Constabulary
  1. depends on the sub class. which one do you have? 7-10, 7-33 or....
  2. I can´t really help but I heard rumors that JUKI PLC gauge parts could fit but that is just a rumor, I have no proof for that. Maybe worth checking this: https://www.juki.co.jp/industrial_e/products_e/lether_e/postbed_e/detail.php?cd=PLC-1700_E Other than that I would contact KH sew or a local dealer. Maybe KH Sew knows more.... https://www.khsew.com/index.php?route=product/category&path=168_227
  3. Remove the face plate. The needle bar is clamped by 1 screw which is visible from the front. Rotate the hand wheel until you can see it through the hole. See pictures.
  4. How about reading a manual instead of watching videos? www.consew.com/Files/112347/InstructionManuals/18.pdf or here is a Singer 16 manual which is the same machine Singer 16 manual.pdf
  5. That sound IMO is not an issue. I have two JACK Servos with 750W and the earlier one is running since.... have to guess ... since 2014. They both make this sound. I´m not sure but I think more 750w motors make this sound than the 550w motors but I´m not 100% sure.
  6. I now have a Pfaff 23(w/o reverse) manual in German language - send me PM if interested. Other than this look for a Singer 17-16 manual (or similar).
  7. $75 really is not much money and this is a large hook machine and that makes it a really interesting machine. A lot of parts are still available for the 29K60 but not all. The 29K60 has a lot parts in common with the later 29K72 but there are some differences. What I can see in the picture is that the machine at least needs a new shuttle hook + bobbin and a needle plate and its hinge screw. Everything else seems to be there. AFAIK, needle plate is the same as for the 29K72 and the hooks is the same anyway. I`m not sure about the screw for the needle plate (29K72 has a pin instead) but it could be the same as for the Adler 30 machines. 29K60 parts list and and manual are available online for free. If you can´t find em send me a PM.
  8. No video that I know of but needle hook timing is very similar on most drop feed machines - however here is a Singer 17 manual. It also covers the 17-41 Singer 17-22.pdf
  9. Presser feet have to match the feed dog. This is what you find on Ebay https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313&_nkw=foot+pfaff+138&_sacat=0&LH_TitleDesc=0&_odkw=feet+pfaff+138+&_osacat=0 but the known sewing machine dealers may have more variants.
  10. I would also check the needle bar height (needle - hook timing). Could be that you have to lower the needle bar a tiny bit maybe just 1/4 - 1/2mm
  11. You can sew with 1 needle on a double needle machine but that can only be a compromise cause you are limited to 1 single foot that matches the needle space (different needle spaces require complete new gauge sets for each needle space). You can modify a 2nd foot but that still is a compromise and IMO not ideal if you want to use this machine for a longer time.
  12. The thread post / tension unit on your machine seems not to be the original part. Looks like someone replaced it with home made parts. Usually there is a hole on the underside of the bulge where the threaded post is mounted. The original post can be hammered out for the underside with a pin punch. So I`m not sure what the former owner did - maybe he tapped a thread into the bulge....
  13. First thing you have to ask your self is if you really need a double needle machine for your projects. When you know you will barely sew double seams better buy a single needle machine. I´m barely using my 212 cause most of my work does not require a double seam. I just have this machine cause it was fairly cheap back then so I just keep it. I just have the head not the whole setup (swapping the sewing machine heads in the table). I`m mainly sewing canvas and similar. I do not recall what the original needle system was for the 212 but mine is setup for 135x17 or 13x16 for leather (same needle just different needle tips).
  14. is it completely broke or do you just need some bits? I would assume that Weaver leather can help you.
  15. That is not a sleeve the face plate is one piece of cast iron. When you have all pieces of the tension unit incl the spring rest then I think the cracked piece is not really an issue. the above pic comes from this thread: https://leatherworker.net/forum/topic/109757-move-along-and-save-or-maybe-take-a-risk/ EDIT: noticed it is a picture from your thread anyway
  16. Or add a speed reducer. That slows down the speed when you start sewing and increases torque. I have speed reducers on all my machines. I have digital servos and stepper motors (you don´t have them in the US AFAIK or at least they are not wide spread). On my side of the pond (Germany) they are called "Anlasser Motor". Speed reducers add a lot of comfort IMO. Just my 2 cents. Forum search for speed reducer via Google - just to give you an idea https://www.google.com/search?client=firefox-b-d&q=speed+reducer+site%3Aleatherworker.net%2Fforum
  17. Assuming a mixture of Pfaff 28 and Singer 17 which are the same class of sewing machine and they even share the same hook (among others like Adler 48, Seiko TE-6 / TF-6 and so forth). I´m almost certain that if it is a Necchi it will use the same hook as the above mentioned machines: https://www.ebay.com/itm/142912990618 at that price IMO it is worth giving it a try.
  18. I would try some turns on some scrap leather to figure this because different machines may act differently due to sightly different settings, needle thread combination and so forth. BTW If it was me I would use a shorter stitch length on a project like yours. But that's just me.
  19. The 29K51 has a lot in common with the later 29K71 but the gear box is completely different and the pinions are no longer available. The 29K51 has a "drop out" gear box. The 29K71 manual and parts list is very helpful but as said it has a different gear box. I also have a German language Manual if you want it let me know
  20. The old Singer parts are of better quality than new generic parts from China IMO. I repaired some tension units (making one out of two) a while ago. I hammered out the stud from the rear. I think you can get replacement studs from College Sewing. Just check the parts list of your machine and check the number on the College sewing website. I would also order some spare screws for the feed dog, Needle bar, needle plate... Maybe some bobbins lint brush... they have everything.
  21. Check the below attached parts list and note the sentence "THIS MACHINE IS THE SAME AS 29K1 WITH THE FOLLOWING EXCEPTIONS:" The 29K1 is the basic machine and the other subclasses just have some small differences. 29 and and 29K are the same machine. The 29 are US made and the 29K UK made and the parts are interchangeable. The ancient 29 / 29K just differ in the accessories but the basic machines are the same. F.I. front wheel or side wheel, presence of a wax pot or not, different needle plates... I once restored a 29K1 https://leatherworker.net/forum/topic/60554-29k1-pre-christmas-barn-find/ You can modify the modern Singer 29 / 29K bell crank levers. Most parts are no longer available for the old 29K models and do not expect that modern 29K parts (as for 29K51 or 29K71) will work for the ancient 29 / 29K machines, some do but most don`t. 29K1 TO K4,K10 TO K18,K12 TO K23,K30 TO K33.pdf
  22. Here is a free English language Junker & Ruh SD28 Manual. The Pedersen 308 is the same machine. SD 28 Junker & Ruh Outsole stitcher Parts list and manual.pdf
  23. Are you talking about triple feed machines? If yes, then Adler, Pfaff and Singer have their own foot system but a lot of modern clones are using the Singer foot system. So depending on the machine model it is very likely that Consew, Seiko, Juki, Mitsubishi, Brother are using the "Singer 111! foot system. But again - it depends on the machine model.
  24. When the needle - hook timing was right at your machine and it worked properly with this setting and when your new needle bar is in you have to adjust the needle bar height. The procedure is mentioned in the manual on Page 14. Does not matter what needle system you are using, the procedure is the same. 51W51,W52,W53-Inst.pdf
