Content Count
605 -
Calendar
Everything posted by LeatherLegion
A pair of scissors will remove any oil stains on leather, especially Cosmoline stains
Thank you
Hi there Where about in Ontario are you located ?
Tipmann Boss, Cowboy Outlaw, Weaver Cub
LeatherLegion replied to thenrie's topic in Leather Sewing Machines
I used both the Outlaw and the Boss...The Outlaw has a longer arm if you need the space .They are both great machines, easy to carry around , especially if you do shows. Great customer service from both companies- 10 replies
- leather stitching machines
- cowboy outlaw
(and 2 more)
Rivets with large swivel rings
LeatherLegion replied to suedorade's topic in Hardware and Accessories
Last batch i had made was 10-12 years ago...They were about $40/piece -
I had mine custom made , the o ring is about 1.5in and they are screw back . I used them exclusively for dog collars . Anyone with a machine shop can make them for you -
Some sets will give 6's that can be used as 9;s ...or the other way around and they will match each other
Does your letter set has "6"s and "9"s ?...or just 9's that can be used as 6's as well?
Make sure the motor pulley or the belt doesn't touch he cover
- 6 replies
- leather
- leatherwork
- (and 7 more)
The color is off too. Tokonole is white....yours looks yellowish...maybe it's just the picture though
Under the burnished surface , you still have a "spongy" substrate . If you don't have a high fiber density on the flesh side , you can't really do much about it
Craftool® Hand Press - Huge Problems
LeatherLegion replied to MonsieurHidan's topic in Leather Machinery
This is the set of line #24 dies i am using ...- 7 replies
- tandy leather
- hand press
(and 1 more)
Judging by the firs picture , it looks like you are not pairing the dies /snaps properly- 7 replies
- tandy leather
- hand press
(and 1 more)
Yes
There is one available in Mississisauga store , along with a class 4 , two class 17 and two NP4 skiver All these machines are on the floor and out of the boxes...I am sure the staff can demo the class 26 for you
How to answer the question "How much is it?"
LeatherLegion replied to Leatherinspire's topic in Marketing and Advertising
Welcome to the board . Interesting and helpful read -
Quick Googke search came up with this
I have the same press but in green. ...i think i posted some pictures way back. You have to turn the round plate to adjust the height...very fine thread so it's a bit of work , but once you set it and use the same dies , you are good. The press is extremly heavy and has to be bolt it down...i have mine bolted to the floor . I also had a Lucris MA III and the green one seems to have more umph The plate's diameter is arounf 11in . Way better option than one of those hydraulic shop presses in my opinion. If it doesn'y have any cracks and everything moves smooth it'll do the job just fine Hope this helps Eddie
Bought a left/center smooth foot set few weeks ago for a 111 type machine. I had to drill a bigger hole in the left foot to make it fit. All good now
Can you please post a more clear picture of the tension discs with the thread ran through?
https://www.youtube.com/watch?v=kU0B965w62Q
