ArkieNewbie
Everything posted by ArkieNewbie
I run the thread out of my bobbin on my Class 26 clockwise and don't have any issues. If you run it out counter clockwise it will add more tension to the thread because of the sharp turn it has to make. How many times do you have your thread passed through the post on top of the machine? Another thing to look for is if your thread is getting wrapped around anything or if it is getting caught on itself coming off the spool. I had a spool that was apparently spliced together and the thread kept getting caught on that splice knot and when it did BOOM, knots sitting on top. This is a good video. https://youtu.be/SyM-13KFIKc
WOW!! That is incredible!! I us almost exclusively fountain pens for my writing and love anything that has to do with them!
Looking for: High Quality Copper Rivet and Burr Setter.
ArkieNewbie replied to SpruceMoose's topic in Leather Tools
Three whacks is all I do with the domer to get this finish. Yes, it's a little annoying to have to use two different tools but I do like the results. -
I use this to dome brass and copper rivets after driving the burr down with a cheap setter from SLC. This $13 domer does such a great job and in my opinion leaves a much better finish that the domer on the SLC setter. https://www.centaurforge.com/Nordic-Forge-Rivet-Set-Punch-with-Concave-Face/productinfo/305/ -
Sewing Machine Thread Brand and Type
ArkieNewbie replied to rodneyv's topic in Leather Sewing Machines
WOW! This is awesome to see!! The folks at SLC are the best! -
I have had my Class 26 for about a month now. You're going to love it!!!!! It has definitely been a time saver though there has been a learning curve on somethings I make. I am following this topic, I'm curious about thread too. I bought some stuff off Amazon and it has been good so far, haven't had any problems so far but I'm sure there is much better thread out there. The black nylon thread that Leather Machine Co. sent with the machine is my favorite! -
Laser cutting...char and ash..what to do?
ArkieNewbie replied to BDAZ's topic in 3D Printers and Lasers
I've had issues with vegtan holding onto the char too when I cut my hat patches. I have resorted to cleaning each one with saddle soap and that usually does the trick. Some are more stubborn than others though. You could try covering the surface with blue painter's tape . In my experience the laser doesn't care that its there, it peels off cleanly with no residue left behind, and I haven't had any issues with char. The only place where the painter's tape messes me up is if I'm engraving at the same time. To engrave through the takes a little extra power. -
The electricity cost wouldn't even cross my mind! I have run my Ender 3 Max, resin printer, and two diode lasers at the same time and have not noticed any difference in my electric bills. Will it work? My best answer is, probably. I would probably print them in ABS to be sure they would hold up to repeated use. PLA tends to be pretty brittle. The other cost of printing, the filament, is not really going to be an issue either. A 1KG roll of Hatchbox, my favorite brand, is about $25. That roll should last your through several models. The files are the big issue. I have spent a lot of time looking and have found some files, just not good ones. The problem I have encountered is ensuring they are to 100% scale of the original gun. The worst thing is spending 8-10 hours on a print just to realize the model is too small. If someone here has a good source for files I would love to have that as well.
Thanks so much! It is quite satisfying! And the satisfying feel and slight creak of the horse hide helps too!
Thanks! Well first off, they weren't real leather. The whole bag is bonded leather I believe and they were made as three separate parts. The end of the main part of the handle was stitched to a separate piece that went around the ring. With that construction they were dependent on the strength of the stitch holding them in. Once that failed it was all down hill from there. Thanks! Those handles will far outlast the rest of the bag haha Thanks! I appreciate it! I hope so. He's out of town until next Friday so now I have to spend a whole week hoping he will. haha
I got a call from a local dentist about his duffle bag that he uses for his flight gear that he needed repaired. He mentioned on the phone that the handles were in rough shape but I didn't think it would be THIS bad. As you can see he had one of them held on with some aluminum wire!! I remade the handles and the retainer strap. I used a CXL horse but strip I had bought a while back from Maverick Leather. This stuff was AWESOME to work with. Nice and flexible and glued up GREAT! What do y'all think?
You sure you're not really living in a sideways alternate dimension where your shop it laid over on its side?
Laser cutting and engraving Chrome Tan..What Respirator UPDATE
Agreed. I laser cut and engrave chrome tan every day and I t t t t totally fine! But seriously, I agree with you. The smoke can irritate you lungs but, what smoke doesn't?? -
I keep a beautiful wallet on my workbench as a reminder. While this wallet may LOOK really good, it is too small and cards won't fit in it. This wallet too, like your projects, took a flight across my workshop.
What is this kind of buckle called, and where to get it?
ArkieNewbie replied to MtlBiker's topic in Hardware and Accessories
I bought some of these, https://www.amazon.com/Shackle-Release-Rigging-Sailing-Stainless/dp/B08RYGWHML/ref=sr_1_5?keywords=snap+shackle&qid=1687524460&sr=8-5 and still have not thought up a use fo them@ -
I'm going to have to look into that!! Engraved these last night. Did this on my Atomstack A30 Pro. That thing is a beast!
- 21 replies
I've had the smearing too. Especially on oil tan patches. If that happens I just follow up with some saddle soap. Cleans it right up.
- 21 replies
I have 3, all three are diode lasers. I have a 30W, 24W, and a 5.5W. The 5.5W will not cut well but the other two are like a hot knife through butter!
- 21 replies
Yes probably so. The heat from the laser will slightly darken the leather around it. If you lower your power or increase speed it might lessen it. You're correct. I dyed and then lasered. I always make sure my dye is good and dry, cause you know how alcohol likes to catch on fire. Then after engraving I clean its up with a wet sponge to remove soot, let it dry and on that particular patch I use Leather Balm with Atom Wax. Right now I am hand stitching them on. Takes about 10-15 minutes depending on the hat, whether structured or unstructured. BUT, and that's a BIG but, I have a brand new Cobra Class 26 being delivered this week! It's going to be a GAME CHANGER!! So I guess in short, I apply color first, and then top coat after its done. Thanks! I appreciate it! Keep adjusting your settings and you'll get the results you're looking for. Thanks!! I really like the ear tag and that mallard is by FAR my favorite design! SO much detail in it. Thanks, Dwight! Yeah, stitching them on can get tricky!
- 21 replies
I've been making these hats and selling them at our local farmers market and folks have loved them! Some of y'all may not appreciate the laser engraving, and that's ok. It gives me the ability to do designs and detail I wouldn't be able to achieve otherwise. Hope y'all like them!
- 21 replies
Just sent you a DM I am VERY interested in this machine!
1911 Mexican Loop
ArkieNewbie replied to JWheeler331's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Beautiful holster! That basket weave looks amazing on that black leather! -
WOW! That is classy! Very well done!
Jerk Steiner Saddle
ArkieNewbie replied to rktaylor's topic in Saddle Identification, Restoration & Repair
Based on the dates in the obituary I found it seems that this may have been one of his early saddles so you're probably right, he didn't have a makers mark yet.
