Silverd
Everything posted by Silverd
Everything you are saying makes sense. I have a LAndis 5 in 1 with a skiver and it also does as you describe. Hate the Techsew idea. Ive had a problem with them since the start and I started with them so there you go. But I can deal with Campbell and will give them a call. My surprise is that there is so little information about the details of a bell skiver that it would be very easy to make a wrong decision. Cobra has been really pushing the NP-10 top and bottom feed and that would be fine if I were working heavy leather for saddles etc...but I have been clear to them that my work is light...3-4 oz herman oak...Bag making which I guess may not be understood as to the requirements. But seeing the various presser feet that Nipppy demonstrates in the reference video is exactly what I can use. Maybe not all of the variations but I would buy them all if I had to. I have only seen one presser foot intended to replace the feed roller on a top feed machine...not that more could not be designed and machined but that's not my objective. Thank you for your input. I think based on what you told me I will add a Vacuum feature to my bottom feed skiver criteria. Silverd
The SK-4 skiving machine looks great! can you tell me how many different types of presser feet are available for this machine? I see only one on your accessories page,
Thanks!
Don
The Video above that Jimi posted demonstrates what Nippy can provide as I understand it. The quote for a NP-S1 machine included three of the feet in the video. I don't have pricing from them as of yet for additional feet since I have not submitted my RFQ with them. I'll share once I receive. Interestingly; I did see a photo of a Consew skiver ( something -4 model) on Craigs list a while back that included at least 15 different presser feet seller was including. So a full range of feet are apparently available from somebody... I've heard that running a vacuum is helpful as well but I cant identify which machine models will accept a vac. Also: I have often read that a vac is only needed for production runs but I'm skeptical of anything I here at this point. Most people can't / don't articulate effectively about technical topics. Why do you suggest a vacuum system is helpful? Silverd http://www.nippy.jp/ Link to the Nippy site
Agree the other companies carry good machines but how many of them support with 19 unique presser feet? I'm actually in communication with Nippy and they appear to have someone at their end who reads and writes English. They are quoting NP-S1 machine and four standard feet with shipping for about $2600.00 and will provide pricing for additional feet once I provide them with a list. I'm compiling a list based on the factory video from Jimi. I also talked with Dave at Cobra in Ontario CA yesterday and asked him to provide a list of the presser feet they can supply. Obviously buying from a USA based Co is the simplest. Having a Japanese made OEM machine in the stable is certainly something to consider as well. I recently purchased a Seiko 50mm cylinder arm sewing machine direct from Seiko and it is a beautifully made piece of equipment. It replaces a similar clone machine that I never could get to work very well. Dont know if it was just me or the fact that it was not cloned well...and that is my point. When you"re having troubles, and you suspect there may be design issues or workmanship issues with your clone, its more difficult to trouble shoot in my opinion. Basically it comes down to this...You pay for what you get. Silverd
Wow! Fantastic videos. Bottom feed only machines appear to be capable of everything I would ever use them for. Ive been in contact with the Nippy folks. Very difficult to communicate with however. I did get them to send me a quote for their NP-201 machine which they claim is the export model...But its not clear what the differences are between this and the 210 and 211. And I absolutely agree that the various presser feet would be essential to the full range of skiving that one could use. Really great info. So how does one order some or all of the presser feet from these guys. From what I can tell they do not have USA representation. Silverd
Hello Can anyone explain why a top and bottom feed skiver is better than a bottom feed only? Can a top and bottom feed skiver do everything that a bottom feed only skiver can do...but more? If a Leatherworker.net Member is skiving mostly higher temper Herman Oak 3-4oz (1-2mm) leather...can this work be done on a Top and Bottom Feed skiver or should this individual use a bottom feed only skiver. There is not one sewing machine that does everything...Is this also true for Skiving machines? Do I need both? Your assistance to the questions above will assist me in deciding on which machine to purchase and will ultimately determine the success of my business and the health of my sanity! Many Thanks in advance. Silverd
Could you verify this blade setup on my Landis Model 30?
