thekid77
Everything posted by thekid77
great advice, thank you...yeah, I was pulling by the thread and not the needle, but the thread was really slick nylon, so there is a tendency for the thread to want to just slip out of the eye of the needle.... I was leaving a two inch tail on the short end....your suggestion of leaving more thread on the end is genius!! thank you
I don't know about buffalo, but I use a dremel w a 220 grit drum on vegtan to even edges....then i go over the edges w 400, 800, then on to burnishing...if u use too rough a grit you will pull fibers up and u won't get a clean edge...my best advice is try starting w 220 on some scrap, then if thats still too rough go to a higher grit...hope this helps
After threading the needles the usual way, thread thru the eye, poke thru the thread, and pull to lock, the thread keeps working its way out of the locked position and coming out of the needle... anyone else have this happen?
Sharpening Awl--Point So Fine It Bends--How To Remove?
thekid77 replied to thekid77's topic in How Do I Do That?
great information, thank you so much for sharing your knowledge!! :D -
Thanks Bill, that helps a lot...unfortunately I only have an 800 grit stone which is the finest stone I have....after that, I have to use wet/dry sandpaper....seems to work but I was just wondering how to get rid of that flappy piece of metal. Thanks again -
hi all, when sharpening my awl, i noticed that at the very tip, it comes to such a fine point that the metal (a very small portion) is like foil and just bends.... how do i remove this?? i have tried stropping it away on leather and its still there...it just bends back and forth, and makes the awl unusuable since it catches the leather when piercing it... on one of my other awls, i had the same problem, and i tried running the foil tip straight against a fine grit sharpening stone, and I seemed to be able to sand it away, but i dont know if this is the "right" way to do it... any suggestions are appreciated thanks!!
I agree with the others, looks like the edges might not be exactly flush with each other, so try sanding them flush....one way I can tell if the edges are even with each other is if you take the project out into the sunlight, if one side of the edge is higher (uneven), the light will cast a shadow as you turn the edge back and forth in the light....you will clearly be able to see if they are dead flush or not (you'll see what looks like a little valley in between the edges).....this is what works for me, hope it can help you
- 10 replies
- edge finishing
- pigskin
(and 2 more)
with regard to wetting the edges, rather than using a dauber, which tends to hold lots of liquid, you could try using a Q-tip dipped in water and roll it over the edge to dampen it...this works for me, and the Q-tip seems to provide lots of control in terms of the amount of water applied and where exactly the water is applied (so you don't wind up getting any excess water onto the grain/flesh of the leather where you don't want it...just an idea, hope it helps ps if I'm burnishing thinner leather, I'll touch the Q-tip onto a paper towel briefly just so I don't over-apply the water
although I'm no expert, my guess is that there is some sort of lining material like a pigskin in between the layers of leather... here's my experience with edges...the more time you take with them, the better they look...what I mean, is that if you want glassy edges like that, you must be willing to spend some time going over the edges with a few different grits of sandpaper...I even edges out with 220 grit on a dremel, then I go over the edges with 400, then 600, then 1000....don't go to the next grit until the current grit you are using has "cut" the entire edge, and sand in one direction only.....after finishing with 1000 grit, I dye the edges. I take a Q tip and dip it into some dye, then roll the dye onto the edge....don't soak the edge, just coat it...then I'll take a piece of old denim and slick the edge in one direction with it until it shines. After, you can slick some saddle soap onto the edge, and repeat with the denim. To seal the edges, you can use a light coat of resolene cut 50:50....after the resolene dries, hit the edges with the wood slicker. Resolene will harden and seal the edge and help lay down any loose fibers....don't apply it to thick though, otherwise if the edge bend you will have a cracked plastic looking edge. The key with resolene is cutting it about 50:50 with water....comes out to thick straight from the bottle. just my process, patience is the key to good edges...hope this helps
Destroying Projects With Stitch Groover :(
thank you for sharing your experience Michelle, I may just abandon the groover altogether Thank you, do you mean that you put a crease in the leather with your compass? LOL...I admit that I knelt down in unspeakable frustration after I screwed up my last two projects hahaha...thanks for the humor lol, they do tend to survive through the ages... thank you, by guideline, do you mean a line scribed onto the leather, like with a wing divider? or an actual physical guide template that you can follow with the freehand groover? thank you! -
Thank you all so much for sharing your thoughts and experiences!!! I appreciate it so much!! :D exactly same problem for me, i will try doing this, thank you great tip Bruce, I will be practicing that technique...thank you!! :D yeah tandy tools aren't the strongest and usually come fairly dull out of the box..thank you for your input I groove before I edge as well, I was just mentioning that before grooving, i sand the edges so that they are nice, smooth, and square so that the guide foot of the groover doesn't get hung up on an uneven edge...but my technique is poor and I still need lots of practice...thanks for the advice!! -
Today I completely ruined two projects (card wallets) with an old osborne compass style groover I was so upset and frustrated I just felt like quitting... I made sure to get the edges of the leather nice and square, and perfectly smooth...I rounded off the corners and started to make the groove. Turnng these round corners seems to be where I get hung up. I have tried turning the project instead of the groover and nothing seems to work. I'm a pretty patient person, but it took me a day's worth of work to get to the point where I groove, only to find out that I ruin my projects Here are the routes I see...1). stop grooving the leather period, 2). use a creaser instead, 3). try a different groover (but I can't afford a new tool at the moment) Anyone have any suggestions? Im stuck...
