bruce johnson
Moderator
  1. Ray, I would expect that you could get the Boss shipped to England less expensively than a motorized machine, and that may be a factor. I had one of the cast iron Boss machines and liked it. For the weight leather you are talking, should do the job. Mine sewed a nice stitch, and could sew leather corners onto 1" felt pads all day without skipping Pluses - somewhat portable, can't be knocked out of time, control for every stitch, can't go too fast and run off the end, they will rebuild them for a song, easy to work on, you can train your kid to run it in about 3 minutes, good resale value. Minuses - you power it with one hand and only have one hand to hold and guide the piece, throat depth is small, tiring and boring for long runs, good for 138 and up thread
  2. Yep, they are appropriate, and very nice. I like the patterns a lot. Ever done a horsehair one?
  3. Ed, I like the halogens that Artisan sell. I have them on both my machines. I got a couple of the new magnetic mounts from Artisan at the show. They mount right around the needle shaft, and shine straight down. I think they have 7 cells and really light up the area. The combination of the two lights make my dark corner machine look like noontime. You might want to check them out.
  4. Must be the time for Bible covers. I just finished up this one. In the last few weeks I have had some requests that were a bit out of the norm for me. I did some coonhound silhouette stuff, and got this request for a Bible cover from these folks that raise show lambs. We took the logo off their trailer and I added the cross in behind it. I am quite happy the way the logo came out. I really like the new TLF Hiliters. The finish on this one came out very well. I oiled it and let it for a day. I did two coats of Leathersheen. I then 'washed it with Briar brown HiLiter about 1:3 with water. After it dried, I did a light coat of Leathersheen again. I have done this one the last several things, and am liking it a lot. I like the stitching, nice tight smaller stitches. Seeing everyone else's "fine" work has me shortening the length and using smaller thread. Now the ol' three things I see wrong with it. The letter spacing on the last name could be better. The basket stamping below the last name has a "hump". A border stamp inside the bead line might have helped it some (or busied things up, I am still not sure on that in my mind).
  5. I have one of the swivel tip cutters on the way. I'll see how it works. When I visited Russ in South Dakota last month, his dad said he has been using one for quite a while. I can do bigger curves with the brace alright with the big barrel knives. Apparently these swivel tip cutters are designed and still sold as deburring tools.
  6. 3arrows, I'll agree with Brew that better rawhide will last longer. We live in pretty similar climates out here and probably see some of the same problems. It also shows my thoughts on how rawhide has a reputation for durability that may not be deserved for this application. Rawhide edge bindings and braided horns are supposed to protect what is underneath (the leather). They are the first thing to go, and then the leather lasts much longer than the covering that was protecting it. These barrel racing saddles have had nothing more than woman's hand wear them out. As soon as the varnish wears, that thin rawhide will start degrading. In the time it takes to temper the rawhide, cut it, braid it, fuss with it as it dries, and tack the ends down, I have two leather covers done. I price the rawhide recovers twice as much as the leather replacements. Most of these have aluminum horns and no filler layer, so the horncover can loosen and twist. I drill 3 holes in the horn cap, tap it and run three countersunk head machine screws through the filler layer and cap, then cut the bottoms of the screws off flush. I go back and put on my bottom and top pieces and sew through all 3 layers to cinch them down.
  7. D Bar, Great job on the logo, and you are right. FCC is a good group. I hope these covers don't last them a lifetime. I hope they wear them out.
  8. If anyone has one of these relics I could buy or borrow, I'd be interested. I dislocated my right thumb again, and swivel knifing is a challenge with the brace.
  9. Ian, There may well have been some spacing norms, but not that I have seen written. It may have been a shop to shop individual thing. As far as patterns, I check them out in the museums. You kind of have to accept that whoever restored or put them on display might have follwed customs. The holes are generally punched near the edges of the leathers, in maybe 1/2". Most of what I see is a single lace that is fed through a pair of holes, and then each end is whipped through the holes and around the edges for the length used. The tag ends hang loose. I have seen them started at the top mostly and whipped down. Some are started at the bottom and go up. Others I have seen done in a crossing X braid, and the ends are either trimmed or left between the leathers. The lace doesn't go around the edge of the leathers in these. I don't know of there was a regional things with these patterns or not. Buckarooguide hasn't gone there yet.
  10. Jason, Thanks for the feedback. Your experiences fit with another saddlemaker that Dave referred me to. They have have used theirs about 6 months and not had to dress the blade yet. Sounds like the real deal and something that will find its way into my shop.
