Most of the good quality hemmers are designed to fit onto full size industrial machines. The right angles binders that do inside curves require a special presser foot set and a throat plate with a cutout for the mouth of the folder. Some even have a special feed dog that goes with the set. Chances are somewhere between null and void that anything like that will fit your portable walking foot machine. I think your best bet is to contact Sailrite and see what they can sell you that they have for their portable machines (LS and LZ series).
Seiko STW-8B - question on servo with needle positioner
Wizcrafts replied to katit's topic in Leather Sewing Machines
I have to agree with Katit here. I too have servo equipped machines without reducers and it is sometimes hit and miss with using my foot alone to stop dead up or down. That means I have to use the hand wheel to find the perfect rotational place . A needle positioner would speed things up by letting one sew fast, do a motion to affect the needle's position at the stop, then either pull out or resume sewing. The machines that have 3:1 reducers are hard to turn by hand unless the brakes are removed from the servo motors. Clutch motors are easier to hand crank for precise needle placement. -
Once you get down to a size 18 needle the point isn't so important and can affect the lay of the thread. The way I decide on a point change is if the needle makes an unpleasant noise, or squeaks going into the leather. That tells me that the friction is excessive. I keep three types of point in stock: round, DI (triangle) and slicing (LL or LR). Some points go through with less drag than others. Experiment!
There is a coil spring inside the head, around the presser bar. You need to push down on the bar to get more pressure and hold it down until the locking collar secures it in place. This is a domestic sewing machine for cloth. This forum is for discussing industrial leather sewing machines.
If it is, as I suspect, a clone of the Singer 15-90, it can likely sew 1/4 inch of cloth and about 1/8 to 3/16 inch of soft to medium temper veg-tan leather or vinyl. Seeing as how this is a drop feed machine, it will need help to pass leather under the foot. There are two ways to accomplish this: a roller equipped foot or a Teflon foot. While Teflon feet are easy to find and cheap, they mark easily and will be chewed up if one comes in direct contact with the feed dog.
Unbeknownst to many used to modern sewing machines, the Union Lockstitch machines can be adjusted to lay down the tightest stitches in the World, followed by Campbell-Randall Lockstitch machines. The take-up mechanism is capable of locking the top thread 100% near the top of the upstroke. It is usually also set to a certain amount of lift to position the knots in the dead center of the layers.
- 14 replies
- union lockstitch
- sew leather
(and 1 more)
You can read the specifications for the Consew 206R, here.
That Union Lockstitch is music to my ears. I've owned two so far and sold both of them off. I wouldn't be surprised if I end up with one more.
- 14 replies
- union lockstitch
- sew leather
(and 1 more)
Yep. Thread through all of the holes.
Try to locate Tony Luberto. He might be willing to build one for you. Or, he may have one left from the final run.
Take the tension disks off and clean and polish them. Remove any thread fragments you find near the threaded shaft. Make sure that the thread has some back pressure before it gets to the tension disks. This helps keep the thread deep inside the disks.
Actually, from what I've seen and read on the Sailrite website, the feet for leather are checkered, not smooth. They still need to grab a hold of the top layer to pull it back. Smooth feet would tend to slip on the top unless it was very grabby. If they now offer truly smooth bottom feet, I stand corrected.
Who uses a Pearson #6
Wizcrafts replied to T Moore Medicine Hat Saddlery's topic in Leather Sewing Machines
I fully agree with the bold text statement in the quote. Before CowboySew or Cobra, or the Juki TSC-441 ever existed, I owned a Union Lockstitch machine. That machine used a separate needle and awl and had a jump foot. They are typically used to sew long runs of tug straps and other horse tack, with heavy 6 cord linen thread run through a wax pot. The standard needle and awl set for this kind of work resembles a roofing nail. As such, there is no perceptible give when the needle comes up through 3/4 inch of leather and pushes it back to complete a stitch. While most of my sewing with that machine was thick thread into thick stacks of veg-tan or bridle leather, there were jobs that required more finesse, thinner thread and a correspondingly smaller needle and awl. During the years I owned that machine, I had purchased every available needle and awl made for it. Every setting would require tweaking when changing from a #4 down to a #1/2 needle (about the diameter of a #19 walking foot needle). The tapered screws that positioned the moving needle and stitch length assemblies had to be tightened almost to the point of binding to get a perfect placement of the tiny needle in the hole stabbed by the tiny #1 awl (about the diameter of a #20 needle). The slightest looseness in these parts usually resulted in the needle missing the hole, hitting the bottom of the leather, pushing it up and bending the $3.50 needle. But, once the machine was tightened to the Tees, it sewed like a champ. The only machine that could best it was a Campbell-Randall Lockstitch machine owned by a professional harness maker in the same city - whose work often went to the Rockefellers for their race horses. -
Welp. Now I need ("need") a post-bed for fashion shoes.
Wizcrafts replied to SheltathaLore's topic in Leather Sewing Machines
Not only do you have to worry about damage during shipping from eBay sellers, but also the level of assistance the seller will give to you after the sale. Some will and some won't and others don't speak English as a first or even second language. -
Machine Choice Heavier Than A Juki 1541S
Wizcrafts replied to stickandtin's topic in Leather Sewing Machines
My past experience with an LU-563 was that the reverse stitches were nowhere near the length of the forward stitches. -
Singer 95k51 hinges.. machine side?
