Everything posted by Goldshot Ron
Simply put....COOL. A lot of time and effort went into your creation.
Very nice. A lot of thought and hard work went into making these.
Impressive Randy. I made a tool belt for an electrician a few years ago, and there is more that goes into the project than what many people would think. A whole new line of work for you to consider. Ron
Fender repair...
Goldshot Ron replied to Brokenolmarine's topic in Saddle Identification, Restoration & Repair
I am going to cover two tasks. 1. Rivet removal tools needed: hammer, sharp center punch, awl, and drill will bit about the size of a number nine rivet. Flatten the burr end of the rivet, punch with center punch to dimple a hole in the burr end of the rivet, drill out the rivet until the burr comes out. Punch out the rest of the rivet with an awl. Be careful not to burn the leather; I use to use a Drimal tool, but it creates too much heat and burns the leather. Stirrup twist: the Blevins pin part can be placed in two different directions. If the pins are facing outward, you cannot twist the ends properly. The pins need to be facing inward, or when the stirrup end is folded, the pins will be toward the fender. In this position, the twist is 180 degrees, and the pins will now face outward (or toward the horse). To set the twists, the stirrup end needs to be wet and the saddle placed on a stand with the stirrups weighted to set the twist. Often, the twisted leather does not need to be wrapped after setting. But, I wrap them most of the time. -
Help Wanted: Leather Tooling Artist
Goldshot Ron replied to BaroqueLeatherGal's topic in Help Wanted
What would you expect for turn around times once an artist receives the materials? The items you posted, are these die cut or does the artist hand cut the leather (the browband)? Do you send along a desired pattern or drawing; or, do you expect the artist to design a pattern, submit it to you for approval? Oh yes, hardware: does that come as part of the construction package? Thanks, Ron -
Here's how I would do your project: 5/8" is the standard width, but for stamping you may go 3/4 to and 1" wide. Cut your pieces, case the leather, and do your stamping. Edge and burnish the edges and dye (I'd use dark brown, Fiebings pro dye if possible). Treat with neetsfoot oil (both sides) and let dry. After oil has penetrated, rub it well with a cotton cloth or sheepskin (this enhances your work). Now, punch your holes and assemble. If you oil after punching the holes, the oil will darking the leather around the holes (no real problem, it will level out over time). There is no real value to use a protective coating such as resolene or tancote. Just wipe off the dirt and swet after riding.
I haven't read any comments about her tool use. (Or, maybe I missed it.) When replacing billets, I punch my holes in the leather first, before attaching them to the webbing, and gluing them doesn't help much in my opinion. But, what bothered me the most was her use of tools. Using a cobblers hammer on stitching irons, or hole punches, to set the holes irks the hell out of me. I know it's "anal" of me, but I even polish the face of my cobbler hammers so not to leave marks on my leather. I agree with Mulesaw, trying to glue a patch on to this saddle probably won't hold. Ron
Noseband With a Bad Reputation?
Goldshot Ron replied to TomE's topic in Saddle and Tack Accessory Items
I had to look twice to see if you actually installed a crank or pulley on the nose band. Like usual Tom, your work is flawless. Keep posting for us "want to be's". Thumbs up. Ron -
Halter/Bridle combination
Goldshot Ron replied to BlackDragon's topic in Saddle and Tack Accessory Items
I have made a few of this type of bridle, and your's looks very good. One comment, I think your throatlatch is on upside down. Very nice work. -
Photos please...I am not familiar with this saddle that you mentioned, but may help with photos.
