Wizcrafts
Moderator
  1. I bet you didn't know that there is an adjustment for the brake on the right end of the motor. There is a big hex head bolt in front of the output shaft that screws into the housing. You can loosen the locknut, then turn the bolt in or out to adjust the amount of slack the pedal has before the brake lets go and the clutch engages. In order to get the most range of pedal throw, tighten up the spring loaded thumbnut on the right end of the activating lever under the motor. If the spring action is backed off the lever will hang lower and won't have much movement before the clutch activates.
  2. Have or can you measure the voltage at the outlet where you plugged in the motor?
  3. That is the model I sewed on.
  4. Different densities and thicknesses.
  5. The new outside foot may be rubbing against the inside foot, causing the hangup. It could be twisted slightly due to a manufacturing issue. I have purchased aftermarket feet that were misaligned. The original feet would have been installed by the dealer and they made sure they were inline and not rubbing. If the feet aren't misaligned, the new foot could be wider inside, causing it to grab the inside foot at a certain lift position. Adding more foot pressure overcomes slight misalignment.
  6. There is money in making and pleating drapes.
  7. Take the needle out every now and then and feel the tip with a fingertip. If you feel a burr, toss it out. If you are down to your last needle, pull it across Emory cloth to de-burr it, then polish it on a piece of veg-tan leather that has jewelers' rouge on it (like you strop a carving knife blade). Vinyl is trivial to penetrate and pull lockstitch knots into, even with undersize needles. Leather is not. You will almost always need more top tension, or less bobbin tension, or a bigger needle to bury the knots inside leather. The denser or thicker the leather, the larger the needle, or higher the top facing tension needs to be upped.
  8. Call Bob Kovar, at Toledo Industrial Sewing Machines (866-362-7397) and ask if he has some in stock. I've been to his shop and am here to tell you there be needles there!
  9. It may have been the reverse lever that raised up. It's been almost 3 decades since I last saw that machine. It definitely caused the stitch length to shorten as the speed increased.
  10. As a former owner of a Juki LU-563, I suggest that you try sewing (threaded or unthreaded) at high speed (floor it) and watch the stitch length lever to see if it moves up on its own. If it does, your stitch length will vary with the speed you are sewing at. It can be fixed, but requires at least removing the lever and its graduated mounting plate to gain access to the spring or springs that counterbalance the lever.
  11. I used to use a Singer bartacker at a part time sewing job I had in the early 1990s. The machine made the most awesome CLANG at the end of each cycle, which lasted about 1 second! It is very difficult to remove items that have been bartacked on.
  12. I simply passed along my experience where the original shipping box and Styrofoam packaging was ineffective at protecting the fragile machine from a drop along the way. Industrial sewing machines are usually shipped strapped onto pallets, with wooden a protective box around the head, with the hand wheel removed to protect the back of the machine from rough handling damage. Industrial sewing machines and tables are usually shipped fully insured.
  13. I bought one of those odd name portable walking foot machines off an eBay private seller a few years ago. The box was dropped on the way and the machine was hopelessly jammed and inoperable and I couldn't free up the main shaft. The seller tried to refuse to take it back and I had to go into arbitration to get some of my money back. So, anybody contemplating buying one should add insurance if offered for the full amount of the machine, plus shipping. Chances are very high that the box will be dropped and the plastic housing will crack, or main shaft will get pushed too far to fix it.
  14. They should. I would use one size larger needle than the minimum recommended combination on this thread and needle chart.
  15. Holes can be smoothed with round abrasive cord that's sold on metal 2 piece rolls by tool supply businesses. It comes in various diameters.
  16. Negatory Red Rider. A #150 needle is about equal to a #22.5. It lies between a #22 and a #23 in diameter.
  17. Size 150 needles are perfect for #138 thread in leather!
  18. Upload some photos of your clutch purse, Renata.
  19. Get left toe and right toe zipper foot sets, welting feet for whatever diameter welts you might want to sew into seats and bags (1/4 inch is average) and spring edge guide feet for 1/8", 3/16" and 1/4" from the needle. Buy matching colors of thread in all sizes your machine supports. I usually buy two of each so I can wind a matching color spare bobbin as I sew. Get a quart of oil and a couple of small precision oilers to load up. Get packs of needles to match the thread sizes you buy. I recommend sizes 18, 19, 20, 22 and 23. If you plan to sew mostly leather, get leather point needles. Round points are for cloth and webbing. Thread snips are a must have and are cheap. Get a dozen empty bobbins. Make sure you get a bright flex light. That's all.
  20. I prefer a #23 needle with #138 thread, top and bottom.
  21. Double stitching into the same hole pulls two lockstitch knots up into the layers, tightly against each other, filling the hole. In my experience, those knots are forever locked in place unless you get a grip on the bottom thread and yank the bottom knot out. If your top tension and hole size is just right, you won't see the knots from either side and they won't move at all. I do this mostly on holsters where a second row of #277 or #346 stitches might be unsightly, or the reverse sewing might not line up perfectly with the starting stitches. It does require a little more foot pressure to ensure that the leather stays down on the second upstroke in the same hole. It also requires a little practice to set the stitch lever in the zero position.
  22. The plastic used in saddlebags is not Kydex. You search this forum by pasting or typing the phrase Singer 112w140 into the search box in the upper ad section of each page. Select This Forum to get the best results about industrial sewing machines. If you are using a phone, the search box becomes a magnifying glass icon that is at the very top of the screen, on the right of a dark nav bar, next to the three lines navigation menu icon. Touch the icon to open a search box.
  23. In this case, aside from asking for opinions and suggestions here, why not package up some samples of your work in flat rate boxes and ask industrial sewing machine dealers if they will have time to sew off your samples on this or that machine (with this or that thread)? Mail them out and check the sewn results.
  24. In one close-up shot you can plainly see ADLER on the upper body of a patcher.
  25. Tandy Leather stores often put on workshops on Saturdays. They usually employ advanced customers to instruct newbies. There are leather trade shows a couple times a year, during the spring and summer. The biggest is in Sheridan, Wyoming. You can get bi-monthly tips and techniques from the Leather Crafters and Saddlers Journal. They have information about trade shows and equipment and supplies vendors. We have a section of the forum called How Do I Do That, and one called Resources, and another named Suppliers. These are excellent places to peruse or ask your own questions. Finally, this sub-forum is not for general leathercraft questions. It is dedicated to industrial leather sewing machines. If you have questions about your industrial sewing machines, ask them here. Questions about hand or machine sewing techniques, thread and needles belong under the Sewing Leather forum. We have lots of sub-forums. Explore them and enjoy your new craft!
