Yet another question about my Pfaff 545 - tension.
Constabulary replied to LePoisson's topic in Leather Sewing Machines
For what ever reason you may have a top tension release. Do you have a knee lifter you ever so slightly push the knee against when sewing? Or pedal for lifting the foot you rest your foot on when sewing? That MAY cause a tension release. Just a guess... Just to try something... You see the black disc right behind the thumb nut - remove it and put back on the beehive spring and thumb nut and try again. This way you disable the tension release entirely. There is a tiny pin behind the black disc - don´t loose it. Is just to see if there is a change when sewing, it reversible in a few seconds. Have you checked the needle hook timing? Just to make sure the machine is set up for 134-35 needles. Needle scarf is facing toward the hook right? -
Cobra class 26 Bobbin tension??
Constabulary replied to Jakek1978's topic in Leather Sewing Machines
well, the tension parts on sewing machines have not really changed significantly so I´m sure it is the balance between top and bottom tension you have to figure other than that make sure the top thread comes off the spool w/o hanging and nothing in the top thread path is causing drag or additional tension. -
if you cannot find a manual look for Singer 7 manual (flat bed machine instead of cylinder arm). There were some different models but I´m sure one will be close to your Singer 11 in terms of the operational / control parts, threading and so forth.
In 7 years it is well possible that the needle bar has risen a little bit. I´d check the needle hook timing and probably lower the needle bar a tiny bit.
I would check the hook area for thread bird nests so similar. Service manual is available online - maybe it helps: https://www.duerkopp-adler.com/fileadmin/dag/Media/Downloads/176/S_179_EN.pdf
Threading the bobbin case is mentioned in the manual (not super clear pics though) https://www.manualsbase.com/de/manual/578012/sewing_machine/singer/307_g/ Other than that the hook is the same as on 107w and 143w so their manuals work in that regard as well.
I´m not sure if sandpaper is the best solution. For obvious reasons the last thing you want in your machine is sand. Better use thin felt discs or bobbin case stars https://www.college-sewing.co.uk/catalogsearch/result/?q=490468+ I´m also using stars and older type Singer springs - not sure if they are still available: https://leatherworker.net/forum/topic/88778-singer-153w101-bobbin-case-is-stuck/?do=findComment&comment=607136
- 22 replies
- 111w155
- threading the tension disks
(and 1 more)
Guess why I love Singer machines and Singer based machines so much However the linked Adler feet are made by Kwokhing which is a quality manufacturer and the linked Singer feed are of unknown make as it seems.
Dürkopp-Adler has reworked their main website and a lot of older content is no longer available. Figured this with their formerly available "Sewing Lexicon". Many manuals are available here (but not all): https://www.duerkopp-adler.com/downloads
most likely for luggage making. maybe worth checking the Ohio Travel Bag website maybe you find something similar https://ohiotravelbag.com/
Brother LS3-C54B-050 Cylinder Help
Constabulary replied to Marcie's topic in Leather Sewing Machines
Well the ancestors of this machine are the Singer 153w for the bottom part and the Singer 211 for the top part. The stitch length lever is of SEIKO origin I guess. Nowadays Seiko is still making machine that look similar the bottom part I´d say is Seiko CW Series and the top part Seiko LSC series to stay in the cylinder arm section (flat bed would be LSW Series): https://www.seiko-sewing.co.jp/en/model/cylinderbed/ A nowadays clone is the Consew 287RB - you can be sure it is almost the same machine (if not entirely) as yours - maybe with minor differences - maybe. You´ll find an instruction manual and parts list in the below link: https://www.consew.com/View/Consew-Model-287RB-2 You can be sure most of the parts for your machine are still available cause a lot of the clones are based on older Singer machines. Same thing with the feet. Look for Singer 111, 211, 153, Consew 227, Seiko CW, LSC, Juki 562, 563 and many many others are still using the same Singer feet that your machine is using as well. Hope this helps -
Fraying/breaking top thread on 111-155
Constabulary replied to blue duck's topic in Leather Sewing Machines
slightly larger I wanted to write -
looks like your needle bar is missing the tread guide. I would also try lowering the needle bar a tiny bit even when you think the timing is right. That makes the thread loop a little bit wider when the needle rises - worth trying I´d say. Furthermore - you have installed a hook for heavier thread. There is a variant of this hook for lighter thread as well. Not sure at what thread size it is recommended but it is an option. The difference is a small raised tip on the hook gib. But different hook would be the last thing I would try. See pictures Have you tried heavier thread in the bobbin case - meaning #92 top and bottom? Maybe try a slightly needle like 130 metric. -
Presser foot climbing adjustment, is it worth it
Constabulary replied to Waldog's topic in Leather Sewing Machines
well, depends on if you need the comfort of this knob and how often you really adjust the foot height. On my machine I have set it to the highest lift and never went back. Usually all triple feed machines have some sort of foot adjustment. Most have some sort of cam on the rear some have a push knob on top of the machine... Just different systems. -
You cannot adjust the needle bar height on Dürkopp patchers cause it has no "go through needle bar clamp" Even if it had a "go through clamp" (some CLAES patchers had this) going from shorter to longer needle is easier but from longer to shorter is not always possible due to the given length of the needle bar - you know what I mean? 135x16 needles are shorter than System 88 needles.
