Looks a little too wet. It loses definition and doesn't hold the shape of the tool. Try a trial with a couple stamps. When you moisten the leather (case) stamp a single impression, wait 1 minute, then stamp again, continue until the leather is getting too dry to make a good impression. Then you will be ale to see the difference, what the burnished colour looks like, and the definition, and hoe many minutes it took to get there. Not all pieces of leather will behave exactly the same. Different tanages, thicknesses, etc. But it will give you a better measure of how wet/dry it needs to be. This was my biggest mistake when I started many years ago.
@TheMackinaw Moved your post to leather sewing machines. Lots of visitors in this part of the forum Welcome to LW.
You are doing OK here. You can drop several pictures on a post. Then click the plus (+) sign to put them where your cursor is in the text of the post. Thanks for making the effort.
@johnnydb Please post your photos here. Third party hosting often results in bad links due to people changing permissions, moving files, deleting their account, host going out of business or changing policies, etc. When this happens, the posts in the thread lose relevance and become useless to future readers. If you are having trouble posting here, reduce the size of your photos to 800x600 or 1024x768 pixels and you can post maybe hundreds of photos in a single post. See this thread for help if you need it. Lots of options https://leatherworker.net/forum/topic/15122-how-to-post-pictures-on-lw/?do=findComment&comment=551171
Even with the bushings dripping with oil (really over oiled) I've seen several seized up. Only happens with bushings. Never on ball bearings. For my own, I switched to a sealed ball bearing motor and never had any problems with it. Main reason for switching was to change to a 2 speed motor so I could run low speed all the time to maintain circulation through the whole house and run at high speed when heating or a/c kicked in. Ran for years that way, then installed a high efficiency furnace.
I'm not the only one that has run into this problem. If you search through this forum you will find other incidents that are the same. I've had the same problems with furnace fan motors where they seize up frequently, even when well oiled. Seized due to a build up of varnish.
He hasn't been on the site since Oct 2020.
Very bad etiquette for any forum. Suggest you follow the directions you have been given.
You need to reduce the file size of your photos. See this link for several suggestions of ow or what software is available to resize your photos. https://leatherworker.net/forum/topic/15122-how-to-post-pictures-on-lw/?do=findComment&comment=551171 Please post your photos here.
The marketplace includes several sub forums. The business and estate sales section, maybe a good catch all for you. Also note the marketplace rules https://leatherworker.net/forum/forum/70-announcements/ If you are able to, it may help to break things up into groups of tools, etc. with separate postings for each group. It will be easier for you to keep track of what is sold and questions or comments.
@teddy8bear Moved your post to leather sewing machines. Used is in the marketplace where you post to sell equipment. Please post photos here so they don't disappear when 3rd party host, or who ever changes requirements, location, PW etc. Threads become useless when the photos illustrating the information disappear. For videos, save on YouTube or other 3rd party host as they won't usually fit here. Since this video is relatively small, I was able to post it here with your photos.
- 6 replies
- 205-64
- shuttle race
(and 2 more)
@xander0791 You need to reduce the file sizes to fit the restrictions. https://leatherworker.net/forum/topic/15122-how-to-post-pictures-on-lw/?do=findComment&comment=551171 Has information that you can look through to find a method that works for you and your equipment.
Must have been run dry. Oiling won't clean that up.
Wet molding mushes the tooling. I have photos of saddles where the tooling was done before wet molding, and others that were tooled, or touched up after the swells were installed. You may need a block of wood or something to fit inside while tooling.
Or, did someone use engine lubricating oil where the additives in the oil have oxidized turned to a gummy varnish which has dried out and caused the bearings to seize up? If so you may be able to soak it and soak it, and work it back and forth until it breaks loose. Then flush it well with good sewing machine oil and keep working at it until it turns easily again. Takes time and lots of patience. I have a machine that had been running fine. Left it sit for about 4 years. When I went to use it, it was seized up. I have to assume a previous owner had used a hardware store cheap oil like 3-in-1. Took a while to get it back into operation.
Please post photos here. See this link for suggestions and help in resizing your photos to fit. https://leatherworker.net/forum/topic/15122-how-to-post-pictures-on-lw/?do=findComment&comment=551171
- 3 replies
- cambell randal
- skiving machine
(and 1 more)
@Mulesaw Moved your post to general saddlery discussion. I think it will get more interest in that group here.
@Sculptor Moved your post to leather sewing machines. You'll get more assistance here. Have you searched this are of the forum? there is a very good chance it has been posted here.
Help preset foot not raising when sewing
Northmount replied to Candothiscandothat's topic in Leather Sewing Machines
@Candothiscandothat moved your post to leather sewing machines. Perhaps a picture or two, or a link to a video would help describe the problem your are having so members can give better advice. -
@urmasg Moved your post to leather sewing machines. You should get more interest from members in this area.
Pay once and download to your device. You can re-watch anytime you please. If you lose your video file, just download it again with no additional charge. Jim also has a number of free videos on youtube, facebook, etc. See my post above for ElkTracks videos.
Self taught goes a long ways, aided by videos and reference books or articles. https://www.youtube.com/c/ElktracksStudio/videos https://www.google.com/search?q=site%3Atandyleather.com+george+hurst+vidoes&client=firefox-b-d&bih=670&biw=1057&hl=en&tbm=vid&ei=LT5LYZP8Cv-U0PEPpvuikAw&oq=site%3Atandyleather.com+george+hurst+vidoes&gs_l=psy-ab-video.3...5195.8498.0.9368.7.7.0.0.0.0.92.594.7.7.0....0...1c.1.64.psy-ab-video..0.0.0....0.aog3wZl7y-0 https://www.google.com/search?client=firefox-b-d&tbm=vid&q=george+hurst+leather+videos&sa=X&ved=2ahUKEwi727ym5pLzAhVCqlsKHXB7B0YQ8ccDegQICBAG&biw=1057&bih=670&dpr=2.22 https://tandyleather.com/blogs/leathercraft-library https://tandyleather.com/blogs/leathercraft-library/carving-a-ruffed-grouse
Please update with price, photos, any shipping concerns, etc.