  11. Al, I just repaired a few this weekend. The patterns on these varied. The original maker probably used the same length as the nylon noseband they cut off. That should work. They are probably shorter than my real bronc halter pattern. The widths varied from 3-1/2 to 5" at the widest. They are just a smooth oval pattern to the center, and taper down to 1" to fit throught the loops on the squares. I didn't have to mess with the nosebands, just replace the crown (poll) straps. Some were looped through and fastened with splash rivets (wouldn't be my choice). Most had post back conchos. One had rapid rivets, I redid that one with copper rivets. If I had my druthers, they all would have copper rivets. I would use some decent weight leather. Elton's suggestion of about 15 oz combined should work just right. I stopped by and checked the lengths of these nosebands on the way home. They are from 11-13" from fold to fold. The widths are also smaller. I won't tell you how she held the ruler to measure. It seemed pretty wide when show told me them over the phone.
  12. Marcel, I would be little hesitant about Resolene based on my experience. I had it smear the edge dye (permanent dye) on a pair of stirrups. To back up, I edge-dye with permanent ink from a carton marker. I tried it with Resolene and Sharpie dyed lettering and it smeared some too. Granted, I wipe it on, usually with a sponge in thin coats. Spraying any of these would not probably smear, but might suspend some of the ink. Although I use TanKote a fair amount, I don't use it to protect anything. In my hands it makes a nice finish that is going to let me come back and clean/oil the saddle later on. I have used gallons of Leathersheen/Supersheen over Sharpie dyed lettering and silhouettes. I have attached a few examples. These are not molly-coddled pieces. The toilet lids are exposed to steam and moisture a bunch. The rope bags and cans will see more lack of care than a pool cue case, and the Bible cover is probably handled daily. These have all been dyed with Sharpie markers, even the old turquoise and "antique" silver cross on the Bible cover are from Sharpie colors. The Sheen is applied with a sponge and wiped on. I am going to do the kiss of death now, and say that I have never had it smear. If you have access to sprayer, even better. I apply a few coats, this stuff will likely never see care again. I am a fan of the Sheens for personal stuff.
  13. Two words - "servo motor". Adjustable dial for top end motor speed. More control for me at low speed too.
  14. If you have already tried this one, then ignore my suggestion. The brightest spot I have found at Weaver's is advice from Vernon. They sell/sold the 374 and I have found Vernon to be very approachable and helpful. I was looking to buy a 205-64 several years ago from another source, and ran it by Vernon to get a second opinion. He was dead on with his advice - "It is a solid machine, will do everything you need it to do, you will break some needles though, and if you don't like it, I'll buy it from you for that price". He also wasn't sure if some of the accessories for the 374 would fit the 64 (like the two rail edge guide plate), and offered free return shipping if it wouldn't. It fit. I would ask Vernon if you haven't already. That said, my experience with my Adler. Sounds like you might have some kind of hook/needle spacing issue. That was the problem with mine when it skipped, and a spacer ring shim (made from cereal box cardboard) for the whole bobbin assembly fixed it up. It moved the hook closer to the needle and reduced the pierced thread and skipped stitches. One of the mechanics that helped me troubleshoot that (Vernon or Ferdco, forget which) told me that once an Adler skips a stitch, it tends to kink the bottom thread and not loop well, and makes it harder for the next one to catch, feeds yet another kink if it doesn't catch, and so on. Take the throatplate off and cycle it by hand to see how close the hook is to the needle, how it loops, etc. Then again, most have my fixes have come from changing needles. Art's advice is always change needles first. Make sure that the right size needle is in for the thread size, and all that too. Hope this helps.
  15. Great work - again, Brent. So how's the new shop working out? What is coming out the door looks good. Seems like everybody has posted some pretty outstanding work in the last several months. Is this one for a show or a customer?
  16. Doug, Looks really good. I like the carving, and the lacing sets it off well. My wife is thinking she is needing one now...
  17. Rusty, What I can find about James Frew is that he moved to Harrison AR in 1888 and established the Frew Saddlery. It was in business for over 40 years. He died in 1939. I do a few restorations. I have a couple of my own restorations in the living room. First off with the age of this saddle I would restore it to original. I wouldn't think about riding it. The tree is probably not sized for most modern horses, the saddle has some history, and I'd honor that. If you have the stamp for the pattern that was originally used, no reason not to use it. I would try to save as much of the old leather as I could. Clean and condition, then give it some time to see what needs to be replaced. I have been surprised on a few how the old leather came back to be presentable. When you start replacing, it can be hard to match colors and the "patina", and more saddles have lost character from replacing pieces that from just leaving something. We know it is at least 80 years old, let that character show. If it is missing parts, then do those parts with the same techniques as much as possible. If you want to build one to ride with basket stamping and fancy dees, then buy a tree that is going to work. Build from new and let someone find it in 80 years and restore yours. My thoughts.
