Set the stitch lever to the zero forward/backward movement position. Rotate the hand wheel until the tip of the needle reaches the top of the feed dog. The tip of the needle and bottom of the inside foot should meet the top of the feed dog together. If the inside foot does not reach the feed dog with the needle, loosen the big bolt on the back of the left end of the head, which controls the position of the inside foot vs the needle. Lift or lower the inside foot to match the needle at the feed dog then tighten the big bolt on the back then tighten down the big bolt. If the outer foot is not all the way down now, remove the faceplate from the head. Loosen the presser foot bar screws and move it down so the outer feet are solidly touching the throat plate, with the inside foot and needle resting at the top of the feed dog.. Make sure the presser foot is facing straight forward, then tighten the screws on the presser bar. Rotate the wheel to lower the needle all the way to the bottom of its stroke. The inside foot should have pushed the outside foot up. You can change the amount of lift of the inside and outside feet by moving the crank coming out the middle back up or down in the curved slot on the shaft on the housing on the back. The big bolt I referred to earlier is on the left side of that housing where the curved slot is on the right, as seen from the front of the machine. These instructions should get the outside foot lifting as the inside foot moves below the throat plate, on the feed dog. This is how I balance feet of different heights when mounted.
Puritan chainstitch machines are used where the bottom thread is not visible and is covered/protected by a layer of leather, wood, cloth, or padding. You find this machine's stitching on rifle cases, briefcases, golf bags, boots and tall shoes (e.g., RedWing boots) and some luggage. Puritan machines are needle and awl machines with a jump foot. When these machines were first produced they used linen thread run through heated bees wax in a wax pot on top. Nowadays people use bonded thread in Puritan stitchers. Most Puritan stitchers can sew up to 3/4 inch of stacked/mixed material. Thicker stacks call for larger needles and awls and thicker thread.
I discovered that opening your "docx" file requires a newer version of Microsoft Word than I or many other members have. Furthermore, the compatibility pack download is no longer available. Unless a member has a new version of MS Office, the job description cannot be opened. It might be a good idea to create a version in an open source program that doesn't require paid subscriptions to open the file. Hint: PDF files can be opened in most browsers.
- 2 replies
- custom holsters
- manufacturing
(and 1 more)
A 441 machine is a general description of a clone of a Juki TSC-441. In this case, the current Techsew 441 clones are the models 4100 and 5100. The OP may have forgotten the model number, or the machine is in a different location than his home at the time this was posted. My machines live in a shop that I am not in when I do my posting on this forum (too busy sewing).
- 15 replies
- breaking needles
- 441 clone
(and 2 more)
Some clutch motors have a 3/4 inch shaft (~20mm). Most servo motors have something close to 13 or 14mm, which is way under the pulley bore on the clutch motor. You would need a custom bored sleeve to take up the slack.
Make sure you have sufficient foot pressure to fully hold down the leather as you sew. If it is too loose the leather can lift with the needle and cause problems like skipped stitches and bent needles. Take the cover off the end and handwheel slowly, watching the needle and hook for actual contact. The hook should just miss the scarf in the needle on the upstroke. If the needle touches the hook, the needle bar needs to be checked for looseness at the top and re-positioned, then tightened in place. There's a tapered pin holding the needle bar in place and set screw on top the locks down the lateral position of the needle bar pin. How often do you remove the faceplate and oil every crank and oil hole in the left end of the head? While you're doing that, check all set screws for tightness. Raise and lower the feet with the hand lifter to ensure that there is no binding or excess slack. If these simple things don't make any difference, contact Ron at Techsew. Make a video, with audio, to show what is happening.
- 15 replies
- breaking needles
- 441 clone
(and 2 more)
Possibly done on a Consew 104 free hand embroidery machine (by skilled sewers). Otherwise, they use a heavy duty programmable commercial embroidery machine, like those made by Melco.
