Ferg
Contributing Member
Everything posted by Ferg
  1. A really good machine man would find all the little faults. May have been a quick "do-over". Still a great machine. ferg
  2. JoAnn Fabics has a great selection most of the time. I have quite a few with changeable partitions inside. I get the ones with latches. ferg
  3. Shaft may be worn or bearings could be going bad. This is the biggest problem with the older machines of any kind. Expect a number of things to fix/repair, quite often worth every bit of work but parts for the Fortuna may be costly. ferg
  4. If the skiving machine is a Fortuna I am interested. ferg
  5. Ferg
    Tractor Stamp
    If you or someone else, wishes to have a stamp made "Laser Gift Creations" is one way to go. Access this web page: http://www.amazon.com/s/?ie=UTF8&keywords=tractor+rubber+stamp&tag=googhydr-20&index=aps&hvadid=31564919477&hvpos=1o2&hvexid=&hvnetw=g&hvrand=3560352234195011412&hvpone=&hvptwo=&hvqmt=b&hvdev=c&ref=pd_sl_1hs7o5sg05_b There are tractor rubber stamps. This would give you the black line drawing for the tractor to send to LGC. I think you are looking at $50 for the leather stamp. ferg
  6. I don't like storing much of anything except trash in plastic bags. Sunlight has a wide spectrum and can penetrate many types of material including brown paper. If I receive hides in rolled corrugated and brown paper I definitely leave both covers on. Again, my leather is all stored in a dark closet. I have two walls of my work area with lots of glass. I haven't tried Oxalic Acid but don't bet on it. You could cut the piece you need with the sunburn plus some not burned and expose to the sun for a day to see how different the patch looks. I am betting the already sunburned spot will simply get darker, just as our skin does. Just thought of another trick. This won't work too well if you want to carve your leather. Use Neatsfoot or Olive oil application on the "Un-Suntanned area of piece. Don't oil the already sunburned piece. Place that in the sun for a day and see what the effect is. If you find this is okay you could carve the piece and then do the suntanning in the same manner with oil. ferg
  7. You do have lights in your shop don't you? LOL Some types of artificial light will have some effect on the leather as does humidity of course. Before making a decision to hang leather in the "open" I would do some technical research. This info is available on the Web. You can hang the hides if you like. If you can put sufficiently strong anchors into rafters or such. Many types of clamps available. Google that. Remember, you will have some damaged leather where the clamps are placed. ferg
  8. You do not want to store the hides in daylight/sunlight, they will be sunburned where the light hits them. I keep mine rolled and inside a closet, dark cool, and dry. Also keep most of my hides wrapped in brown packaging paper. ferg
  9. First pic is a skiving machine. Could be a Fortuna, cannot tell from photo. Pretty bad shape. Would need to be dismantled, cleaned, serviced and checked out. I would give you $50 to $100 for it. One hundred if it is a Fortuna. ferg
  10. I can see where you are going with this. When I feed thin leather chrome mostly, I want the feed and the knife to turn slowly in comparison to other leathers. Easy to control. If the knife is as sharp as it should be there is no problem with the cut. I have simply gotten used to the way the machine is set up to begin with and have no problem with it. Different strokes for different folks! LOL ferg
  11. I don't have a Fortuna but have one very similar with both top and bottom feed. My machine feeds from one motor. Bell knife, feed for top and bottom are synchronized so you can vary the speed of feed while everything else responds to that speed. I would not want different speeds for each operation. ferg
  12. That is classic! I have seven grandkids. Youngest is 8th grade ????? Oldest is 30. Oh My! ferg
  13. Pleating is one method, my method is another. If using the pleating method and covering with another layer that may also be rolled, the thickness is a little extreme for me. When done properly, which I didn't necessarily do on the piece in the photo, the cuts blend so well there is no bunching. Many book binders use both ways. I think there is a place for almost every method of work. ferg
  14. bryanleenheerYou are getting some bad info here so I will show you a photo of how this is done. Please bear with me, photo is of the first rolled edge, round corner I ever done in leather. The wide portion of wedges must take into account the thickness of whatever you are wrapping at the corner. Each of the triangular pieces/cuts must be equal. Wedge next to the straight/square portion of your rolled edge must be square with the long straight edge with the other edge being an angle one third of the corner or 30 degrees. Note in my photo that I allowed the edge of straight piece to get stuck to glue before it was where it belonged. Doing these is a little tricky. With practice this becomes a very beautiful piece of work. Remains quite stable and strong when stitched. I don't convey instructions real well but I think you can get the idea from written word and photo. ferg
  15. Do you have a photo of this machine? ferg
  16. Hammer Customs, Don't take the criticism to heart. Some folks speak before brain is in gear. Your trucker wallet looks good and with all the accessory items you have included it is worth what you can get for it. Your price of $180 sounds okay to me. ferg
  17. I don't find my written info for doing this right now. Google "Book Binding" then "Rolled Round Corners". You will find a Web Page that has instruction on how to do this with photos. Don't get your rolled edge material too thin or it won't hold the stitch. I skive to about 1 1/2 oz. to 2 oz on anything very heavy or areas of much wear. ferg
  18. Make sure your unit is actually a true copy of the Fortuna. Most skiving machines other than Fortuna are nearly identical but do not have the same type of presser feet or the feed wheel. My Cowboy has the serrated metal wheel. Easily cleaned. ferg
  19. The roller stone needs to be adjusted as near perfectly aligned with the knife as possible. Less aggressive. Using these machines can be very aggravating but super rewarding when you get it all figured out. This is a post I made after I had learned to use my skiving machine. http://leatherworker.net/forum/index.php?showtopic=45661&hl=%2Bskiving+%2Bmachine ferg
  20. Three things you may wish to check: Did you use the stone on the inside of the Bell knife to remove "fuzzy edge"? Sharpen knife in very small increments. You may be feeding too slow. ferg
  21. Jo, Just bite the bullet and buy a servo. You will pat yourself on the back every time you sew. ferg
  22. I make a change purse for ladies. My wife places it in her purse. I made hers of Kangaroo with two snaps, she loves it. ferg
  23. Your machine will sew 207 with 138 in the bobbin. Doesn't really do well with the 207. I have used 69 thru- 135 with no difficulties. I have done a few adjustments to mine and actually sewn nearly 3/8" but it is hard on the machine since it was intended for medium to light work. Hold at 1/4" if at all possible, machine will last longer. Keystone Sewing Machine has a great copy of the manual. URL: http://www.keysew.com/ They also have or can get for you many of the accessories for the machine. Bob Kovar at Toledo Industrial URL: http://www.tolindsewmach.com/ Has many of the accessories also. ferg
  24. Handle the leather as you would for tempering, ready to carve. Makes the punching holes almost fun. LOL ferg
  25. Me too!