My First Wallet
thekid77 replied to alackofcolor's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Beautiful work!!! A couple questions...what type of thread are you using? and what brand/size awl blade are you using for your wallet? Thanks -
Phone Pouch
thekid77 replied to Trevor's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Fantastic work Trevor, I'm inspired!!! -
To Belt Makers: What Is The Proper Formula To Measure For A Belt?
thekid77 replied to Jess Jones's topic in How Do I Do That?
May I also humbly suggest Ian Atkinson's tutorial...very simple way of measuring a belt for anyone, any size...he's a very skilled leather craftsman and very generous with knowledge as you will see if you check out his other videos on his youtube channel Hope this helps!! Skip to about 6:30 mark for info on hole spacing and sizing... http://www.youtube.com/watch?v=YpEmkRlv1Uo -
Hey folks, When hand-stitching an item with a long run of stitching, eg, belts, how do you keep the line of stitching looking neat and uninterrupted if you have to change threads? or do you just use one super-long length of thread? I am curious because I have seen many hand-stitched belts where the part where the person changed threads is either invisible, or non-existent... Thank you in advance for sharing
I put a light coat of neatsfoot oil onto the leather while the leather is still damp from dyeing. The leather pores will be open and more receptive to the oil while damp. I noticed that dyes tend to dry out the leather a lot and I think that can aggravate the wrinkling... Let the dye dry completely, and you can add a second light coat of neatsfoot oil onto the leather. This time, gently begin to flex the leather and you will notice that it will not wrinkle as badly. Just remember, any time you flex leather to the extreme, you are stretchng it out and you will get some wrinkles no matter what, but the oil will make the leather more supple and less likely to wrinkle badly.
I can't believe that nobody replied to this!!! I love the design!!! I have never made spur straps before, but I really want to start making them....I hope I will be able to be as creative as you Awesome!!!
They look awesome!!! I want to start making straps soon!!!
I use a compact disc as a guide and make the cut with an x-acto knife. I don't try to cut through the leather all the way on the first pass, rather, I make 2-4 light cuts, one over another until I get all the way through the leather... The disc may or may not work for you depending on how much of a curve you need. It works well for the pockets of card wallets that I make. Hope that helps!!!
I went through the same frustration as you did a few months ago with the same thing...here is what I found that worked for me... Please refer to the first picture for a list of things that have been helpful to me: -Green Chrome Polishing Compound (usually available at any hardware store) -Paper business card with green polishing compound rubbed onto it (the card has to have a paper surface, not one with a glossy finish) -300-400 grit sharpening stone (this is just for grinding your starting edge on the awl blade) -600, 800, 1000, 2000 grit sandpaper -a flat surface, preferably a piece of steel, glass, or granite (not shown) Although the Tandy awl blades are definitely not the best, I have had success in sharpening them by using the following procedure: In the case of a new awl blade from Tandy (which are dull as a butterknife), I fix the blade in the awl handle, and go to work on the 300-400 grit sharpening stone using the technique illustrated in the second photo. Two keys to the sharpening technique from here on out that are ABSOLUTELY CRITICAL: 1. Keep each flat side of the awl blade FLAT against the sharpening surface (refer to the second attached photo) 2. Work each of the four sides of the awl blade back and forth on the sharpening surface an even number of times Once the edge of the awl blade is ground down fairly thin, you can move from the stone to the sandpaper. You will notice that there are lines (scratches) on the metal from the sharpening stone. Those scratches need to be gradually sanded away using a finer and finer grit progression of sandpaper. Any imperfections such as scratches, even the most minute scratches will prevent the awl from going through the leather smoothly... Starting with 600 grit, place the sandpaper on a flat surface (metal, glass, or granite) and work each of the four sides of the awl blade in the same fashion as you did on the stone until you see the scratches from the sharpening stone disappear (those scratches will be replaced by finer scratches of the 600 grit). Once you've done this, repeat the same technique with the 800 grit, then with the 1000 grit, then with the 2000 grit. Now take a paper business card, place it on a flat surface, and rub the green chrome polishing compound over the entire surface of the card (until the card is green). With the card still on the flat surface, you will take each of the four sides of the awl blade and work back and forth over the card (just as you did with the stone and the sandpaper). The green chrome polish is much finer grit than the 2000, and what you will notice is that it will provide the awl blade with a mirror polish. You will notice that as you work each side of the awl blade over the business card, it will leave behind black marks on the card. That is a good sign that the polish is doing its job and smoothing out any remaining scratches caused by the previous grits of sandpaper. One caveat: Do not rush from one grit to the next, or you will never get the little scratches out of your awl blade. The idea is that you make an investment in your time now to save time in the future. After you've finished with the green polish, take a scrap piece of leather on a flat surface, and work the blade in the same fashion as you did with the stone, sandpaper, and business card. All you are doing is polishing the blade. Finally, when you get ready to pierce your hole in the leather, tip the blade in some paraffin wax every so often and it will allow the blade to slide through the leather even more smoothly. If you can't see your reflection in the awl blade, it could be sharper. I am in now way an expert at sharpening, but this is the technique that has worked for me. Please forgive my explanation if the steps are difficult to follow. I would be happy to clear any confusion up if you just ask Good luck!!
+1 to Nigel's video
