Have you considered leasing a brand new Cowboy stitcher? They make several models that are based on the Juki TSC-441, but at half the price. I have their CB4500, which has a useful 16.5 inch long arm.
class 3 & 4 buckstitch needle opinions
Wizcrafts replied to maggielj's topic in Leather Sewing Machines
Campbell-Randall sells Union Lockstitch machines, needles, awls and accessories. @CowboyBob might have the leather point needles you need that are meant for your machine. You would need to angle the tapered points to get the buckstitch appearance. -
It might do if it is twisted so the chisel is at about 45 degrees. It would probably have to be a #26 needle. -
I wonder if a Union Lockstitch chisel awl can be fitted into the needle bar of a 441 clone? Mine are at the shop. I'll compare the length and shank diameter on Tuesday and report back. The needle bar can be adjusted up and down as needed. It just needs to take the awl shaft and lock it in. Then the awl can be angled for punching buckstitch holes. -
Ah, so! If you must use a closed eye machine, get one with a lube pot on top. Fill it with liquid silicon (from Toledo Industrial Sewing Machines and other dealers). Run the top thread through the silicon to lubricate it. This may keep the wax on the thread from clogging the eye of the needle. Also, use a larger needle than is called for (see thread and needle chart). The larger eye will have a better chance of clearing the wax that strips off the thread. But, keep a dauber and a jar of Goof Off handy in case everything clogs up with wax.
Sewing thick leather with waxed thread calls for a needle and awl machine. You will find two of the best needle and awl machines here. I used to have a Union Lockstitch machine and ran Barbour's Irish Linen thread through it, using Lax Wax from Campbell-Randall, or Ceroxylon from Puritan Industries. Sellari's liquid stitching wax is also available for needle and awl machines and is often used in sole stitchers.
Perhaps Campbell-Randall Company, in Conroe, Texas can help you with the adjustments. They a the dealer for Campbell-Randall and Union Lockstitch machines and would probably know as much as anybody out there about sole stitchers. Address: 405 FM 3083 Rd, Conroe, TX 77301 Phone: 1-800-327-9420
https://leatherworker.net/forum/forum/223-3d-printers-and-lasers/
Messy stitches on cobbler only when stitching to the right
Wizcrafts replied to arich's topic in Leather Sewing Machines
When you move the leather to the right of the machine it has more friction as it tries to move over the throat plate and arm. There is also the push button on the throat plate that can get in the way. May I suggest that you remove the throat plate and get is buffed to a high polish? I did that on my Adler 30-7 and it helped a little. -
That's good work! We have a section of the forum where people can share digital and laser printer design patterns and programs.
Juki 1246-6 Skipping/Breaking Thread - Help!
Wizcrafts replied to brad Harper's topic in Leather Sewing Machines
Yea! Another win for the good guys! Glad it worked for you. -
I tried sewing soles on various machines I've had over the decades. The worst ones are flatbeds. The best were cylinder arm machines that have very little space on the left of the needle. I sewed one pair of soles on my Cowboy CB4500 using an inline foot set. I used #346 thread and a #26 needle. I cranked down the foot pressure to keep the leather from lifting with the huge, loaded needle. It worked. If you are planning to sew on soles more than once in a while, look for a used Landis 12 sole stitcher. The last model was a 12K. These machines had a curved needle (hook) and awl. They are specifically made to lay a perfect stitch of waxed thread along the edge. You sew with the sole up on the Landis'. It has a knife that cuts a channel on top to submerge the thread into the sole.
- 6 replies
- presser foot
- singer 132k6
(and 1 more)
I have news for you about the slowing it down part: "Ultra High Speed, Single Needle, Drop Feed, Lockstitch Machine" "With: Automatic Lubrication, Reverse Feed, Japanese Components" Here's the product page. Despite the requirement to run this machine at very high speed, it can be slowed down with a servo motor. Before you start sewing, unthread it and run it flat out for a half minute. This will pump the oil to the extremities. This is assuming you got the table containing the oil pan and gasket. The machine is not meant to just be manually oiled. It is a garment manufacturing machine. It is not rated for sewing leather.
Yep. At one point in time, I had two Singer (96k40 and 31-20), one Juki 563 and a Pfaff 138 all fitting onto the same table. I had to move the knee lever around to use the different heads
Maybe tweak the check spring to get a larger loop formed as the needle begins its ascent. There will be 3 adjustments possible: strength, travel and starting position. Try minimizing the travel so the spring stops as soon as the needle penetrates the top of the material. Back off the tension on the spring a bit. Try adjusting for more or less slack in the thread. Sometimes, adding slack helps overcome floppy material dissolving the loop. Othertimes, reducing the slack may do the trick.. -
The belt type is called Type 3L. They are 3/8 inch wide on top. If you have a hardware store nearby, they usually stock them in numerous lengths. Measure as close as you can, then buy a couple v-belts around that general size. Return the belts that are too long or short.
