I have been using the "S" point exclusively for the longest time in my Cowboy CB4500 and Boss . For anything smaller than #138 thread i am using the LR needles in my Nakajima 341 and Singer 17-30
I have the same press but in green. ...i think i posted some pictures way back. You have to turn the round plate to adjust the height...very fine thread so it's a bit of work , but once you set it and use the same dies , you are good. The press is extremly heavy and has to be bolt it down...i have mine bolted to the floor . I also had a Lucris MA III and the green one seems to have more umph The plate's diameter is arounf 11in . Way better option than one of those hydraulic shop presses in my opinion. If it doesn'y have any cracks and everything moves smooth it'll do the job just fine
Hope this helps
Eddie
You need to back stiitch...just cutting the thread and burn the ends is not gonna work. The Jerk (hook)needle does the same stitch as a speedy stitcher or a sewing machine. There is no reason to use a jerk needle on knife sheats or holsters in my opinion
On 2-3oz i usually use an air brush , especially if using an alcohol base dye as i am trying to limit as much as i can the amount of alcohol going into that piece of leather
It looks like Tandy's buckle looks extremely similar at $1.99...but than again , they are not made in the USA like the other suppliers' so i guess the quality is not the same
If you are in the "neighborhood" you should drop by...it is worth it . The museum is inside of the store now, very clean and well organized . If you are into leather craving you'll love it ...it is a piece of leather history after all . I am not into carving but still found it interesting
I like the nylon cutting boards but the marks left by the stitching irons tend to have raised edges. When you slide veg-tan on top of them they will leave marks . The puck still has a smooth surface after used .
I just tried a hokey puck the other day . It is firm enough to give me a clean cut on the back of the lather but soft enough not to damage my stitching irons .
Try the Eco-Flo Waterstain Slate Gray. Make sure you shake the bottle , work it in with a sponge , let it dry , buff it and apply some Golden mink oil. It's not a dye but you might get the result you are looking for
