Please help, thread is too tight when pass bobbin
Wizcrafts replied to Orrrmygod's topic in Leather Sewing Machines
Look at the bed of the machine, to the right of the sliding bobbin cover plate. There should be a push button barely sticking out of the flat bed, somewhere in line with the hook shaft. Use a finger to push it down as you crank the hand wheel. Once it finds the correct position it will click in and drive the (cleared) hook again. The mechanism is under the bed, but the button is accessed from the top. -
If the hook stopped turning it's because you popped a safety clutch with the thread jam. You will have to use tweezers to pull out whatever thread is inside the hook. Then once cleared, find a button on the bed of the machine, hold it down and rotate the hand wheel until the clutch tang re-engages the hook drive shaft. -
And so another Hobbit learns a lesson.
You are attacking a long time member who is also a reputable dealer in Australia. Don't do that again. Drop it now.
- 39 replies
- able290
- chinese shoe patcher
(and 1 more)
I use titanium coated needles in all of the machines that accept systems DBx1/16x257 and 135x16. They cost about $2 more per pack of 10 and are less likely to stick in the material from heat or basting tape.
Looking for first Heavy Duty Machine
Wizcrafts replied to kbarker's topic in Leather Sewing Machines
You're about to encounter the classic what machine can do it all conundrum. The answer is none. You already have a machine type for medium thicknesses with #138 thread. To sew thicker, and/or with heavier thread, you will need a substantially heavier duty machine. This class of machine is sometimes called a harness stitcher, because that's what they were originally designed to sew (as well as thick buffing wheels. There are several machine styles in this category. They are... GA5-1 style, based on/cloned from the Singer 45k models. These are bottom feed only machines that are usually setup to sew between 7/16 and 1/2 inch of leather. The teeth really dig in hard on the bottom. They are best used with thread sizes 138 through 346. Your least expensive option, they sell for between $1000 and $1400. Juki TSC-441 and clones. These machines have triple feed and can sew at least 3/4 inch, with Cowboy, Cobra and Techsew models rated at 7/8. The aforementioned clones have smooth feed dogs. The original Juki did not, but may now have it as an option. A Juki 441 will cost you about $6,000, while the clones go for the mid 2ks through lower 3ks. Cowboy CB3200. This machine has triple feed, a smooth feed dog, sews up to 1/2 inch and can be tweaked for 5/8 inch by giving up the very bottom. It uses the same needles as the bigger brothers from Cowboy and thread from #138 through 415. They sell for $1900 right now. Adler 205-370/374. These machines (discontinued by Adler) sew 3/4 inch and run smoother than the Juki and its clones. The 374 subclass has a smooth feed dog. They were selling for between $6500 and $7,000 until the end. The new Adler 969 ECO. It sews almost an inch of leather and has a built in motor. They are sold by Weaver Leather and cost about $10,000, more or less. Campbell-Randall Lockstitch machines have a needle and awl and produce an awesome stitch that looks great on both sides. They sew 3/4 inch out of the box, with higher lift options available. They can use linen or bonded polyester thread, from 3 cord through 7 or 8 cord (~#138 through #556 bonded), with the proper needle and awl combination. There is a learning curve and they are very expensive (over 6k). Sold in Texas. Union Lockstitch machine, also sole by Campbell-Randall company in Texas. This is a high speed needle and awl harness stitcher that sews 3/4 inch. Handles the same thread types and sizes as the Campbell-Randall. A little less expensive the the CR Lockstitch (~5k). -
If you have a lube pot on top of your machine, buy some liquid silicon lube and run the top thread through it. Most industrial sewing machine dealers have quarts in stock.
Adler Chandler model 190 - thoughts - experience?
Wizcrafts replied to plinkercases's topic in Leather Sewing Machines
You could ask the seller if they could sew a 1/2 inch stack of leather with the heaviest thread and matching needle they have, at the maximum stitch length, sending you a photo of the results. -
This is a case of bring your own stack of leather and see if it sews that thickness and what the maximum stitch length is at that thickness. -
All of the class 153 machines are rated at #138 thread, top and bottom. The stitch length depends on the type of stitch length adjuster used in that particular machine and how you set it up. My Singer class 111 walking foot machines have a threaded rod and knob on the back of the hand wheel. The maximum stitch length is about 4 to the inch. The later model 111w155 was able to eek out 3.5 spi, using a different stitch length system. The Singer 153 uses a standard G size bobbin that does not hold nearly as much #138 thread as newer M style bobbin machines do.
What you have there is a Union Lockstitch machine. I've owned two of them over the years. They are different from Randall Lockstitch machines (now called Campbell-Randall Lockstitch), like apples and oranges.
Search Leatherworker.net for Adler 105-64. There should be a few discussions about the machine and its capacities. -
Cowboy 4500 Won't Stop. Servo Problem?
Wizcrafts replied to greyleatherco's topic in Leather Sewing Machines
That's a good thing! They really got these motors right compared to the old push button styles. BTW: Did you change the image file in your signature? The usual banner is missing, leaving only a link to your website. The missing file is: kovar.gif- 13 replies
- cowboy 4500
- cb4500
(and 3 more)
It looks like a clone of an Adler 105-64 -
Pressure foot issues with Cowboy 3200
Wizcrafts replied to TheHollerLW's topic in Leather Sewing Machines
Try swapping out the pressure springs for lighter/softer work. You don't need the extra heavy coils until you sew stacks of hard leather. It only takes a minute to unscrew the pressure screw. -
The OP already tried backing off the foot pressure, to no avail. Also, there is no separate pressure screw adjustment for the inside foot. Both feet are adjusted together with a big threaded cap screw on top of the machine head. -
We can add this to our knowledge base of quick fixes for mystery problems- 13 replies
- cowboy 4500
- cb4500
(and 3 more)
Let us know how this turns out for you.- 13 replies
- cowboy 4500
- cb4500
(and 3 more)
There is a spring inside that motor that is supposed to lift the lever all the way up. Something happened to that spring. You can call one of the Cowboy dealers for assistance with your motor. Your closest dealer is Solar Leather in Texas, then in Toledo Industrial Sewing Machines in Toledo, Ohio..- 13 replies
- cowboy 4500
- cb4500
(and 3 more)
Yes, that is a standard compound (triple) feed walking foot machine, good for all types of upholstery, belts, wallets, pouches, gabs, etc. It can sew up to 3/8 inch with #138 bonded thread.
Open up the motor end cap and see if something is binding or the brake cork is not engaging with the lever up.- 13 replies
- cowboy 4500
- cb4500
(and 3 more)
See if there is a return spring on the motor control arm that pulls it up. Tighten that spring. Otherwise, you may have bent the plastic control arm. The bend would be obvious. Try straightening it out. Also, make sure there is slack in the chain from the motor to the pedal.- 13 replies
- cowboy 4500
- cb4500
(and 3 more)
Thread stuck to bobbin when pull out the work
Use the bottom stop bracket to set the throw of the spring. The thread should remain taut until the needle has penetrated the material. The spring tension should be just enough to hold the thread as the take-up lever starts its downward stroke. The spring tension must not override the main tension disks. -
The thread should be taut until the needle meets the top of the fabric. From there it depends on the material. I usually keep the thread taut until pickoff time.
Rotate the hand wheel a little more to clear the thread from the shuttle. Also, it looks like the thread is getting caught on the tab on the bobbin case. Adjust your check spring to leave more slack in the top thread. It should go around the bobbin case and shuttle without binding, snapping or getting hung up. Your last photo doesn't show how you have threaded around your check spring assembly.
