Ferg
Contributing Member
Everything posted by Ferg
  1. I use a pair of 3.0 diopter reading glasses for close work. Haven't tried any that are actually magnifying glasses. ferg
  2. If I was going to build a prototype of what you speak....... I would buy stainless steel tubing the size you need for your holes, grind the outside diameter perfectly. Use a stainless steel channel the correct size for the OD of the tubing. Drill holes in the channel over each tube to place a screw that would thread into the end of the tube to hold them in place thus making the tubes replaceable/sharpened. You would then need a fixture for the channel that could be fitted to what ever machine/press you desire. You would also need a hole in the side of each tube for dispensing the leather divit. Just my .02 lol ferg
  3. I remember when I was a small boy,long time ago, I watched men shearing sheep. The difference? they done it by hand. The clippers looked like grass trimmers. Those old guys could fly with the shearing. Wonder if they sharpened with a stone? ERIC, Some day I am going to make a point to come to your area to see your shops. ferg
  4. Just a heads up: There are a number of leather stores selling hides without stating exactly how many sq. ft. they may contain. When I buy these hides I enlighten myself as to the average size of which ever animal hide I am ordering. ferg
  5. Your diameter of the "half circle" is more than the width of the straight portion of the body of your bag. Match the two and everything will work. ferg
  6. Nice and clean. One Caveat, you need to clean-up your radius where it meets the straight line. As you know it makes your stitching "wonkie"also. ferg
  7. I like the harness but I love the horse. lol ferg
  8. I have been doing quite a lot of experimenting with this product. There are several different edge paints on the market. I began with Fenice because it was readily available to me. Basically most seem to be relatively the same. Close grain leathers are the easiest to make a nice rounded edge. Open grain/soft leather, is more difficult. I done some edges following directions of several folks who have used the edge paint with less than desirable results. Most require you to apply anywhere from 5 to 10 applications, waiting to allow them to dry between coats. That is very time consuming and costly if you are trying to make something for sale. I used the rounded portion of a very good solder iron with a temperature controller to smooth the edges between applications. It is okay but takes too long. Fenice has a product called "GLOSS EDGE AGENT". It has the consistency of water but is real sticky. I applied one coat of it to a two layer kangaroo and Italian cow hide and one coat to a two layer with kangaroo and upholstery leather. Allowed them to dry for about 15 minutes. I used one of my modeling tools with somewhat of a curve to the tool end, and "slicked" the surface of the AGENT with it until there were no bumps or dips in the edge. Probably took 5 minutes of little pressure. I then applied one coat of GLOSSY EDGE PAINT PLUS, this is slightly heavier in consistency than standard. Allowed to dry for 20 to 30 minutes, used the modeler again. Required little work. I then applied one more coat of the same "GLOSSY EDGE PAINT PLUS". Left to dry overnight, it has a beautiful edge. I tried applying with a fine bristled artist's brush to apply the AGENT, that worked for me. As I mentioned it is like water so brushing it on was easy. I bought the little stainless steel edge tool from Tandy to apply the paint. That is a piece of cake. Without the AGENT as a first application the paint wants to run around a curve and puddle, definitely diminishes that problem. I believe the Agent being less than completely dry when applying the finish paint helps to keep the paint consistent in depth without running over the edges. I also waited just 25 or 30 minutes for the first coat of finish to dry before applying the second. Directions says a couple hours if I remember correctly. The FENICE product is a good product. You have to shake the bottles for several minutes and then set them down to allow the bubbles to disappear before application. Heavy product collects in the bottom of the finish coat bottles. If you do not shake well, consistency of the product is not there. Photo included is the tight leather. Forgive me for the poor photo. Difficult to capture with light reflecting off that gloss edge. lol ferg
  9. When you work with shell cordovan almost every other leather is just a little less pleasurable. ferg
  10. Doeskin, baby calf, goat, and I use Kangaroo for everything. ferg
  11. Robert, I am not interested in your leather. You might have a problem with this since some of the pieces you have cut the best parts from the hide. Nothing wrong with that, you just might have a problem getting $120 for them. My .02 ferg
  12. Change your routing of the thread after the post on top of machine. From right to left through the top hole, left to right in middle hole,(don't wrap thread around this),the right to left through the bottom hole. I don't know how you have your thread coming off this three hole piece for sure, this is the way it should be. From the bottom of the three holes go over the top of the adjusting discs, pull the thread between the discs and out the right side of same then down under the bottom adjuster, between the discs up on left side. When you pull the thread up to go into the top "Uptake" make sure the thread hooks over the little pointed piece on the back disc. The remainder of your thread route looks okay. After doing this do not change any tension before trying to sew. If the thread is still pulled out to the bottom you need to loosen the tension screw on the bobbin. One/eighth of a turn each time before testing again. If you need to do this more than 3 or 4 times you have your top tension messed up or the wrong "Bee Hive" spring on your top adjuster. ferg