Wizcrafts replied to plinkercases's topic in Leather Sewing Machines
As I have learned, sometimes, the only way to get hinges for ancient Singer sewing machines is from another one of the same model, or year/period in time. It may be easier to convert the hinges to modern ones, even if that involves drilling out the holes in the base of the machine and routing out the indents in the table. -
The machine isn't exactly a 111 model. It is a 20" body Singer 139w109. However, the moving parts and stitch length adjuster are the same as my 111w153, except the case and top and bottom shafts which are extra long. It was custom built for me by Bob Kovar, owner of Toledo Industrial Sewing Machines. You'll have to ask him what was involved in converting it to the LU Juki hook. I can tell you that the LU hook makes the timing very touchy compared to our standard 111w153. There is almost always a snap as the top thread goes around the shuttle and I have a lot more skipped stitches on this machine than most others, especially when sewing through leather tape between the layers. I only use titanium needles to minimize the glue buildup on needles. There is also more tweaking of the check spring needed than on the standard 111 machine. Would I buy another machine with an oversize hook conversion? Probably not. -
Anybody responding should know that Carmen is located in Canada. There will be customs documents required and possibly duty charged if the work crosses the US/Canada border.
I'm getting a birdsnest on the backstitch only
Wizcrafts replied to christine1ca's topic in Leather Sewing Machines
It is my experience that the timing of the arrival of the tip of the hook above the eye of the needle varies between forward and reverse sewing. That is why we time our machines in the zero motion position on machines having a single lever for both direction and stitch length. Most of my numerous sewing machines are forward only. I spin the work 180 degrees to lock the stitches at the beginning and end, or else I pull the top thread through the bottom and tie both starting and ending threads together (then trim the ends). This eliminates any issues like you are having. -
His profile plainly states: Raleigh, NC.
I know they are as rare as hen's teeth, but see if you can locate a Singer 168G101 7" post machine. These are compound feed walking foot machines that use the same feet, bobbins and needles (and tension unit) as a Singer 111w155. The stitch length adjustment is totally different than on any other Singer machine in the shop. It is done by turning a spring loaded screw that's accessible under the top rear cover plate. I am able to get better than 4 to the inch at the longest and too short to talk about at the other end. Expect to pay about $1400 to $1500, complete with a table with a servo motor (plus shipping or gas to pick it up). If you find one, buy some spring edge guide feet. Or pay the dealer to install a drop down edge guide. There is no room on the post to add a standard guide. -
If your budget is only around $500, you're going to have to buy something used and abused, privately. Search Craigslist for your state and neighboring states. Also, take a look in our Marketplace section, under Sewing Equipment, under the Refurbished or Used categories. The least expensive industrial sewing machine you can purchase as a complete unit is about $1100, plus shipping. Even a hand cranked heavy duty machine sells new for $1400 (Tippman Boss and Cowboy Outlaw). You can find some real awesome machines there. The biggest obstacle you will encounter is the thread size limitations of various types of sewing machines. As a hand sewer you may be used to waxed linen thread that is between 1/2 to 1mm thick. None of the modern lockstitch walking foot machines are able to pass that thread without gumming up the works and needle. That leaves you with dry or lubed bonded nylon or bonded polyester thread as your 2 options. Machines designed for upholstery are usually limited to a maximum thread size of #138 (aka, T135), which is rated at 22 pounds breaking strength. Some walking foot machines have been upgraded by specialty dealers, like our dealers, so they can handle #207 thread on top. But, that still leaves a weaker thread on the bottom. Not good for horse tack. See this thread and needle size chart for a reference. The machines that are designed with the required heavy duty parts for tensioning heavier thread (#207, 277, 346, etc) cost much more money and are much bigger. Be prepared to quadruple your budget for a truly qualified new harness stitcher. Even a used one will often sell for over $1300. Check our Marketplace, which I linked to in the first paragraph. I use this machine to sew harness, holsters, saddlery, knife sheathes, saddle bags, etc. Look at the pictures and read the specs.
I acquired one of those old post machines in the late 1980s. It needed parts. I solved that buy buying another one for $50 from a dealer who had it on a bottom shelf.
- 2 replies
- singer 51w
- post bed
- (and 7 more)
It will, if it has a 50mm (2") or smaller pulley. When set to their slowest startup speeds (for controlled detailed leather sewing), these motors have much less torque than the rated amount. That happens at a certain speed. The smallest possible pulley will slow down the machine speed and let the motor rev higher at any sewing speed, thereby transmitting more torque to the mechanism. Find out first if the motor you are looking at has a minimum start speed measured in hundreds of rpm, rather than a gradual ramp up from zero. Push button servo motors are notorious for starting with a bump at a few hundred rpm. Disclosure: I have been using servo motors with brushes and speed limiter pots for several years. They start at zero and need 2" pulleys to punch through most leather until I get the speed up to several stitches per second. They seem to come into their own power range around 5 stitches per second. Adding a 3:1 speed reducer really changes the dynamic. The larger the balance wheel pulley, the more torque that is delivered for any motor or pulley configuration. This also applies to clutch motors.
Can anybody identify this Consew?
Wizcrafts replied to strathmoredesigns's topic in Leather Sewing Machines
Tailor shop sewing machine, geared for high speed. Optimized for the thin cotton thread typically sold at fabric stores.
