MarshalWill
Everything posted by MarshalWill
  1. Very nice. That antique finish really makes the stamping stand out.
  2. Looks good. Nice even BW. That had to be fun to do.
  3. Thanks. I wasn't familiar with that design aspect.
  4. Beautiful tooling. Looks good. Very nice work. What function does the hole in the middle of the strap fulfill?
  5. I like it, it's a good-looking design. Maybe not pockets but a divider or two across between the stitch lines. Nice work.
  6. You're getting some nice, even dye jobs there. I like to use Fiebings or Lincoln dyes that can be thinned with alcohol. I then spray the piece with alcohol first so the dye takes more evenly. I also have never heard of using hot water. I've heard of people using plain water but not hot water. The whole idea is to slow down the dye from soaking in too fast and getting darker spots in the finish. The exception to that is if I want to get a patchy finish, then I don't use alcohol first and dab it on with a cotton dauber getting it as textured as I want.
  7. You made a very cool case for a much needed item. Well done!
  8. Not only is it a clean looking design but it's versatile. all around a good design. Nice looking, too. This gets a hearty thumbs-up!
  9. Those look good. I particularly like you oval one. Beautiful!
  10. That looks like a nice, stout holster. Very appropriate for a Ruger. Good work.
  11. Cool. It's nice that the stamp is made from square stock. It will make it easier to line it up, assuming they made it aligned with one of the flat sides.
  12. That's by far the best looking farrier's apron I've ever seen. Beautiful work.
  13. That one's only 2-3/4" across, just the right size. Besides, those blades don't getcha much once you get used to them. Getting used to them can be a challenge, though...
  14. Looks good. I like the way it fits under the welt.
  15. Good looking tote. If you want one to hold a shape, you would have to wet mold it before assembly or put stitch lines to hold corners.
  16. What sizes exactly? I would probably order 1" and 1-1/2" or 1-3/4"
  17. Looking good! i like leather and wood together. Nice work.
  18. Outstanding! I'll bet she was thrilled.
  19. Thanks. It looks good.
  20. I look forward to seeing your stamp design. Post a photo shen you get it.
  21. What rivet setting tool is that? It makes a great stamp.
  22. 5mm is a good choice. It's close to 5 stitches per inch, which I like for things like this.
  23. Looks very good. Clean and uncomplicated. Bills in the clip and ID or cards in the sides. Thumbs-up to this one. The only thing I would have done different is to run the stitching all the way around so there's no break in it at the top and bottom of the fold. That's not right or wrong, merely preference. It's great the way it is. I like the oval windows and the basket weave on it.
  24. Mighty fine work. Thumbs-up!
  25. That new one looks great, too.
