Everything posted by Ferg
Preventing Immediate Wrinkles In New, Stiff, Veg-Tan Leather
Ferg replied to cameronmoss's topic in How Do I Do That?
I agree. Turning Veg tan of any thickness at all will make it appear wrinkled. Unfortunately, the cost of good leather is some times relative. You really need to see what you are buying if you wish to make high end products or most other items worthy of your talent. ferg -
Your photo appears to be "Leg" or "Belly" maybe neck, leather. You need to buy some of the better and more expensive hides if you wish to do this type of work. Cheap hides will have a lot of wrinkles. Looks okay with some goods. ferg -
Just In Case You're Having A Bad Day
Ferg replied to Dwight's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I walk away, grumbling probably. Go out into the yard and talk to my flowers and the birds. Works most of the time. Just think of all the practice those provided you. ferg -
Pull a length of thread through the slot, 3 or 4 inches, hold onto it as you start the winder allowing it to wind several times so it will hold. I usually stop when it is winding tight, clip the projecting thread so it doesn't get tangled up with the bobbin. The slot should be on the side of bobbin away from machine. ferg
The word "Footer" is what I was referring to. If you cannot change any of the coding they have in the Template you undoubtedly cannot delete the word. Your redo of the About Us page reads much better, good job! It is a little strange the template is written with a "Hover" and an entry text. May confuse a number of folks but don't worry about it now. See how much traffic you get on the site. I haven't allowed the people that are going to contact you with all the fabulous contacts they are going to get for you, to get any further than initial E-mail. Let the Robots scan your site. If you have appropriate layout and important words in your title your site will get listed higher. May take several weeks before you find anyone "Hitting" your site, don't get discouraged. I have a site I sell one product on. Used a service to get more hits, paid them good money with little to no response. Ditched them as soon as I could. Business has been good ever since. We have more business than we want during Christmas Season. Unique product line will get you noticed quickly. ferg
Web-Site looks to be okay, a little on the amateur side but useful. I am picky about the way text is used on a site. Your "About Us" page has this line: Between helping pets and promoting the dying art of leather work I could not be happier to make these for you guys. Get rid of "you guys". Stop at "you". At the bottom of each of your pages you have "Footer". That is a coded reference more or less. It should be hidden or simply do not include on the page at all, not necessary. "Store" pages should tell your potential customers what they need to do to access a particular item to buy. Many folks would not know to "hover" over the item photo. Your order information is redundant. Your "Hover" should take the customer to the full description with information they need to give you as well as their link to Credit Card/Shopping Cart. If you wish, you could leave both the "Hover" and the Description Text under the photos, linked to the full description page. Just a few thoughts. ferg
I don't remember seeing one commercially made just like this. You can make one with steel electrical conduit, not aluminum. You can make the long cuts with a bandsaw while cutting the inside ends with a dremel tool. Sharpen the edge of the tubing before cutting the "Legs" of the punch. When sharpening for a lace punch you sharpen both inside and outside of tube. You would also need to use a small file to even up the edges of the punch. ferg
Barge will hold almost anything together if it is applied correctly. You cannot glue wet leather, it must be dry. Do not thin the glue from the can it is the correct consistency. Apply the glue to both surfaces, allow to dry until it feels barely tacky to your finger. Position exactly where you wish the pieces to be. After placing the two pieces of leather together roll it with a Paper Hangars roller. (Available at Lowe's or HD) Weldwood Gel contact cement is another great glue for leather. Same instructions apply. ferg
shooter55, Try taking vitamin B12. Weird I know, it works. ferg
Some of you gents may think the press I illustrated is slow but I assure you, it is not. "Slow" is relative to the person doing the work. Lay out the job, set-up the jig and have at it. Simple as that. ferg
My explanations of how to do things seem to be less than perfect for some folks but I will give this a shot. You need at least a 2 ton Arbor press. It will be hand operated, your arm will increase in size after you do a pile of these. LOL One piece of steel at least 1/4" x 4" x 12" One piece of steel 1/4" x 1 1/2" x 12" Two pieces of aluminum or steel 1/2" x 2" x 2" Two angle brackets intended for sliding doors (Lowe's and HD has these). One piece of cutting board surface at least 1/4" x 4" x 12" Four 1/4x20 thumb screws 1/2" long. Four other bolts to fasten upright to the angle brackets. A strap end punch of your choosing. Cut the handle completely off the punch and grind the surface level across the top of the cutting edges. You will need a 1/4" piece of steel to match the outer limits of the punch cutting edge. This will lay on top of the punch so the ram of the press has a surface to rest on. If you have access to brazing or welding equipment, the small plate should be attached to punch. You will also need access to a drill press and thread taps. Photo showing table with adjustable back stop. You will need a stop at one end to butt the strap and align the punch. Rear view. Table turned up so you can see the blocks that clamp onto the base of the arbor press. Holes in aluminum blocks are not relevant. Another shot of adjustable angles. You could add another stop to adjust to different widths of strap if you wish. Normally the strap will stay against the back stop while cutting. Tried to make this as concise as possible and still give you enough info to make the jig. The arbor press will not cut more than one strap thickness at a time but this provides you with a jig to cut every strap exactly the same. If I can be of further help just let me know. ferg
U-Line possibility for you. http://www.uline.com/Product/AdvSearchResult.aspx?keywords=9%20x%204%20x%201 ferg
220V Ez Clutch Motor Woes- Troubleshooting Help?
