The blind stitch machine uses curved needle and may or may not be able to sew through a blanket. The one I had was portable and only good for light weight pants and skirts.
It should always be possible to tighten the bobbin spring to exert sufficient tension on the bobbin thread to keep the knots centered inside the leather. Make sure that you feed the bobbin against the direction of the slot in its case and snap it under the tension spring. Then tighten down the bobbin tension screw until there is a reasonable pull required to get the thread out. Make sure that the top thread isn't getting caught under or around something it shouldn't. That includes the spool it is wound on.
If you're referring to a band knife splitter, I made my own skivings box out of suede and hung it under the opening in the table on 4 hooks. I put grommets on the holes to prevent wear. I pull it off the hooks to empty it. It's been working fine for about 5 or 6 years. I believe my skiver is a model 10.
Not according to your ip address. You are in Florida, using Hotwire ISP services..
These machines were made to fix shoe and boot uppers. That doesn't require thick thread. Most people use #69 (T70) bonded thread in their patchers. I do too. They can sew quite a long run with #69 thread in the bobbin. You can sew even farther if you move down to #46 (T45) thread.
For adhering canvas to vinyl, or vinyl to vinyl, I recommend HH-66 vinyl adhesive. It is a contact cement (applied to both pieces) that won't melt your vinyl like some other brands that contain aggressive (and dangerous) solvents, like toluene. You might want to buy an 8 ounce can first to test it out. If you buy another brand, make sure it says it is safe for use on vinyl on the label.
The only Singer patchers that are newer than the 29k71 are the Japanese built 29U171, 29U172, and 29U173. Anything else that is a newer patcher will either be a Chinese clone, or an Adler 30 series, or a Claes. At least the Adler 30 class uses the same bobbins and shuttles as the Singer 29 series. You sub-class 71 uses a small bobbin.
Make sure that your needle is the correct system. This is any of these: 29x3, 29x4, 135x16, or 135x17. Then, insert the needle all the way up inside the needle clamp and align it so that the ribbed side faces due left and the scarfed side faces due right. Lower the needle and inspect the paddle shaped spring above the clamp. It must exert good pressure on the thread coming down the hole in the needle bar. If that spring is twisted, broken, or weak, the loop will dissolve before the hook can pick it off the needle. See if there is a lot of slop in the shuttle gears. If there is, you will need to time it advanced to compensate for the wasted movement of the drive gears.
- 16 replies
- singer 29-4
- 29-4
(and 4 more)
Your needle is too small for #207 thread! A #22/140 needle is minimum size for #138 thread. You'll need to move up to a #23 or 24 needle. If the hook hits a larger needle, you will have to move the right side of the split post away from the needle and feed dog. To do this, loosen two huge bolts under the machine that secure the right side of the post and nudge the right side of the split post to the right, leaving the feed dog side in place. Set it so the hook just misses the needle, then lock down the bolts. This changes the timing. It also makes it more likely it will skip stitches with a #18 needle and #69 thread. Be aware that moving the posts apart might allow the tab on the bobbin case to slip out of its detente under the needle plate, and spin freely. This would be a bad thing if it happens.
The Juki LU-1508-NH is rated to use #207 thread, top and bottom and has a U size bobbin and double top tensioners. It can sew up to 10mm long stitches and has true rectangular feed on the bottom. It can actually sew up to 1.2 inch of material. The feet lift up to 5/8" to allow thick seams to pass under them. To allow for higher lift and thicker sewing, this machine is equipped with System 190 extra long needles. The inside work space (harp) is 5" x 10 inches. Is this enough space to roll the material up if you are sewing inside? This might be important if you sew on labels, Velcro or webbing. If 5x10 isn't sufficient, you'll need to look into long arm, high harp, tarp and sail sewing machines. They have up to 3 feet of work space to the right of the needle. My long arm has 20 inches.
I have a Singer long arm machine that was upgraded to a U bobbin system over a decade ago. When it works right, it is great! But, it jams either the top or bobbin thread at the slightest provocation. This could be from starting or stopping suddenly, or turning a corner too fast. If I don't hold back the top thread just right when I start, it jams in the hook (and, I know what I'm doing). The other day, while I was in the midst of sewing a gently curved rocker patch onto the back of a vest, the thread jammed the machine to a halt. I had to cut the thread stubs off over and under the vest. I discovered that the bobbin thread had actually wrapped itself up and under the spring loaded bobbin securing clamp and around the bobbin post! It looped right around that sucker! My G size bobbin Singer machines don't normally have these problems. This isn't to say that every Singer or clone machine that gets modded to a U bobbin will have troubles like mine. In fact, I suspect mine is an isolated problem. That said, the risk of introducing new problems is real.
Maybe the presser foot bar is binding when it is in the lifted position. If so, loosen any set screws that might be holding in bearings on the top and bottom of the presser bar. If that drops the foot, find the best position and tighten the screws to keep them in a good spot. It would help to pull out the presser bar and clean off any residue or dings with emory cloth.
Singer 211G155 - Auto Upholstery Worthy?
Wizcrafts replied to Adam704's topic in Leather Sewing Machines
I have a similar machine in my leather and sewing shop. The machine pulley is a fixed size. You probably want to replace the motor pulley with a 2 inch pulley. You need to measure the diameter of the shaft, then eBay it. Or, order from one of our supporting dealers, like @CowboyBob. I think that clutch motors have a 3/4 inch shaft, while most servo motors are 15mm diameter. Once you know the diameter, order the small pulley and also get a new v-belt that is that much shorter. The old belt will be too long and the motor may not have enough adjustment to compensate. V-belts have their length stamped somewhere on the outside. A typical -belt for a 4 inch motor to 4 inch machine pulley like your setup might be 44 inches. But, it could be less. The new belt would be 2 inches shorter if you get a 2 inch motor pulley. -
Disable any ad and scripting blockers for our website.
