Reached The End Of My Rope With This
Constabulary replied to Hockeymender's topic in Leather Sewing Machines
Yep - had the same problem with my Jack Servo + 3:1 Speed reducer, always E5 Error. So I kicked out the NPS which I do not need at slow speed - its a nice feature but not that much important to me. Sometimes less technology is better. -
Operators Manual For Singer 45K76
Constabulary replied to Jwfarms's topic in Leather Sewing Machines
Check this thread: http://leatherworker.net/forum/index.php?showtopic=61619 -
Uwe - tell them they are nuts, the "real" puritans are quite cheap: http://www.ebay.com/itm/SEWING-MACHINE-73-E-PURITAN-MAID-BAY-STATE-PRODUCTS-METAL-REAL-MACHINE-WORKS-/111796656073?hash=item1a079997c9:g:WCwAAOSw9N1VvUHU This is a real heavy duty leather stitcher. Look at the mighty foot, must be a needle feed machine, it´s the well know Mod. 73E - I think you agree, right? And its even portable!!! Maybe the predecessor of the Sailrite LS Hokus Pokus
ALL 29K PARTS SOLD
Adler 69 / Pfaff 335 Binder Options
Constabulary replied to Constabulary's topic in Leather Sewing Machines
I see - well I should have checked the parts lists first. Thats the info I needed. Thanks folks -
Yet I haven´t worked with either machine so I don´t know much about the internal technical details. I know there are dedicated synchronized binder machines of either type. My question is if it possible to convert lets say an Adler 69-373 (or Pfaff 335 equivalent) into synchronized binder machine? I mean do all the machines factorywise already have the synchronizer mechanism thats is probably just covered by the arm cover? Or with other words - can I remove the plain arm cover and replace it with this cover https://www.college-sewing.co.uk/KHB69-ARM-COVER-FOR-BINDING-ADLER-69 and have a synchronized binder machine? I just don´t know and don´t want to waste money.
both shuttles and oil cup sold. I have left the 2 needles plates
You say a thread brake throws it out of time right? So I would guess either the safety clutch has released or some set screws on the hook driving gears are probably not tightened up properly. If it has the same safety clutch like the Consew 227 or Singer 111 models this Video should give you an idea: Do you have a manual for your machine? Maybe this one helps, it´s from an Consew 227R2 which is about the same as your 2700 I think. http://www.consew.com/Files/112347/PartsBooks/227R-2.pdf
- 23 replies
- adler 69
- sewing machine table
(and 4 more)
Singer 133K - Information Wanted
Grüße nach Frankfurt! Lucky you - I never have found a 133K8 in Germany, my only luck was the 133K3. Glad you found the manual useful. You can use Sys. 328 (214x1 / 214x2) needles. But you can but the original 216 needles from CollegeSewing in the UK https://www.college-sewing.co.uk/catalog/search.aspx?keywords=216 refine the search in the NEEDLES category. What needles size are you looking for - I may have a few extra. -
Busmc No6 Refurb But Missing Screws
Constabulary replied to Russodges's topic in Leather Sewing Machines
I may have a few from my restoration. All screws have numbers on the head, can you post the numbers please. I´m almost done with my restoration, maybe you are interested in it http://leatherworker.net/forum/index.php?showtopic=62817&page=1 I´d also like to see some pictures of your machine if you don´t mind. -
Well, the few straps I probably would cut with it are worth buying cut to my specs so I think selling it is probably the better deal for me. Some one interested in it $200 incl worldwide shipping? Send me PM.
Holy smokes - do they really cost about $400? I had no Idea Haven´t figured the maker yet but they all look pretty much identlical. Some have more steel parts but most are about the same style. errr -someone interested in it?
I got this strap cutter in a lot I bought from an old upholstery shop that went out of business. It´s the only leather tool in that lot but I don´t know much about the vinatge tools so I wonder if someone knows the maker. Some pictures
sorry I don´t know this machine and google does not show me pictures of it or I broke the internet
very basic information but I´d decrease the bottom tension or try a 1 or 2 sizes thicker needle
I´ve recently learned that unobtanium (thanks Wiz - always good to learn from the wise) is the material they are using for aluminum magnets. It even holds copper and brass. But it only works on the norther hemisphere if the magnet contain left turning unobtanium bacterias. I think you need the right turning bacterias on your end.
Maybe not new to everyone but at least to me. Yesterday I bought some stuff from and old upholstery shop that went out of business a while ago. One thing that came in the lot was this magnetic bobbin holder - pretty neat idea. They are still on the market as I figured. But if you have an electric router this could be a nice DIY. Just wanted to share this.
Singer 29-4 Won't Pick Up Bobbin Thread
Constabulary replied to gstqfashions's topic in Leather Sewing Machines
A few pictures would be good. Maybe the machine is badly worn - the 29-4 are very very old machines. Have you threaded the machine correctly? I´d try to adjust the spring of the shuttle carrier a little bit the way it barely touches the shuttle hook. Or maybe the shuttle hook tip is worn and you have to replace it. You also can adjust the needle holder a little bit, when you loosen the screw that attaches the needle holder to the needle bar you can move the holder a bit sideways. -
Do I Have A "complete" Busm / Pearson #6 - Or What?
pulled the bobbin winder parts off the electrolysis bath today, wire brushed them and gave them a new paint job. Still have to clean and attach some smaller parts but thats how it looks atm. -
Rigth - I just thought you probably don´t know... Sorry but I can`t help. Good luck with this machine - it´s a nice one!
- 12 replies
I don´t think a machine is in this condition is much worn. I have seen worst. Do you know how to adjust the stitch lenght?
- 12 replies