  13. Bought some skins from Pergamena. They were okay. My biggest concern was how "floppy" the Goat skin is. Would be okay for lining but not much else. ferg
  14. Monica, Hide House has the American Bison. I believe that is where I bought my last hide. Seems they have Baby Bison also.Both are great leathers. If you google "American Bison Leather" you get a whole list of dealers. ferg
  15. Save your money a little longer and get a cylinder arm. You can do a "Fast Attach" for a table. You then have two machines for the price of one. This scenario isn't so great if you have lots of business. If you get busy later you can get another machine that doesn't require you to go to the bank for loan to acquire repair parts. Just my .02 ferg
  16. I do not join any of the social sights. I cannot view this without becoming a member. ferg
  17. Looks like it could be an 1873 year model. Gosh that is something older than I. ferg
  18. I had the piece of conduit. I really only needed a hole for my iPhone. lol Most of those shapes on e-bay can be made for next to nothing from readily available material. Too old to buy much on e-bay I guess. ferg
  19. Plus I am about ready to disconnect the bank, Safari, Office Supply store, Walmart, etc. from anything on my cell. The spam and advertisements are getting way out of hand. ferg
  20. I don't think I am the only one needing to cut the hole for camera and flash in leather cases for Cell phones. Didn't have much luck finding any stock Hole Punch that would work and I am sure, to have one custom made would be too expensive. Decided to make one. I used a piece of 1/2" metal thin wall conduit. You could clamp the end of the tube in a bench vise, I used a special type of Vise Grip, to slowly clamp the end close to the dimensions you need. I then inserted a piece of 5/16" x 1/2" solid brass into the crimped end. Using a flat headed steel hammer I continued to shape the tube to what I need for a Cell Phone. Ground a bevel at about 60 degrees on the outside of the crimped end to almost sharp then continued sharpening with a stone. Finished the edge on my leather strop. Cuts perfect. My first attempt at making one of these isn't exactly right on one side, will make another and correct that. Enclosed photos: ferg
  21. needlesYou can accomplish the same thing with the Fenice Brand. They even have a kit of all basic colors plus clear to use for over 100 different colors. ferg
  22. As many of you know, Tandy is distributing the Italian edge paint from FENICE. I bought some dark brown and some red the other day and have been experimenting. A few things I have found about using the product: The little steel bladed tool Tandy is selling is great for doing the edges. They have a short tutorial showing how to use the tool, if you try this product, view the tutorial. I wouldn't want to use a "Dauber". Too messy. You need to have the edges of the leather cut as near perfectly vertical as you can. Glue completely to the edge of both or many pieces and roll them down and then using a flat faced hammer, pound them down as tight as possible. It takes many coats of the paint to fill the joints if this is not followed. When I cut straight lines/edges of leather I find I can use a roller blade and get a very good edge on the leather. I tried two pieces of thin Kangaroo, two pieces of 3-4 Oz. veg tan cowhide, one piece of Kangaroo glued to one of kidskin, and a piece of upholstery leather glued to some veg tan cowhide. I read somewhere, you cannot use the edge paint on soft chrome tanned leather. That is not exactly true. You need to apply more coats to fill the pores but it still works. None of these pieces have been done long enough to see how they perform when bending or roughing them up etc. After cutting the leather I sanded with 600 grit sandpaper. Not sure if that is necessary when the edges of the leather are tightly glued. I did not stitch any of the trial pieces I done before applying the edge paint. I would definitely do that on a finished piece, after I get more experience at application. Too much paint on the metal wand can make a mess. It will run over the edge and onto the face or back side. I love to do rolled edges. They are time consuming if you want them to look good. The edge paint is time consuming if you want them to look good. I am sure the edges painted with Fenice is going to be something I am going to work with and learn to use properly. The edges are beautiful, especially since we can use quite a few colors. When the paint is dry I will take some photos and post them. BTW: When you hold the metal wand correctly you will have a nice rounded edge. I glued two pieces of upholstery leather together, rounded the edges with a tool, painted it. The paint will go to the rounded spot on the leather but not over the edge as you might expect. ferg
  23. Don't know if any of you are getting this one or not. We are getting Phone calls from Lord knows who, saying they received our e-mail and wanted to get more information. They know our names and I can only guess what else they know. BE CAREFUL FOLKS, WE DO NOT LIVE IN THE SOCIETY SOME OF US GREW UP IN. ferg
  24. When you come up with a price figure send me a PM. I may be interested. ferg
  25. The work is great. The green Taupe reminds me of my youngest daughter and her brunette hair died Red. Neat, well stitched and you obviously done a good job on your blanks, ferg