The four motion feed dog is also call "square drive." If done correctly, the feed dog starts under the throat plate in the forward most position. It then lifts straight up above the plate level. The it moves the material in sync with the needle and inside foot. After reaching the back of its travel, it drops straight down. This makes the bottom assist a little more precise than the standard feeder, which has a slope as it engages and disengages. I don't know how much difference this would make in every day sewing.
things to look for when buying a used machine?
The machine probably shipped with a couple of Metric wrenches for the most common bolts. Just bring a set that includes everything from 10 through 15mm. Also, bring a large flat blade screw driver with a fat handle. You can set the head upright in the back or front floorboard and tie it in place. Put some padding in the truck bed and lay the pedestal stand down with the post on the bottom and tie it down. Take the parts drawer out first and put it in the truck. There will be needles, bobbins, wrenches, extra feet, extra throat plates and probably a 4 ounce precision oiler. Bring a box for the small parts and all the thread you'll probably be getting. I've owned a CB4500 since 2012 and it has never seized or broken down after 11 years of regular use. I would ask to plug in the machine and test it to ensure that it turns over smoothly and actually sews. Bring several pieces of 8-10 ounce leather. If it is threaded with #277 thread, it needs at least 1/4 inch thickness to easily hide the lockstitch knots. Unless it's been modified, the thinnest it will sew is about 8 ounces, using #138 thread. It can be modded later to sew thinner with thinner thread and needles. The black and gold finish indicates that the machine came from a former dealer in Arlington, Texas. -
Turn the speed dial up a notch. You'll still be able to feather the pedal for slow speed, although it will be a little touchy until you get the hang of it. A 1:2 speed reducer is also a 2:1 torque magnifier.
Rather than promoting one particular seller, here are some Google search results for "Pull The Dot snap fasteners." Some eBay sellers have them in as little as 10 sets. Just make sure you read the specs to get the right post length for the project at hand. Some have very short posts for canvas. You'll want longer posts for use on holsters and sheathes.
The spindle doesn't have any threads. What it does have is a round tab inside one side of the cap on the end. That tab fits in the threads cut into the back of the top shaft. If those threads are intact, when you screw in the spindle you may have to loosen the cap and inside screws that have a very strong, small spring with a stud or ball bearing on the end. There is also another screw on the opposite side of the housing in the top of the head. It sets the maximum stitch length. The process is to determine which side has the cap screw. Remove it, then unscrew the inside screw with the spring until it is almost out. Rotate the shaft so you can get to the other screw and back it out. Now you should be able to twist in the spindle shaft. With it in all the way, screw down the spring loaded screw, then secure it with the cap screw. Set the maximum stitch length with the screw on the opposite side of that housing; usually between 4 and 5 stitches per inch. Now, you can screw the cap on the spindle out to shorten the stitches, or back in to lengthen them again.
Top and bottom mechanism timing on Pfaff 145
Wizcrafts replied to Marcremb's topic in Leather Sewing Machines
In my experience, when the top thread is so tight that it snaps going around the hook, the timing is retarded. There's two ways to correct this. One is to advance the hook. The other is to adjust the check spring for more slack during the take-up cycle. The additional slack is normally used when sewing thick seams, or if the material is bunching up from too tight stitches. If your hook is slightly slow, the check spring adjustment might reduce the tension going around it. If not, advance the hook slightly. It's possible that the hook has too much slack in the gears so that even though you timed it correctly at rest, it retards during operation. It might even have one or both set screws loose. Or, it could be set too high in the saddle, or the slack gears might allow it to lift during take-up.. -
If there is a Tandy Leather store near you, shaver blade and is used to thin the flesh side of leather belts at the turnback area where the buckle goes.some of your pleather in and ask to try their hand held skiving tool. It uses a small razor blade to skive (thin) leather belts at the fold for the buckle. Maybe it will work on your pleather.
That would be tricky on manmade material like pleather. I've tried skiving Naugahyde, to no avail. It just chewed up the back side. Still, it may be worth a tyry if the OP has access to somebody with a band knife skiver.
Should I Buy? Seized Singer 29k60 Treadle
Wizcrafts replied to EDDD's topic in Leather Sewing Machines
This machine is a shoe and boot "patcher." Do you plan to work on shoes and boots (uppers only)? It can also be used to sew patches onto vest pockets and jacket sleeves without closing the pockets or sleeves. Do you intend to go into the patch sewing business? Another thing these are good for is repairing looe purse strap tabs on the sides of purses. The narrow nose can get inside where no other machine can go. Will you be repairing purses and pouches. One more task the long arm patcher can handle is sewing cue cases, or other cylindrical otems, up the arm (I call it sewing up the snout). If you answered yes to one or more of those questions, it is worth your trouble to haul it home, fix the cause of the seizure, and put it to work. Please note, that despite its robust appearance, this is a light to medium duty manual sewing machine that is entirely fed by the presser foot. The foot rotates around 360 degrees and has aggreesive teeth to grab the work and pull it to form stitches. The teeth will leave very noticeable marks on veg-tan leather.