My attempt to enter the machine sewing world
Constabulary replied to Tio's topic in Leather Sewing Machines
You can DIY speed reducers 45mm Pulley 130mm Pulley piece of 15mm shaft (15-20cm long or so) 2 pillow block bearings for 15mm shaft some wood from crap box some screws, nuts & bolts some DIY skills Shaft, pulleys and pillow block bearings are from Ebay. I made one for my Singer 51w setup. But there are many other samples for DIY speed reducers in the forum. -
You are welcome - so what did the trick finally? 332 is too short - 657 is the same as system 88 but with a different tip but that does not matter really. 332 LONG is as long as the 88 but has different shaft diameter but they may work if the hole in the needle bar is wide enough. As you figured - these ancient patchers can be challenging So the 2 options are System 88 or 332 LONG - I would go with 88. You can get them from Shoe System Plus https://www.shoesystemsplus.com/Claes-Model-30-Needles-10-per-pack_p_353.html
I always chose price + shipping: Lowest First But you can still find lower offers down the list f.i. when the listing has multiple variants like sizes (screws for instance). BTW - Are you aware of "Dynamic Pricing"? Sometimes prices on certain online marketplaces or web shops can be different depending on times, days (weekends vs. Mondays or in advance of holidays) or what device (lets say old Win 7 PC vs. latest Apple Phone) you choose for shopping. And - believe it or not Ebay is often cheaper than Amazon. I do not recall when I bought on Amazon the last time. I often compare prices before buying and my experience is that Ebay is cheaper most of the times - sometime other web shops but seldom Amazon. May depends on the products but thats my experience. Just recently - I needed a capacitor for my air compressor. Ebay was cheaper and fun fact - when I looked the sellers other listings (German Seller) I found the same capacitor listed in a different country (Ebay Spain) and it was 1.65€ cheaper than on Ebay.de. Sure not a big amount of money but still 30% cheaper @ 5.50€ vs. 3.85€ - but sipping was a little more - but still. And I figured Chinese sewing machine parts are often cheaper on Ebay.com than on Ebay.de from the same seller (has multiple accounts) that saved me ~12€ recently. I´m not counting pennies but over the time you can safe some good $ and buy other things.
maybe for some Flintstone style bikinis
Adding reverse to Class 7 Singers
Constabulary replied to James850's topic in Leather Sewing Machines
oooouh - too bad! -
Not sure what you want to do first. In case you want to check my 1st suggestion then you have to take the machine head off the stand (mounted with 3 screws) and tilt the machine to have access to the rack. ==== The cam is held on the top shaft by 2 large square head set screws - you see both in your pictures. Make your you mark the position of the parts you move in case you have to reverse the adjustments. Also make sure you know at what point the loop is formed. Watch the cycle of the needle bar (see Video from 9:20 onward). The needle rises from bottom dead center a little bit, then stops and goes down again a little bit then rises again... Make sure you find the right point where the hook grabs the thread... Again I only can guess cause I do not know your machine - you are on your own when you turn screws and make adjustments. Keep that in mind! My experience with this machine is very limited but I have restored several other pachter machines but only once a Durkopp 18.
I´m pretty sure one or more cams on your machine are not correctly installed. The Adler 30 and Singer 29K patchers are very simple machines there is not much that can go wrong. I would check the position cams. EDIT: Bob was faster Check your other Adler 30-1 thread. I mentioned the cams there already. Everything on this machine is controlled by 3 cams, one controls the arm lever / needle bar, one controls the shuttle driver / timing and one the foot lift / feeding. So you can be sure the major problem on your machine is one ore more incorrectly installed cams.
Pfaff 335 H2 complete rebuild thread
Constabulary replied to Woehlk's topic in Leather Sewing Machines
Would not repaint it either but I repainted machines that others wont repaint as well so do not listen to me In case of reselling (now or later) original painted machines usually bring more than "obviously refurbished" ones or machines with a "personal touch". Holy smokes are you well organized. I usually put all parts in one bin and go from there -
I have not much experience with Dürkopp 18 I just restored one once and never really touched one again. So I only can tell you what I would TRY in your case (not knowing details or the overall condition of your machine). There is a rack with a roller and with a long squared cutout coming down from the big cam on the rear (see end of my video) it is attached to the long rack with the thread hook that goes from back to front in the bottom arm. Maybe you can try to "reposition" it a little bit. I unfortunately do not recall enough of this machine to give you many advice. Another option could be that you bring the hook to it´s foremost position where is is supposed to grab the thread loop. Then loosen the set screws on the big cam in the rear. Then hold the cam with your hand (if not seized) or a pipe wrench or pliers (be careful - do no damage the cam track) and rotate the hand wheel until the "timing is right". As far as I recall the cam was not pinned. I know this is not very precise but there just too little information about this machine. I recall that I had to reposition the cam that controls the thread lever a little bit on my machine but that was trial and error too I hope this help or at least gives you some ideas. Maybe LW member SHOEPATCHER knows more.
Maybe worth checking Renia Aquilim 316 or Aquilim SG
