Constabulary
  1. Abbey England has some but I don´t know the diameter: http://www.abbeyengland.com/Store/tabid/77/CategoryID/31/Category2ID/155/List/1/catpageindex/2/Level/2/ProductID/68541/language/en-GB/Default.aspx
  2. I know the 214x1 (Sys 328) have different shaft sizes / diameters and I know they are for the Singer 45K Adler 4, 5, 104,104 and so forth. I also use them in My 133K3 (no problems in general) but the original needle for the 133K3 is the 216x1 regarding the Singer manual. I just noticed that the 214x1 (328) size 200 METWAR needles (Metwar is now Groz Beckert) do NOT touch the hook whereas the thinner SCHMETZ 180 + 160 DO slightly touch the hook. it´s probably because the needle is thinner and the scarf is closer to the hook therefore. It really is a tiny tiny bit but it is barely touching no matter what angle the needle has. Sound stupid but thats what going on! The hook of the 133K is of course a bit special as it is a rotating hook and not a oscillating hook and the tip is not as sharp as at the 45K type hooks f.i. and the 133K hook tip is much wider and has a flattened side facing towards the needle so the tip may need a bit more space. So I wonder if the 216x1 has a constant shaft size and therefore a deeper scarf. I never have owned / seen 216x1 needles so I honestly don´t know the difference between the two. I hope someone know more....
  3. this could be useful too BTW - check where Adler has manufactured their Class 69 - it´s mentioned in the manual (2008 copy) Adler 69 Service Manual.pdf
  4. Got it wrong - it is the Adler 69 not the 169. The 169 is like the 227 type. Hope this helps: Adler 69 Manual.pdf
  5. same as the Adler 169 - as far as I know these were even built by Adler.
  6. Durkopp thread stand is sold - Thanks a lot! Still having the 2 Pfaff stands!
  7. Off topic but thats one reason why I like my old Singer 111 so much - all parts (and feet) are available w/o problem at very reasonable prices! And that approx. 60 years old clunker runs and runs and runs... Thats what one should keep mind when buying a machine - how is the spare parts situation and how much do these parts cost!!!! I have tried 2 or 3 Adler (67 and 167) after I bought my 111 but I alway decided to keep the Singer! The Adlers might be a bit technically advance (are they ???) but non of them was able change my mind!!! And the Singer 111´s are much easier to repair (f.i. replacing timing belts).
  8. Sorry I can´t help I don`t have this one.
  9. can you post a picture - not sure how it looks
  10. Is this what you need? http://www.ebay.com/itm/Singer-107W-143W-112W-Table-Hinge-Hook-210844-202259-/280419094123?pt=LH_DefaultDomain_0&hash=item414a47ce6b http://www.ebay.com/itm/Singer-145W-300W-Machine-Table-Hinge-Plate-2pcs-/271285513569?pt=LH_DefaultDomain_0&hash=item3f29e06d61
  11. My "secret weapon" is paint thinner or in particular cellulose thinner but I´m not sure if it is technically the same "stuff" that I use. This is what I use: http://www.ebay.de/itm/5-Liter-Waschverduennung-Verduennung-von-Recolor-fuer-Autolack-Reiniger-E0075-/201025074668?_trksid=p2054897.l4275 It is quite aggressive and resolves the paint but in case of repainting the machine this effect can be helpful. This really removes all the old grease and oil but I´m sure you have something similar in the US. I´m no chemist I just know that it works very well. BTW if you want to repaint it with wrinkle paint I heard that the VHT wrinkle spray paint is good. I have a few cans but never have used it. Maybe it will try it on my next project.
  12. I would not rip apart the entire machine, this will probably cause a lot of timing problems. I would thoroughly clean and oil it ad give it a new paint job.
  13. I have worked with both (but with reverse) and I prefer the 111 since the 211 as a very small hand wheel. But that does not mean the 211 is a bad machine, both work fine but depends on the overall condition and setup. If you can´t find a 111 buy the 211 and I´m sure it will do the job!
  14. U.S.M. thread stand ist sold - thanks a lot!
  15. I know Techsew has them online available or Cutex, Campbell-Randall, Leathermachine Co. and so forth. Shouldn´t be a problem to find them.
  16. You can download one in German language here: http://www.altenaehmaschine.com/shop/page/8?sessid=ys0ScJMFIGNhq1CupqkzLgAWOC9Ts1VT82NIt7g0qwJsb5K9ng7f75ALkxpkq4Zz&shop_param=
  17. I have a bunch of harness needles in original envelopes. I think thats how they are called in the US - we call them Sattlernadeln. I have attached some pictures. I have 7 packages in total some are size 1 and some are size 2 - overall I`d say more than 120 needles (maybe 140 or so - I have not counted them). The size 2 are about 50-55 mm long and the size 1 are about 60mm long. Some light rust stains but not too bad I´d say - see pictures - what you see is what you get!!!! I´d ask $30 shipped (registered Airmail) for the entire lot. I will also throw in some more needles for free (about 30 or more) but they are a bit more rust stained. Send me a PM when interested.
  18. I don´t recall how the Adlers look from the underside but usually the hook saddle is attached with 2 (very tight) screws. I need a picture to tell. You can also leave the hook installed, remove one of the needle and bobbin case so the hook is spinning but it is empty. Or pull the entire hook with hook shaft and gear. I cannot give you further instructions atm. But I would only do that in case you are desperate and don´t find a single needle machine elsewhere. Better look for a single needle machine!!!!
  19. A hook does not cost $400. You can get quality generic hooks for about $150 or less. You can either use the left or right needle both have a permanently spinning hook (of course) but you are limited with the accessory feet. The single needle feet do not fit for a double needle setup. You can remove one of the hook saddles and have a spare hook. But I don´t think this is the best idea - I would look for a single needle machine!
  20. I have a bunch of 4 beautiful antique / vintage thread stands made by Durkopp, Pfaff and U.S.M. (United Shoe Machinery I guess). The Pfaff with the curved top is original. I have found it exactly that way in a parts list. I first thought someone replaced the top part... I´d date them to the 1930´s to 1950´s - oldest is the Durkopp as it has the old Company sign. Here is a overview - I will post more pictures a in the days to come. Asking $40 each and $45 of the Pfaff for 3 thread spools. Or all together $150 + shipping. I will leave them up here for a couple of days before I put them on Ebay.
  21. stitching looks good so far. Good luck with the further restoration!
  22. I would assume that your machine once has been setup for a certain sewing application for the upholstery business. Usually no foot requires drilling or grinding when it is made or meant for a certain machine but everything is fine as long as it it works for you...
  23. Well - I´m sure that this was not the correct way to solve it. All 111w walking foot machines are using the same feet and there is no need for drilling. The machine was set up with lower foot lift because one of the former owners did not need a high lift. It is a machine setting problem not a pressure foot problem.
  24. yes they are water slide decals. I have used them on my 111G156 and 133K3 and some lamps. I´m satisfied. For detailed instructions contact the seller or check his website: http://www.customfeatherweights.com/decals-page/29