Cobra 26 needle missing needle plate hole
Wizcrafts replied to falling4u's topic in Leather Sewing Machines
The feed dog is way out of position. -
The Cobra 26 is a compound feed walking foot machine. There is no needle hole in the throat plate. The needle hole is inside the feed dog. The throat plate has a rectangular cutout to allow the feed dog to move from front to back.The needle bar moves in sync with the feed dog and inside foot. The needle should always go through the hole/slot in the feed dog. -
On my Cowboy CB4500 and my friend's Cobra Class 4, both of us can back off the top tension disks spring to the point that there is no tension at all. This is the same lack of tension we get when we lift the feet all the way with the hand lifter knob, or foot lifter pedal. When you lift the feet does the tension drop to, or close to zero at the disks? If the tension can be set to zero at the top disks, can the same be done by backing off the beehive spring on the bottom roller? Standard procedure is to wrap the thread around the bottom roller 1.5 turns. Check the tension as the thread exits the bottom roller. Move on to the check spring. Is the spring able to move up and down as the take-up lever moves up and down? Inspect the inside of the loop at the end of the spring to see if it has a burr, or is somehow pinching the thread. Inspect the thread hole in the take-up lever for burrs. Inspect the lower thread guides, including the thread hole on the needle mounting clamp. You need to figure out where along the thread patch the tightness is coming from. Maybe it is the spool itself. Is it cross-threaded? Once you are able to set the path to zero tension, balance the top and bottom. You should be able to back off the bobbin tension to a bare minimum and balance the knots. Make sure you're using the best thread and needle combination. Consult this needle and thread chart.
Do you realize that you have posted your name, address and phone number in plain view of anybody reading these posts? I hid them for your protection in case the harvesters didn't scrape them already. Take matters like this to private messages, not the publicly viewable forums.
@TES When you removed and replaced the shuttle retainer plate, did you leave some slack in the spring covered retainer securing screws? They need room to float as the top thread goes around the bobbin case. I back mine off 1 full turn for #277 thread and above, or 1/2 turn for smaller thread sizes. If you tightened the screws all the way down, there's no room for the thread to push out the shuttle as it goes around. This adds tension to the top thread and can actually pinch or jam it.
Are you holding back the starting threads for a few stitches? This is a necessity! When you start sewing, can you confirm that the top thread is going inside the inside foot and exiting out the back of that foot? If the top thread is fed between the inside and outside foot, there will be trouble. How much swing/travel does the check spring have? It must hold the top thread taut until the needle has penetrated the top layer. and must stop moving down before the needle reaches BDC. If your chec spring travel is too short, there will be too much slack in the top thread as the take-up lever moves down. This could lead to the thread getting caught by, and wrapping around the feet.
I wonder if it is a special model double needle machine? That would 'splain the second bobbin cover on the left.
CobraClass 4 Bobbins -- Will THESE fit?
Wizcrafts replied to MacB's topic in Leather Sewing Machines
@MacB I found these bobbins for your machine, from the seller Evernice. -
A #25 needle is too large for #207 thread. The hole will be too loose to grip the knots. Move down one size to a #24. Use leather point system 794 (7x4) when sewing leather, and round point 7x3 when sewing cloth, webbing and bio-synthetics. I don't know how you've threaded the machine on the top, but, make sure that the thread isn't rising up in the top tension disks as you sew.This may call for re-positioning the thread guide just below the disks. Also, it helps to wrap the thread counterclockwise around the top and bottom holes in the top thread post. I feed in through the top inline hole, wrap CCW, and feed out the bottom inline hole. This provides needed back pressure on the top thread which helps keep the thread from twisting and lifting out of the business part of the disks. Whatever needle you install, make sure the rib is facing due left and cutout scarf is facing due right. If the bobbin thread tension is too light, the knots will come out the top to easily. Reverse the direction of the bobbin so it makes are sharp turn and feeds against the direction of the path to the spring outlet hole. If it's too tight, feed straight in and reduce the spring tension. These machines need a fair amount of bobbin tension to offset the big spring in the tension system.
@Crockett Know that just because your machine can clear 3/8 inch of material and sew it, that material can't be very dense and incompressible. So, while that machine can sew together 3/8 inch of upholstery leather, it can't do the same with hard veg-tan in a shaped holster. The moving parts aren't secured strongly enough to hold together under the strain of trying to penetrate that thickness of hard temper leather, especially if you are trying to sew with #207 thread using a #24 needle. The best you can hope for is the sew 1/4 to 5/16 inch with #138 thread, using a #23 needle. Number 138 (T135) bonded nylon thread has 22 pounds breaking strength. I wouldn't trust that size thread to hold a serious holster together unless you also rivet the layers in case the thread breaks under stress. FYI: All of the holsters my partner and I produce are sewn with #277 thread, on top and bottom, using a #25 diamond or S point needle. I use a Cowboy CB4500 harness stitcher that I got from Toledo Industrial Sewing Machines in 2011. Before that, I used a Union Lockstitch Machine for holsters, sheathes, weight belts, gun belts, and anything over 1/4 inch thick veg-tan. The thinnest holsters we make are 1/4 inch thick. The thickest was 1 inch. The average is 1/2 to 5/8 inch along the edge that has a filler for the trigger guard and bottom profile..
