Justification for buying a real Durkopp-Adler.
Constabulary replied to leerling's topic in Leather Sewing Machines
College Sewing or Trojan Sewing in the UK are quite good sources for parts for certain Chinese / Japanese / Taiwanese made machines. But since BREXIT importing things from the UK became more expensive. -
New Member and mystery machine
Constabulary replied to piningforfjords's topic in Leather Sewing Machines
No Singer serial number IMO - I´d say Consew 226 or Seiko STW-8B -
Can´t find my digital caliper but yes, the 45K needle bar is ~0.9-1mm wider so a drill press will help
- 14 replies
- and many more
- singer 153w
(and 4 more)
IIRC the 45K and 132K foot bars have a slightly larger diameter but I can check that later today. Anyway - if you have a drill press you probably make the adapter work. If the standard Singer feet will then work with the 45K / 132K is another story. You for sure have to modify the feet as well f.i. to allow the use of larger diameter needles. Keep in mind the standard feet are rather narrow and the feed dog on the 45K / 132K are rather wide. So the foot thing is trial and error IMO but the adapter it self can be modified I´d say.
- 14 replies
- and many more
- singer 153w
(and 4 more)
Question is why do you want to adjust the foot height? I never do that on drop feed machines. I once set my foot bar top the max. foot lift and then I´m done. I only adjust the foot pressure. But maybe I do not understand your problem with the foot height. Maybe you mix up something. You can adjust the walking foot height on triple feed (aka walking foot) machines related to the material thickness. But on plain drop feed machine (like 45K25 and 31-15) there usually is no need to do that.
claes Help! Claes 8345 ( Metro Spezial / Pfaff 9345)
Constabulary replied to Arsura's topic in Leather Sewing Machines
System 81 also is LA X 81 https://www.frankfordleather.com/needles/groz-beckert-claes-81-needle.asp Or check https://www.shoesystemsplus.com -
w/o knowing what is worn we only can guess. I love the old 45K´s very much but to be honest they had their time and better machines are out there nowadays. Not saying they are useless but it depends on the job and the money you can spend. I´m still using my 45D91 and I`m still pleased with it and I do not have the output that would justify a CB3500 or even CB4500 . What are you sewing with your machine? However they still make clones of the 45K - its the GA5-1 / Cowboy CB105 / Cowboy CB2500 and it is well possible that some parts are interchangeable but I never tried this.
Separate 45k21 from table + spare part question
Constabulary replied to Redbeeerd's topic in Leather Sewing Machines
The Singer 45K jump foot system foot cannot be added to machines w/o jump foot. Well, maybe - if you have enough milling machinery and so forth, money, time and patience. Quick try for an explanation: The 45K jump foot is controlled by a notch on the cam that also controls the thread lever the 45K21 (afaik) does not have this notch so you have to to pull the top shaft to replace the cam or the whole shaft . There is a piston (kind of) sitting in the top side of the casting and the notch is pushing up the piston at the moment the foot is at its rear position then the foot releases and is jumping to the front. The 45K58 has a flat top on the casting head where the piston is mounted whereas the 45K21 doe not have this flat top. Then the 45K58 has a leaf spring on the rear (just like the Singer 29K4 f.i.) and that requires a special mounting which the 45K21 machines do not have. Not speaking of possible the differences in the casting on the rear side to accommodate the moving foot bar and differences in the face plate.... This is just what comes to my mind... BTW The check spring indeed is broke or missing. College Sewing in the UK has them: https://www.college-sewing.co.uk/parts-by-machine/singer-sewing-machine-parts/singer-45k-parts You either need just the inner part with the thread loop or both parts. -
Just what I can tell from the picture: Machine appears to be in very nice condition overall, however, I do not see a presser foot and the needle hole throat in the plate is damaged and the machine seems to be not correctly threaded. I´m not sure if the check spring is there (or broke) cannot tell from the picture. At least the thread is not going through the check spring - thats why I think it could me missing or is broken. It´s not a walking foot machine. It is a plain drop feed machine. -
The 45K machine has an oscillating barrel hook but no rotary hook. Hooks are available on Ebay as well but College Sewing indeed has some 45K parts in stock - not many though. But in case you will order from them order make sure you buy a the 2 components of the check spring as spare - better too have than to need. I would also buy 1 or 2 thumb nuts for the tension units as well (same reason). If you cannot find the parts enter the parts number form the parts list BTW the 45K tension unit on Ebay (for GA5 machines) do not work properly - guess how I know. If you have pictures of the machine please post them so maybe we can detect missing / broken parts. -
Google is your friend (sometimes) here is a download link for the manual: https://ismacs.net/singer_sewing_machine_company/industrial-manuals/17-22&17-23-manual.pdf Pictures will help to visualize your machine issues.