  18. Tim, Great deal. Now time for another of Bruce's musical quotes From Dave Stamey, who packed for a while. He has written several packing songs. This is the intro he gives to one of them. "If someone dies in the mountains, lay them face down over a log until rigor mortis sets in. Then you can pack them out over a mule easier."
  19. I guess I have never used soft nylon. If I am handsewing something I need a sticky thread for I mostly use the bonded poly I use in my machines and run it over the beeswax. Otherwise I buy the coarser handsewing thread on the spool from Weaver. I haven't had the problem of it untwisting or unraveling and bunching unless I cut a strand with an awl.
  20. Steve, I am seriously considering a big splitter. Depending on how the year progresses, end of this year or after the first maybe. I got the nickle tour of the new one from Artisan at the show. There are also an Artisan folk or two here on the forum, and I hope they can fill us all in with the 25 cent tour. Apparently they got the blade material figured out. What I saw in the demo looked good. You can run the motor or clutch it with the motor off and hand wheel the work through. The down side about demos, show horses, and sale horses, you always show what they do best. Jerry was cutting little 3-4" wide pieces of what looked like chrometan or oiled leather with it. He was shaving off cigarette paper thicknesses. Probably like opening sunflower seeds with a jackhammer for this monster. I have two bench splitters that laugh at that too. I can pull 7" or so of that material through my 10" Chase easy enough. I asked him about splitting wide pieces of vegtan. He said it would. (Artisan guys and gals - That would be a good demo. The guy who only needs to split 4" chrometan probably doesn't have the 20" high on his list. The guy who might run skirts or a binder cover through one does. Show us the cool stuff it does). There are some old shops that have the old wide handwheeled splitters too. Usually those are spoken for long before they are ever considered for sale though.
  21. Tex, Seems like Jeremiah's size numbers for the edgers run about 1-2 size numbers up from some of the other makers. If Jeremiah's #5 Bisonette is too small for the skirts, then it looks like you got an option. Some of those Bisonettes from Osborne are pretty wide. Carefully enlarging the hole should work, and leave enough blade to keep some strength. I saw a Bisonette a guy modified (unintentionally) and ended up doing horn covers with it. I've been kicking around adding one to my next order to try it.
  22. Andrew, That is what I like to hear - a happy customer!!! Now you know why I traded to or ordered servo motors for my machines. I don't make holsters, but I use the holster plate for gussets on things like ropebags and saddle bags. The raised center gives me someplace for the gusset to lay down into. Otherwise I have been known to sew across a wrinkle on a corner and say bad words. I use the stirrup plate for sewing some stirrups, but mostly for sewing gussets into purses, brief cases, and shaving kits. The rounded top shortens up that turn radius and makes those corners go much easier. The narrower ridge to the left of the needle slot lets you get close to the wood on stirrups. It also doesn't push over the gusset on the bag corners.
  23. LBum, Those are the style I was referring to. I just have trouble getting down in that slot to strop and get a decent thin edge. I used the rouge on a string deal, rouge on the edge of hard cardboard, and on the wider ones I used rouge on the edges of firm thin leather. Those Osbornes seemed to be the best in that style edger too. Some of them are sharpened at a pretty steep bevel. Looks like some makers cut that slot with a wheel. If they lose the "hollow" and go on through, or you sharpen them up a few times and get past it, you have a steeper draggy edge. In my hands that led to chatter marks on softer leather. For the time I spent tuning them up, I am time = money ahead to use the more open end style of edger.
  24. I have a leather thickness gauge I use. It is one of the dial gauges that TLF sells for about $30 or so. I hang it mostly by my splitters, but also use it when reducing thickness with the beltsander or bell knife skiver. Pretty handy tool to have for me. About the only time I mark for the sander is when I use the sander to "gouge" folds for checkbooks, pad holders, and that sort of thing. I mark out the margins of the gouge area on the flesh side and go to grinding. I use french edgers for thicker leather when I really need to thin a gouge, but the beltsander makes a smoother transition than the stairstep a french edger leaves. Then you skive that down. You can grind off 3 thin ones with the belt sander in that same amount of time.
  25. Simply. A splitter would be the best. You'll probably get some advice to use a round knife or skiver. If you haven't done that before with these, it isn't simple to get good results. Probably the simplest, and a method I still use on some things is a benchtop belt sander with a coarse grit belt. Keep it moving a bit, but I have almost zero scorching with the beltsander. I think the coarse grit is eating the leather off faster than it is polishing and heating up. Works well in my hands, this is also how I skive folds in belts and straps. Is that cheating?