New! And moving onto bigger and better projects
Wizcrafts replied to PaperSpiders's topic in Member Gallery
@PaperSpiders The three text links you posted are invalid links. Please try posting new links to your work or gallery photos. -
I recently bought a 6" blade Landis hand cranked splitter from a walk in customer. The blade needed to be replaced and the screws and springs adjusted for best results. You can sometimes pick them up for $300 to $500, depending on the condition. Or, you can save the hassles and buy a new cranked or motorized splitter from Weaver Leather, Cobra, Cowboy, or Techsew. Hand pulled skivers and splitters are sold by all the usual suspects, like Weaver, Tandy, Springfield, eBay, Amazon, etc. The longevity depends on how good the steel is in the blade and how good you are at keeping the edge stropped, sharpened and polished.
Forget the position sensor unless you want to sew fast and stop fast. If you buy a servo motor like this one, which already has a very small pulley, you can feather the pedal to sew at about 1.5 stitches per second. It is easy to stop it on a dime from that speed. This type of motor has brushes and does have a power drop off when you turn the speed limiter pot or switch all the way down. Turning it just above the starting speed regains the lost torque. The knob on this motor limits the top speed. Some people add a speed reducer setup between the motor and machine. That allows for extremely slow sewing and magnifies the torque by the gear ratio of all four pulleys (motor to large reducer, small reducer pulley to machine). There are new v-belts required when changing from a clutch to a servo, plus when adding a reducer into the mix. I would try it direectly from the servo motor to the machine pulley. Just make sure that you buy a servo with a 50mm pulley. I use these motors on most of my machines.
What a time to be broke ;-(
Changing pulley on a Family Sew motor
Wizcrafts replied to mcdoug's topic in Leather Sewing Machines
I edited the actual source code and fixed the link. It's an HTML thang. -
Here is the 7411RL-37 in action...
Singer 111W103 Stitch adjuster spindle wheel removal?
Wizcrafts replied to Scarolamade's topic in Leather Sewing Machines
If the threads are too far gone, use the set screw on the bottom of the adjuster channel to set the stitch length and lock it down with the top set screw. If you need a different length, unscrew the top screw and set the new length, etc. -
I checked out that ad and the machine is setup as a standard crossfeed machine, not up the arm. The foot and feed dog must sit inline with the arm to feed up the arm. This one soen't have that.
If you go to this Singer model number page and look under the section for the 11 series, there are several listed as up the arm feed machines. Finding one in working condition is another matter. They are from the 1940s and WWII.
From what I can see in the dark photos, that cylinder arm machine just has normal feed over the arm. Transverse feed machines have the foot/feet and feed dog aligned inline with the arm, not across it. Singer used to make a machine that sewed up the arm.
That style of feed is called transverse feed, or sew up the arm. There are sew up the arm machines used to make blue jeans, but they aren't really able to sew with heavy thread and may only be chainstitch machines. There are some specialty sew up the arm machines that are smaller than the Hightex in the video, but you'd have to search the Internet for them. If a chainstitch is acceptable, there is a brand made in the USA called Puritan. Their machines are chainstitch with needle and awl feed. The make an up the arm machine called The Alligator.
Another factor is about to come into play regarding the prices of Chinese vs Japanese built sewing machines. The Chinese machines now have a 25% tariff applied at the port of entry, Japanese machines have much lower tariffs that are not about to go up. As the prices of Chinese clones rises due to tariffs, the Japanese prices will likely stay put. The difference may zero out soon, making a JP built machine a better deal all around.
Bore out the hole in the pulley with a bit that is the closest good fit. You will need to use a caliper to figure out if you need SAE or Metric to get it to fit. That's what our dealers do when they sell you a Family Sew motor with the 50mm pulley already on it. Of course, they have special drill bits that bore an exact diameter to fit on the motor shaft. You could have saved all this running around if you bought the motor with the 50mm pulley installed from our dealers. -
If I recall correctly, the Singer 15-91 also threads from right to left (groove on right). However, it is a horizontal hook machine using Class 15 bobbins. Singer slant needle machines thread from front to back with a vertical hook in front of the needle.
Left foot/open toe blanket set for 441 clone
Wizcrafts replied to Parott1's topic in Leather Sewing Machines
Then update your profile to show your location. -
I have better success using #23 (160) needles with #138 thread.
Sorry. Not me.
Personally speaking, I would prefer a clutch motor with a 2" pulley over a pushbutton servo motor that starts spinning at 300 rpm. One can learn to feather the clutch, but can never feather an on-off switch. I have clutch motors on a few machines and prefer them over any servo due to the nature of those machines.