Help with old Singer cylinder arm machine
Constabulary replied to Metalhorseman's topic in Leather Sewing Machines
The predecessor is the Singer 107w50. I think it shares a lot of parts with this machine. Yours just has a more modern casting. I think it is late 1950´s -1960´s made. The predecessor flat bed version of your machine is the 107w1, 107w2, 107w3 and the like. The flat bed machines for sure share some parts with the cylinder arm version a s well. I´m almost certain that the instructions for the 107w50 will help you a lot with your machine. https://www.manualslib.com/manual/364298/Singer-107w50.html?page=6#manual -
How to make a USGI M1916 leather holster?
Constabulary replied to Tango99's topic in How Do I Do That?
I have these Mil. Spec. pattern files. Do not recall where they came from - not sure if they help you. I have more but cannot upload them - files are too big -
Advice on Singer 34K11 or Adler 5-6
Constabulary replied to Gryning's topic in Leather Sewing Machines
do you have a picture from the left side / the face plate so we can see if parts of the tension unit are missing. -
Part needed for a Singer 21w180
Constabulary replied to stitchbystitch's topic in Leather Sewing Machines
do you need just the hook or the hook + hook saddle? If just the hook I probably have an idea but you have to remove the hook from the saddle first so that I can see the bottom side. -
Don´t know where you come from but I restored my 29K71 with parts from College Sewing and they were all fine except the shaft for the front drive (no drilled pin hole). But bit by bit I replaced all non OEM parts with OEM Singer parts but thats a different story. The encircled thingy IMO is parts of the darning device.
Wiz, the 34K11 subclass it the much heavier subclass in the 34K range. The upper arm and hand wheel are from the 45K and it has a larger hook than the other 34K's (like 34K5 or 34K1 or the like). It is using the 214x2 / 328 needles. -
Yet another request for identifying
Very similar to Singer 96K. -
When you want to pick up the bottom thread you have to hold the top thread with your fingers. Send me a PM with your email address so I can forward you a manual for the 34K11 - file is too big to attach here. I think 12mm is pretty much the max. you are able to sew with either of the machines so keep in mind that with 12mm material thickness you run them at their very limit! Not sure if the 34K11 will be good at this at all with it´s rather narrow feed dog. -
I agree and most likely a touch up could make it look even worse cause you will most likely not find a 100% matching paint and the original paint is already a bit aged so that makes it even harder to match...
Some pictures of the machine would help so we know how it is set up. But usually yes. Roller foots are fairly cheap an on this machine class they just mount where the regular presser foot is mounted. Depending on the roller size you probably have to adjust the foot bar height. https://www.ebay.com/itm/165207112611
You cannot retrofit a walking foot to sewing machines. There are "top feed" attachments for certain domestic machines but that is not even close to what is considered as a walking foot (aka triple feed = bottom feed + top feed + needle feed) in the leather trade. The 17-30 is a light - medium duty cylinder arm machine with drop feed and reverse. Some may have a roller foot some may have a straight presser foot. They have a long beak shuttle with fairly small bobbins.
The download link is in the 1st post here: https://leatherworker.net/forum/topic/78444-download-singer-132k6-seiko-sk-8-manual/
Claes 8345/34 Patcher Needle Size
Constabulary replied to Kristian99's topic in Leather Sewing Machines
I do not agree that the 34 subclass is the "heavy subclass" - see above list of sub classes. The 34 is the same as the 30 but with motor stand. The motor stand makes it a 34 everything else is like the 30 incl. needle System 88 - the head only w/o treadle or motor stand is the 30. Check the list. IMO the heavier class has the higher foot lift as well, meaning the machine that takes the 214 needles should have a 15mm foot lift. Thats at least how I understand the subclass list. But I`m maybe wrong. How high is the foot lift on your machine?