Adler 205-370 - help an old man who screwed up
Goldshot Ron replied to councilman24's topic in Leather Sewing Machines
Sorry, I must have imagined it. I could not find the timing video either. But, Uwe Grosse has some on Youtube that are informative, and there is a Weaver video that offers good information on a 205. One problem I had when I first got my 205 was that I had to order two extra shims to fit behind the collar on the bobbin to accommodate 346 size thread. There was certainly a learning curve between the Adler and a clone 205. Good luck. -
Weaver has a good video on Youtube for timing your 205. -
Randy, what I do to avoid this problem is to use an overstitch wheel and mark about 4 or 5 stitch marks. Start at the third or fourth mark in reverse to the number one mark, then go forward from there. Make sure you hold both threads when starting. Ron
Screws ripped out of saddle tree
Goldshot Ron replied to Mendosa's topic in Saddle Identification, Restoration & Repair
I am going to be a "devil's advocate" here. What make of saddle to you have? Is the tree a rawhide covered wood tree, or fibreglass covered? Is it a composite plastic tree? Is this saddle a: no horn, heavy swell, bronc saddle; or, an old saddle that you thought would work. As Chuck mentioned above, is it worth fixin'. And, Bruce said contact the your saddle maker; lift is too short to skimp on proper repairs. -
Landis 3 Needle and Awl machine not stitching correctly
Goldshot Ron replied to knotzo's topic in Leather Sewing Machines
I just saw this thread. The one thing that I think I see, is that the bobbin is threaded incorrectly in the shuttle. Sewing with the cover off will also affect how it sews. I have messed with my Landis 3 for almost 7 years, and I still do not have faith in it nor myself to tackle a real project. -
I agree with Bland. Your latest photo tells me that the rigging is placed around the 3/4 position, and the rear strap on the rigging dee is attached around the back of the cantle. When going down a steep embarkment, your weight leaning back should be sufficient to keep the saddle in place. The saddle looks well made and well designed. To make the modification that you are asking about, would easily be $350 and more to reproduce something that would blend with the existing design.
- 5 replies
- wade saddle
- single rigged saddle
(and 3 more)
When I am in a pinch for a square hole, I use a sharp wood chisel.
If you can get it, I would suggest using Fiebings acrylic antique dye for your first attempt. It is more foregiving than their Pro dye, and you can lighten it easily with a damp sponge by removing some of the color before it dries.
Hey Tom, thanks for the write-up. You did a very good job on your "Constructing Halters" paper. I'll have to put a copy in my notebook on halters and bridles. Ron
You need to adjust the top thread, which in this case tighten it some. The top thread is showing on the bottom between the stitches of the bobbin thread. But first, what size bobbin thread are you using? Example: 277 for top thread, the bobbin should be 207 (one size lighter than the top thread). In fact, if you were to use a lighter bobbin thread, you might not have to adjust the top thread. Your stitches do not look that bad, it just takes practice. Ron
You are welcome. I see that you and Randy are both from Oklahoma. He's a pretty good saddle maker, and a good source of information. Well, have fun keeping your granddaughters safe.
Tucker Saddle hazy film
Goldshot Ron replied to KathySemi's topic in Saddle Identification, Restoration & Repair
Kathy, Your pictures suggest that it had a factory finish on the saddle, and you washed some of it off. The seat jockeys do not appear to be dry, and the type of leather they used looks like burgandy latigo. Latigo does not shine naturally, but has a dull finish. What I use on latigos and strings is Rudy's Leather conditioner. I use it on saddle seats where you do not want oil wicking into your jeans. Springfield Leather carries this product, which is made in Vancouver, Washington. It is a non-oil product, but it does not shine up. It works to prevent mold and mildew on leather. So, you are correct, I agree that you need to oil the saddle. When I have a really dirty saddle, I will use a formula of water, a few drops of Ivory dish soap, and amonia (enough to keep the amonia smell) to cut the grim and gease. Your saddle would not need this treatment. Good luck, Ron -
Kathy, It sounds like you removed the oil from the leather by cleaning it the way you discribed. I would recommend using Neetsfoot oil to condition the leather. Start in an obscure area first to see what it does. If you do not have Neetsfoot oil, a virgin olive oil will work also. I am not familiar enough with Lexol products to comment on them; I haven't used Lexol in over 40 years. My basic procedures is to brush off dirt and dust, wash with saddle soap, and when dry, oil with Neetsfoot oil. Once the oil has penetrated the leather and is dry to the touch, buff the saddle with a cotton cloth. Ron -
Several years ago, I saw a saddle made by your father. It was fully tooled with long tapadaros. When I searched for the maker, the search kept coming back to a Bill Conway in Pueblo, CO. It is good to know that he is the same person. I have worked on a couple of Ted's saddles; and, they were really made well and his tooling was outstanding. I never met the man, but I feel privileged to have repaired one of his saddles. Thank you for the information, Ron
