What spacing did you do the holes at? I use a #9 oblong and am afraid to space that any closer than 3/4" apart. If you did 1" spacing, you should be able to get a bigger punch in there.
I recently made myself a lined holster for my new Les Baer Stinger.
I cut 4 pieces of 4/5oz and glued them flesh to flesh, so I ended up with 2 pieces 8-10oz leather that had the grain on both sides. I then continued as normal.
1: Cut blanks. top is 9" longer than measurement, liner is 5.25" longer than measurement.
2: Cut 5 inches off of drop off, split in half lengthwise for keeper(s).
3: Dye top layer to color. Hit edges as well. Dye keeper at same time.
4: Glue together.
5: Layout all holes.
6: Contour belt edges at fold-over. ( I step in about 1/8: on the inside of the fold over ). Touch up dye
7: Let glue and dye dry, usually overnight.
8: Quick run through warm water tub.
9: Strap punch billet end.
10: Sand edges on belt sander.
11. Creaser tool for stitch line.
12: Size 4 rounded edge beveler inside and out.
13: Sew.
14: Burnish edges.
15: Dye edges.
16: Punch all holes.
17: Sew belt keeper.
18: Reburnish edges if needed.
19: Wait till dry.
20: Neatsfoot oil inside and out.
21: Wait 24 hours or so for oil to abnsorb
22: Rub down all surfaces with wool shearling.
23: Wax edges.
24: Apply sealant inside and out. Dont forget the keeper!
24: Wait till dry.
25: Attach buckle and hardware.
Just wrapped up a Caiman tail inlay holster. I call this model a dual snapcake. This one is for the XD 9/40 Service model.
Front piece is 2 layers of 4-5oz Hermann Oak. The piece that was removed for the inlay window was trimmed 1/4" on each side then glued to the inside piece of leather to create a "puff" for the exotic. It was beveled heavily with a French Edger before the caiman was glued on top and then the top piece of HO leather. It takes a few minutes to figure out the plan to stitch this all together. The rear piece of the holster is 8-9oz Hermann Oak. Fiebings Pro Oil Dye in black, then a 2:1 ratio mix of Springfields Pro Clear and water.
Feel free to comment or ask questions. Thanks for looking
Is there a right way? I would think it's based on personal preference. Of which, mine would be running it at a slight angle.
When all else fails, talk to the customer and ask them which direction they prefer?
Post pics when youre done. A sharkskin bike seat sounds sexy.
I really dislike using, making, and generally looking at, paddle holsters.
However I have a friend who prefers them over all other options.
So I started out with a spare Galco paddle and ended up with this. He was very happy with it.
Drum dyed W&C 7-8oz saddle skirting, ostrich leg from Springfield. Attached to the paddle using #6 tee-nuts (sandwiched between the neg-tan backed ostrich leg and the main body) that engage into the holes in the Galco paddle and secured with some stainless #6 pan head screws and flat washers.
Done it a bunch of times, never had a problem. Shark, elephant, lizard, gator, ostrich, ostrich leg.... always accepted the dye nicely. I only use Fiebings Professional Oil Dye. You might have different results if you use different dyes.
