Wizcrafts
Moderator
  1. The 441 machines are timed slightly differently than upholstery class walking foot machines. I have a Cowboy CB4500 and one of my buddies has a Cobra Class 4. Both of us set the feet so that the inside foot hits the throat plate at the same time as the tip of the needle. Failure to set them this way throws the reverse stitches out of sync. My upholstery grade 111 type machines usually have the needle hit first. But, I sometimes tweak these positions for different jobs.
  2. Here is the Singer 11 guide for versions 11-1 through 11-26
  3. @Ronsruger Make sure you are using either a System 29x3 or x4, or a System 135x16 or x17 needle and have the rib on the left and small cutout above the eye on the right. If you are using one of these needle systems and the needle is facing as I described, the shuttle may be out of time. Your machine is probably from the late 1800s or very early 1900s and I'm not sure if the hook timing can be adjusted via an eccentric screw under the base like is is on later models. If so, there will be a hole in the base for a screwdriver. There would be a lock nut on the back of the cranks that needs to be loosened before you can turn the eccentric screw. Lock it back down after adjusting for the best timing. If the rod going to the shuttle isn't adjustable, one of the gears under the shuttle would have to be rotated in the direction needed to bring the tip of the hook inline with the needle, above the eye, after it comes up from bottom dead center and halts momentarily. The machine should preferably be upside down to keep the gears from falling out when the bottom gear cover is removed. I have uploaded the only manual I have that covers the older patchers. It refers to sub-models with the letter K, like 29k2, but also applies to models with a dash, like your 29-2. I hope this helps. 29K1 TO K4,K10 TO K18,K12 TO K23,K30 TO K33.pdf
  4. I have a similar machine in my shop. It is a Techsew 2700. It is a clone of a Consew 227R. I either use #69 (T70) or #92 (T90) thread, top and bottom. It is a very handy machine if you need a cylinder arm, compound feed, walking foot machine. It is great for sewing cuffs on leather jackets and hemming denim pants. You were curious if there are various feet, including smooth bottom feet. This machine is based upon the Singer 153, which is a cylinder arm walking foot machine based upon the Singer 111w155. As such it accepts all of the feet made for the Singer 111 series. There are lots of smooth feet available in left toe, right toe, double toe, piping feet, edge guide feet, and left or right toe narrow zipper feet (with teeth). Most of these machines use the same G bobbin as the Singer 111 and 153. G style bobbins are regarded as 1x capacity. Prewound G style bobbins hold 25 yards of T90 bonded thread and about 35 yards of T70. I use both sizes of prewounds.
  5. Throw out everything you know about thread. Hand stitching vs machine stitching are two different Worlds. You probably use waxed linen thread that is up to 1mm diameter, sewn with two needles in a running saddle stitch. The CB4500 (which I have) doesn't use linen thread, unless it is dry. Then, it is too weak for the thickness being sewn. It tends to shred as you sew. Lockstitch machines with a closed eye needle use bonded nylon, or bonded polyester thread. You can compare the bonded thread sizes to you linen thread sizes in this needle and thread chart. I use #277 bonded nylon to sew most holsters and sheathes, up to about 7/16th inch. Beyond that, I use #346 thread, top and bottom.
  6. Linen thread can be used only it is unwaxed. Closed eye machines are not meant to use waxed thread. It will gum up everything it come in contact with. If you want to routinely sew with waxed thread, look for a Union Lockstitch machine, or a Campbell-Randall Lockstitch. They are needle and awl machines with barbed needles that don't clog up from the wax on the thread. But, they still need to be cleaned up when the wax dries. There are only two thread waxes I have ever used in my machines: Super Ceroxylon from Puritan and Lax Wax from Campbell Randall. Again, they are meant for needle and awl machines.
  7. Yes! I've used mine a couple of times to punch holes for hand sewing with two needles when the customer is willing to pay extra. It can punch two to the inch maximum. The rest of the time I use the sewing machine to sew.
  8. You need to list your location if you want a local sewer or artisan to help you. Add it to your profile. Welcome to the forum.
  9. There are a couple things that can cause this. One is loosely bonded thread. Another if overly taut thread and another is retarded timing. The fixes are listed below. If the top thread is loosely bonded it will tend to unravel at the slightest provocation. Further, single needle lockstitch machines are meant to use reverse (Z) twist thread. If perchance your thread has a right twist, it will loosen and unravel as you sew. Try using a different or newer spool of thread on top! If the top thread is held taut all the way down as the needle bar approaches BDC, the loop will be small and tight. This can be corrected via the check spring travel limiter bracket that stops the downward motion of the spring. Set this for the best results by loosening the bracket set screw and handwheeling until the needle moves down to the top of the feed dog. Stop there and adjust the bracket so it stops the spring from going any lower. You might also change the position of the small screw in the curved slot on the check spring disks. The top thread needs some slack thread to function properly. This is controlled by the aforementioned position of the check disks. Moving the disks clockwise reduces the amount of slack. Moving counterclockwise adds more slack thread. I find that if the top thread is snapping as it goes around the hook and bobbin case, adding more slack quiets it down and makes for more controllable sewing. The hook to needle timing affects how the top thread loop is picked off the needle and wrapped around the bobbin case. Sometimes, retarded timing lets bad things happen as the thread goes around the case. It also causes the top thread to snap as it goes around (when it doesn't jam) Try advancing the hook slightly and see if that solves your problem.A combination of tweaking the hook timing and check spring may correct the shredding problem if everything else has been ruled out.
