots of different things. I wanted a simple light weight quiet burnisher that I can turn off and on. And that's all this is haha. Works for what I need. Imade a vacuum press bag as well, just haven't been able to find the fittings too set up the pump to test it yet haha.
  14. Before I start, I need to mention that this project deals with simple circuitry/wiring of a DC motor. Don't do this if you don't know how or understand the risks involved. With that said I made a burnisher for free! My neibor gave me two electric scooters that 'dont hold a charge' Soo, I gutted one. After taking it apart I realized that the motor for these scooters is a good little motor. It's a 24v permanent magnet motor that has a rated rpm of 2500-3000 with no load on the motor and ton of torque. Unfortunately the batteries were not good so no power for the motor.. or so I thought Wheels get to spinnin' and I realized I had a power supply to an old laptop... The charger outputs a 19v 4.78A dc current. I cut the end of the laptop charger off and wired it to the on off switch I salvaged from the scooter. Then wired the switch to the motor and viola! Burnisher motor with switch. I also recommend covering the connections with electrical tape or wire nuts or shrink wrap. In my case, I used hot glue, because it's what I had... Don't judge me! Hehe The motor works just fine. It's rated for 24v DC and at 19v (from the laptop charger) it runs fast enough for my needs. The actual burnisher is attached to the shaft by smashing a nut into a slightly small round hole. In the photos I repurposed a wooden drawer knob. I used a simple chisel to add another groove and also evened out the groove that was already there. So it has 2 grooves. All that's left is mounting it to something I can clamp down to the table. While it isn't the best thing in the world, it does work. It takes up minimal space, and is very light weight too. All in all, I'm happy with it. I'm posting this because I know people like me can't afford much. And sometimes you gotta make due. You don't need super fancy mega spinomatic 9000 burnisher models out there to get the job done (although if I could buy one I would) I hope this helps people out. Just remember to do your research and be careful with the wiring/soldering. I don't want people getting hurt or fried out there. The last picture is a burnish sample. It was done with just water and a little saddle soap and dried. No dye or wax or anything. It was a quick test so it isn't the best, just to show it works. Cheers and happy making!
  15. Lol, I haven't tried mop n glo yet but people swear by it. I'll give it a try one day. I have used resolene over feibings before. It worked well enough lol
  16. Resoline is acrylic based too. Idk why I never thought of acrylic paint as a resist until now haha. I've heard people using resolene for a resist in places. And it says right on the bottle "ACRYLIC" resolene hahaha. Guess I'm just a bit slow on the uptake aren't I haha.
  17. It'll be nice when it ages. I like the blonde color of fresh veg tan, but something magical happens when it patinas and ages
  18. @JD62 the company is called ks blade punch. They make hole punches and other tools as well as these irons. I think they have diamond chisels too but don't quote me on that. The unique benefit is that each tooth is made separately and inserted into the head of the tool individually. This allows you to polish and sharpen them (if need be) easier as well as replace any teeth that break or get damaged somehow. Obviously, a standard designed iron like the Blanchard's and such... Well they are very expensive and if you break a tooth you have to replace the entire tool. Not fun. Here's the website for is tool for further research... Or drooling... http://ksbladepunch.com/product/pricking-irons Also, Nigel Armitage's I believe reviewed the ks blade irons as well.
  19. How do you like the ks blade irons? I'm looking for a good set. I like that the teeth are replaceable.
  20. Just found buckle guy sells English bridle strips. Wickett and Craig, Hermann oak and Clayton's . Rough prices..Wickett and Craig is $13 Hermann oak is $17 and Clayton's is $27 all 8-10 some 10-12 oz 55"-60" length.
  21. I still haven't seen this 'picture' of what my coworker wants. It sounds like it is an h style or step in harness. And I do have a pattern for an h style another member pmed me. She said it was a simple harness so, we will see.
  22. I'm with you on that too @Mattsbagger which is why I'd like to get a bend or back or something. However... Since I can't reasonably charge that... Sadly hehe, strapping does sound like a great idea. Thanks for the suggestions.
  23. You know, I have some veg tan light saddle skirting I totally forgot about. It's a total pita to work and cut but I have it. That's plenty strong for this right? I wouldn't think a harness for an Akita would damage easy made out of super stiff saddle skirting. Ah but bridle or latigo would be so much better. I wonder how much a bend from them runs? Might have to email em if it gets serious haha.
  24. Yeah that's part of my problem. I just don't have the money for it. I don't sell much. So I don't have use for a large stock of leather. I don't feel right charging for the whole side or back or double shoulder. I can use lighter weight better than heavier weight too. I may just have to deny the job :/
  25. Awesome. Here do you get your bridle?