Ferg replied to MCM Ranch's topic in Sewing Leather
I believe you are correct about the voltage readings, IF you read between the two terminals. When you read from ground to the terminals it is a different story. I have a 40 horse phase converter in our shop. Actually the three phase voltage is 260 Volts with no load in our set-up. I have a 220 Volt single phase sander tied to the two three phase terminals in the fused disconnect that read 120 v each, to ground. The sander is obviously grounded. This connection gives me a 220 v single phase. I can also connect to one of these 120v. terminals plus a ground to run anything requiring 120v. single phase. The best "fix" for this problem is.....buy a Servo Motor that is 120 volt single phase. Such as one Bob Kovar sells at Toledo Industrial. All of your sewing problems are solved with one simple set-up. ferg -
Talk about overkill, you guys are dreaming up something that is totally unnecessary. If you wish to make a top with laminate as a finished surface, obtain a piece or 4 x 8 foot sheet of particle board 1 1/8" thick. You can build an under carriage/leg set from 2 x 4's you can buy at Lowe's or HD if you like but the "H" set of legs available that are made for this purpose, I know your wife thinks they are ugly, has everything where it is supposed to be with no interference when you mount a motor, cut a belting hole, etc. You think that 11/8" particle board isn't heavy enough? I have three of them and I see absolutely no problem with any of them. IMHO, Buy the "H" leg set and cover it with something that makes it look Industrial if you will. BTW: If I put a table under one of my machines with that black pipe for legs my wife would make it disappear. LOL ferg
- 181 replies
- diy sewing table
- industrial sewing table
(and 3 more)
Question Regarding Old Craftaid Templates
Ferg replied to Ed in Tx's topic in Patterns and Templates
I gripe all the time about purse hardware in particular. An awful lot of the pieces available are almost or are exactly like those we bought 50 years ago. Magnetic catches are "nifty" but many of them pull out of the leather the receiver is fastened to. I recently made a new purse for my wife. Used a very nice looking catch that should work well. She fiddles with it all the time to get it latched. Slots with a leather tongue for closing is often used. ferg -
Years ago I used the Craftaids because it saved time. I have a "Bunch" of the old ones, some were used very little. Have no idea what they are worth these days but if they have been used a lot they tended to curl up somewhat. Definitely need to case the leather before using them. If you try to transfer while the leather is too wet, forget it. ferg -
Looks to be some of the older Tandy tools. Good find anyway. ferg
My roots are not very far from the Amish tradition so I enjoy these folks immensely. Buy timber and other building materials from them as well as visiting their community in Ohio just about every year. Almost everyone going to the auction says much the same thing about the crowds. In my later years I have learned to frequent less crowded venues. Too bad about the prices things went for Art, that "kinda" negates the whole idea of an auction of used equipment. ferg
Adam, Very nice front page. I noticed one little thing. "somethings" should read, "some things". Nice photos. ferg
Help Deciding Between Clicker Knife And Japanese Style Utility Knife
Ferg replied to apriori's topic in Leather Tools
In my opinion neither of these knives is what you want. I have the Osborne clicker knife. If I had my druthers, it would be in the trash bin. The blades are about as cheap as anything I have ever tried to use and the handles are terrible. For a utility knife visit a local hobby shop, Michaels or others. Get a very good ExActo knife. After you use it for awhile you can think about a good knife from one of the folks on this forum. ferg -
Frank, I know something of what you are feeling. In 1970 we lost both mom and dad and three other close relatives. It takes very special folks to care for the disabled. Prayers are with you. ferg
Double check your tension settings. Remember: Your stitch is only as strong as the "Least" of your thread. ferg
I guess it has been more than a year when a number of us drooled over some Italian Clicker knives among others. Clicker knives were used many years ago in the shoe industry. Trimming edges and cutting heavy leather. There are You-Tube videos of name brand manufacturers using a clicker knife to cut parts for many different items. I spoke to a good friend who makes fantastic knives about making at least two blades for me that would cut forever with nothing more than stropping. After several communications with my wishes and his knowledge I have two different blades. I have made one handle. I will enclose photos. I have made a number of wooden handles over the years and found that almost every human hand has something different about it when working with wood or leather and I am sure many other materials as well. Folks who make cutting knives for a living must try to make handles that will work for many different hand shapes etc. This handle is two pieces of solid brass with Purple Heart wood to the same thickness as the knife blade. One strip of the wood has been glued even with the two long edges of the brass plus a "plug" at the butt end of the handle. Blade and handle is held together with three brass screws. Blade has two holes to accommodate screws. You may note the handle is not exactly straight along the edges. I have found that the heavy brass and other metal handles need to "Cozy up" to your hand to be comfortable when working. I will probably do some further filing on this one as I use it. Simply a view of the one edge of handle. The business end. I wanted to show the blade entry into the end of handle not the blade itself. Time to make the handle occupied about 4 hours. I split it up into three or four sessions so I could still move my fingers when finished. I have no intentions of making any of these for sale. Am still thinking how I want to make the other handle. Questions? Just let me know. ferg
Probably didn't let it set long enough. Normally 15 minutes to half an hour is sufficient. Sounds as though you may have had some oil or other residue present. ferg
I drilled 3/8" holes at the inside corner locations of the 4x 4 post on the end plates, cut 3/8" All Thread to one inch longer than the total length of post plus end plate thickness, used Jam nuts on the All Thread tightening them to secure the plates to the post. We have a great metal supply shop close by, they cut the post and plates for me. The jam nuts rest in holes drilled into the 1 3/4" top and bottom so the plates can be lag screwed in place. This is link to finished unit. http://leatherworker.net/forum/index.php?showtopic=48492&hl=ferg ferg