  10. Some servo motors are affected by the side angle of the chain that connects to the "go" pedal. My CB4500 had that problem so I placed a large C clamp on the pedestal post to feed the chain more inline with the motor's control arm. I also moved the chain mounting bracket as far to the right as it would go on the pedal. That solved the problem of slowing down unexpectedly when I want it to speed up.
  11. Read this post for suggestions to reduce an image's filesize.
  12. If a #22 needle gets stuck in the hole in the throat plate, that suggests to me that the machine is meant to use thinner needles and thread, like a maximum of a #18/110 needle and #69 bonded thread. I recommend using a #19/120 needle with #92 thread, if that machine can handle it. It sounds like you bought a tailoring/dressmakers' machine, or maybe just a domestic/household machine falsely advertised as industrial. Does the machine come on a 20x48 inch table with a large clutch or servo motor underneath it, shipped on a pallet? Or, is the machine sitting in a small fitted box with a removable carrying case lid with a tiny motor attached to the back of the head? If the latter, it's a domestic machine for sewing thin cloth with small spools of cotton or polycore home sewing machine thread with thin needles (e.g., #10, 12, 14, etc). If so, you can probably forget about sewing 8 ounces of leather.
  13. Either use an anti-backlash spring under the bobbin, or insert the bobbin against the direction of rotation of the shuttle. This means the bobbin thread will make a sharp turn off the bobbin to the slot and stay under the spring better. It does add a tish more bobbin tension which may need to be counteracted by backing off 1/2 turn on the bobbin tension screw. Negatory. Mine is manually oiled. Everybody calls me Wiz. That's who and what I am!
  14. When this happens to me I chalk it up to the convergence of forces beyond my comprehension!
  15. I dunno the standards for needle/thread combos in the sail sewing field, but in the leather end we usually use a #19 or possibly #20 needle maximum with #92 bonded thread. It seems to me that a #22 needle is poking too big of a hole and the tip can't slide past the thread knots as easily. I occasionally sew non-leather items in my shop. Of course that calls for round point needles. Lately, I have been buying Groz-Beckert Gebedur needles and they are fantastic. Gebedur needles are titanium coated, but last longer under stress than the Orange brand. You might try dinking with the check spring slider position. Normal operation has the screw in the middle of a curved slot. Turning the disks clockwise tightens the top thread by reducing the slack on the downstroke. Try doing that. Loosen the little screw in the curved slot, back off the round nut and turn the disks clockwise, then lock them back down. If it gets better, problem solved. If not, return the screw to the middle, or try turning it ccw for more slack. Note: tightening the check spring slack setting all the way may cause the top thread to snap as it goes around the shuttle. If this happens, back off a tad.
  16. Suz, may I call you Suz? There is a trick to avoiding jamming your machine with top thread wrapping around the shuttle. Hold back the starting threads for a few stitches. If the bobbin thread is inaccessible, hold back the top thread. You will probably have to pull up or down to hide the first knot or two later on. Failure to do this usually results in the machine coming to a halt and you having to cut the thread under the material to remove it, then open the shuttle cover (and maybe the throat plate too) and as you found, the gib holding the bobbin case, then pull out all the double or triple wrapped thread. You may have to retime the hook if the machine lacks a safety clutch that disengages the hook when there's a thread jam. It is an unfortunate fact that a large number of perfectly good industrial sewing machines suffer from firsttitchitis; the grabbing of the top thread and double-wrapping it around the shuttle and bobbin case. Sometimes you may get lucky and be able to start sewing without jamming the hook, but only if the take-up lever is already on the downstroke and the top thread is firmly captured under the presser foot, and the foot has enough pressure to not let the thread slip out. Too many ifs in play.
  17. G style bobbins are too small for Big Barb! Don't even think about it! They are like half the size. Just load your own U bobbins with the bobbin winder.
  18. Spammers post links on forums hoping for search engines to pick them up and help promote those websites. It is the oldest trick in the books since the Internet moved from just bulletin boards (BBS) to websites with graphics and shopping carts. I was about to defang the link but you beat me to the punch and deleted it.
  19. The spam link goes to a Russian industrial sewing machine dealer with their own name branded machines. I deleted the post as I do for all spam links I learn about.
  20. Sometimes prewound bobbins are wider than metal bobbins, especially in larger sizes, like U. You might have to waste a few yards of thread to get them to drop in if that's the case. I haven't had that problem yet with the G size prewounds I buy from them and other places. But, somebody who uses them did and told be to be aware.
  21. Red nail polish using the little brush in the bottle.
  22. You must have bribed them with GlenLivet single malt scotch!
  23. The Cowboy inline foot set would also work good on narrow gussets.
  24. That looks like a 18th Century glockenoodleshitzer from the Outlander series. The British used them to torture the Highland Scots they captured during the battle at Glenlevit.
  25. Do you need the flatbed to sew 1/2 inch with #207 or #277 thread? There are a limited number of qualified machines that will do that. I went down this rabbit hole during my first couple of years sewing leather goods. Rather than enumerate all the numerous machines that didn't work out, the one that did was an Adler 204-374. These are as rare as hen's teeth. However, there is a clone of this machine made by Cowboy. It is model CB-243. It is expensive and only sews flat work. Do you know that you can buy a heavy duty cylinder arm machine and get a table attachment with it? This gives the best of both Worlds. Here is the machine I have for sewing holsters and gun belts. It came with an accessory pack that included a large flat table that bolts onto the pedestal stand. It is expensive too, but will save you having to buy a second machine.