Silverd replied to SDeaconandSon's topic in Leather Machinery
looks great! Manual is available on line and it does a pretty good job of explaining how to set the blade. There are stops which are intended to catch the blade at each side. They also tend to damage the blade at each end and then will not position it accurately. So front to back position of the blade should be done carefully. I'm not sure it is the most critical alignment aspect on this machine however. The blade gap between the bottom roller is however. It should be about 0.060" or the thickness of a credit card. The gap is set by making adjustments to the hex nuts that are below it in the frame. They are in reaction to the big coil springs which load the lower roller into the leather as it travels through the blade. Those sliding components need to work freely in the splitter frame. Silverd -
Cobra sells table only with servo motor, controller etc. Silverd
For your files and information. I recently purchased a Seiko BSC-8BL 50mm dia Cylinder arm with full compound feed, on the fly presser foot height adjustment and M size bobbin. Machine is compatible with Singer 111 system presser feet and 135-17 needle system. I'm currently trying to fit a roller guide to it although Seiko does offer this option for about $350.00 which amounts to a common drop down style guide with an adaptor plate. Do you think using OEM bobbin cases is worth the added expense? Silverd
You are likely correct. However. I did find that Cobra sells just tables. The one I would want will be about 500 delivered...no motor or controller which I have already. I purchased the machine through Hoffman Brothers in Ill and I have also reached out to these folks. Silverd
- 3 replies
- table
- sewing table
- (and 3 more)
Hello Fellow Leather Workers HELP!!! I am in need of a sewing table for my latest cylinder arm sewing machine purchased from Seiko Co. It's a rather heavy beast even though it only sews small stuff. BSC-8BL. Any one know where I can buy one like this? Many thanks! Silverd
- 3 replies
- table
- sewing table
- (and 3 more)
Thank you! Eli and I are in regular contact with each other. I'm actually buying a Seiko machine through him and I have done custom machine work to support his Landis 16 refurbishment business as well as having Person presser feet investment cast in China. I thought he made a sitting level table for the 16 but he apparently uses the original stand up base. I can continue to do that but was hoping he or someone had a custom made bench version. Not sure if a 441 stand would be suitable. May have to design one myself and have it fabricated. Anyone interested in participating in that project? Silverd
Hi I'm looking to remount my Landis 16 head onto a sitting table. Has anyone an example they can show me. I like the idea of retaining the swing out oil drip tray...very cool feature. It may require custom design and fabrication...unless a standard cylinder arm table is up to the task or if someone has plans or one for sale. Silverd
Mid Century Modern Clutch Project
Silverd replied to Silverd's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
175 is low but if the selling continues of the early versions then ill feel better about raising the price a bit. I also have Wrist strap and Shoulder strap kits that can be purchased in addition if the customer wants. Thank you for your input Silverd -
Started this project last year as my first Clutch for the shop I sell out of in Santa Barbara CA. During the C19 shut down I focused on completing a short run of 4 bags of which I've been able to salvage three. The 1mm Herman Oak outer as well as all intetnal pockets are lined with .5mm Italian Lamb skin in black or in one case red. The bag features a front zippered pocket, a magnetic flap fastened center pocket and a 3 credit card holder on the back inside wall. End gusets are nylon lined and feature eyelets or D rings to accept an optional wrist or shoulder strap. Selling starts at $175.00. I've produced 10 like these and the design continues to evolve through interviews with my Test Drive Staff who carry, use and report on what they find wrong or in rare instances what they find right! My instructor suggests I start with big and work small as this is more typically an easier strategy for successful beginning bag making. Now he tells me. I designed the 12 patterns by hand and not including thread combine 22 separate components that takes me about 24 hours each to assemble. Not a big money maker. Most of the stitching is done using #69 thread on a Juki 1541S or a Cowboy 335 but I also use a Techsew 5100 for sewing the center pocket into the gusset folds with 138.
Kydex, yes I was made aware of this material and it does seem to be the material of choice for military, police and serious hunter types. I was hoping to use a sewable material but I'll present options to my client from the blade forums as you suggest and if he selects something from kydex, well I'll have to come up on the learning curve. It's not unlike pulling cased leather over a form once it's warmed up a bit...trim, rivet top to bottom. What could possibly go wrong! Many thanks! Silverd That's a pretty cool idea! Silverd
- 15 replies
- synthetic
- knife sheath
(and 2 more)
I like your idea of Cordura. I had a bouyency compensator used when scuba diving, made of Cordura and it held up well for many years. Thank you for the suggestion Silverd
- 15 replies
- synthetic
- knife sheath
(and 2 more)
Oxnard is located about 65 miles N. of Los Angeles BTW
I'm in Oxnard and have been making custom English bridles and custom halters for a small group of customers. My shop is well facilitated for strap work, nose band pad making, buckles and machine and hand stitching where needed. Silverd
I'm looking for a supplier of small diameter rivets for leather of about 3/16" to 1/4" thickness. Also shorter ones for 1/8" thickness. Something with a clean head and finished crimp. Application is for a purse to support high stress points where several layers meet. I'd even consider paying for a custom product. Silverd
Yes, a little too big is right although the 16 will work for a lot of the items you listed. I would suggest a medium size cylinder arm with a flat bed attachment. There are many of them to choose from and you will want to do some research before pulling the trigger. Silverd
Machine is currently not available for sale. Ordered a new Seiko BSC-8BL from Japan due to arrive in 5 weeks. Once that machine is on line I'll repost should anyone still be interested. Silver
- 9 replies
- barely used
- leather stitcher
(and 1 more)
Eli will not usually answer his phone but will call you back if you leave a message. He does not have access to email or internet so you will need to resolve the issues through conversation. Its not the best situation but Eli is a great guy and very knowledgeable through a wide spectrum of machines and especially the Landis 16. I purchased one myself a couple of years back with his help but I cant comment as to the exact problem you are experiencing. Silverd
Good points re using well conditioned leather. I'm not sure his exact intentions; certainly not swimming with the knife though. The knife he wants the sheath for I believe is military style carbon steel with plastic handle. I made him a sheath for it already albeit a more decorative style. Thank you for the thoughtful suggestions Silver
- 15 replies
- synthetic
- knife sheath
(and 2 more)
