Content Count
1,907 -
Calendar
Everything posted by camano ridge
Josh that turned out great. When ever I have made that pattern I also have found that the straps need to be lengthend.
- 12 replies
- 1911
- shoulder holster
(and 1 more)
Not a dumb question. Some people do use it as a fianl finish. After wet moldng your holster should be pretty firm. When you oil it you should do just a finger tip aplication. You are trying to put a little nutrient back into the leather. You should not use enough oil to soften the holster. If you use Aussie ,others can chime in here because I don't use it at all. Apply light coats. Again this is a holster you do not want to make it supple. Your questions are not dumb they are essential in doing things right. We have all been there. None of us was born with a swivel knife in their hand other then maybe Al Stohlman.
That would be good KB You have posted this in three places and we have nothing new to look at. If you can post pictures wha tyou are now dealing with it would be helpful.
Like Texback said oil before sealing. and as Tex said give the oil time to migrate into the leather. No offense to the employees of Tandy, however if you want answers to a questions this is the place to come. You may occasionaly get a not quite correct answer here however there is always someone around to correct it.
Very Different Than My Usual
camano ridge replied to THein's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Very nice looking slings. I like the Reaper. -
Blue Guns For Sale
camano ridge replied to Haystacker's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Got mine today also. Thanks again Jeff. -
What you are wanting to do is called Hot Foil Stamping or Embossing. Do a search on you tube for hot foil stamping or hot foil embossing, you will see how it is done. There are hot foil machines that will cost several hundred to thousands. A cheaper way is similar to a branding ironplacing foil on the leather then pressing down with the branding iron. You might call these people and tell them what you want to do. http://lwleathers.com/products/leather-embossing They advertise on these forums at the top of the page.
Thanks, already tried Maverick they do have some light pebble gain, however it is a little to soft and stratchy for my needs.
Anyone know who sells pebble grained calfskin? I have tried the usual, Springfield, Goliger, Zackshite, Hide House. Actualy I maysettle for any pebble grained leaather.
KB what is your method for casing? A lot of people make the mistake of wiping a little water on the surface let it start to dry if it turning back toward natural color and feels cool you are ready to carve. not necassarily so. It takes more then moisture on the surface. If yo have not already done so read Hidepounders thread on casing leather http://leatherworker.net/forum/index.php?showtopic=19121 There are other ways of casing leather the important thing is to get the corect moisture content throughout the leather not just on the surface.
Where To Find Small Star Shapes For Punching Leather
camano ridge replied to KateB's topic in Leatherwork Conversation
Ok, I just made a liar out of myself. Goodsjapan has them in 4mm, 5mm 6mm and 8mm they are mixed in with other shapes so scroll down and you will find them. http://goodsjapan.com/leathercraft-shaped-leather-hole-punch-large-5-point-star-no12-8mm-x-8mm-554-p.asp The punch on etsy apears to be high carbon steel, it is not uncomon to have a little surface rust. As long as there is no pitting ( indications of severe rusting and lack of care). A little oil a wipe down with 0000 steel wool and you should be good to go.- 6 replies
- leather punch
- shapes
(and 1 more)
I have that set from Tandy and they work well. I really don't think you are going to find any smaller unless you have them custom made.- 6 replies
- leather punch
- shapes
(and 1 more)
If you are looking for a common name liek lemon juice it does not have one, it is sometimes called sodium acid. It is derived from mined phosphate. It is also phound in canned seafood and is used as a leavening agent in making bread. THere are many phosphate derivatives used in food. DISODIUM DIHYDROGEN PYROPHOSPHATE is characterized as GRAS (generaly reagarded as safe) There are warnings that excessive use can cause mineral imbalance in the body and bone loss.
Blue Guns For Sale
email sent -
I don't know what dye reducer you are using. Read the label if there is a fair amount of alcoholl in it may work. Try it and see.
Cheryl, Welcome to the forums. I am a little norht of you Camano Island. In Marysville all the time. If you need something quick there is Quilceda Leather on 88th. A little higher then Tandy but if you need just a couple of things it is cheaper then driving to Shoreline Tandy.
Weaving Belt
camano ridge replied to Mini5's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Here is his other thread it show the stamps he uses and he will sell them to you. http://leatherworker.net/forum/index.php?showtopic=61049&hl= -
Corey, see my post above yours. Alcohol will lighten it just put some on a rag and rub. Try it on an out of sight area to see if it gives you the effect you want.
Help To Identify Two Antique Saddles
camano ridge replied to John22's topic in Saddle Identification, Restoration & Repair
Marek, sent you a PM. At the top of the window right hand side next to your screen name you will see a red envolope click on it and it will open my message to you. -
Not sure what your defenition of reasonably priced is. Who ever does them for youwill charge a set up fee and minimum order. SX Industries http://sxindustries.com/ does custom work. They are a member on these forums. Give them a call.
Here is Royalwoods wholesale page minimum $100.00 order mix and match. Probably about the best price you will get from them. http://www.royalwoodltd.com/cat14-17aw.htm
Good Snap Setter?
camano ridge replied to Red Cent's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Longtooth not sure how long of a screw you need, Tandy, Springfield etc sell screws for that purpose. They say to convert conchos to snaps. However I use them to attach the snap to a T nut. You can get the black pull the DOT on ebay. Also Index Fastners sells Pull the DOT in Black and kind of a military tan color. http://www.ifithermoplastics.com/products/snap-fasteners
