Everything posted by Halitech
	Now you've gone and done it Jeff, you forgot about the pansexual and asexual in your alphabet soup When I was a kid (and no, we won't go into how long ago that was), you were either a boy, a girl or you were gay. Now, there are more letters in that alphabet soup then you can shake a stick at. It's no wonder the kids growing up today need safe spaces to retreat to when someone says something they don't like, words hurt them more then sticks and stones do and they grow up confused from the time they are born. Oh, and transgendered means they were born with a stick shift but feel like they should have a slot machine which is supposedly different then being a guy and being gay :shrug:
	I'm not an expert on holsters but I think you'll find the holster will loosen up because the stitch line should be closer to the gun. Any chance of seeing the backside? with the mag holder, I would have added a back piece to protect the ribs from being dug from the end of the clip
				Fire department radio pouch
Halitech replied to JNewkirkct's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Nice work and design. 2 things I noticed though. 1, the mic strap should be up higher to the shoulder so they don't need to unclip it to talk and 2. When doing the name, you pressed too hard on the arbour press handle because you can see the square from around the letter. -
	looks better then some of my first ones. A suggestion though, turn the adjustment buckle around so the tail hangs down instead of pointing up. It's a small thing but from what I've seen on most others, that's the way they have it. I don't use buckles but works the same on the same brown studs I use for adjustment.
				top coat for natural veg tanned color and strength
Halitech replied to jasonmccluer's topic in How Do I Do That?
the reason your belts aren't being protected is because NF oil is NOT a protectant. It's to put oil back into leather that has been dyed or wet molded and has lost moisture. Nigel (I think it was him) did a test on multiple finishes, both for water resistance and color change (if I remember right) and resolene was the best option of the products he tested. Resolene also has the benefit of blocking most UVA/UVB rays so it prevents the most effects of being in natural light. Most finishes won't protect the shape, stitching the edges will help some though. -
	what would a full set of these cost if a person was so inclined to order them?
	if you put the resolene on then antique, there won't be anything to keep the antique from rubbing off so you will end up with a hack of a mess (I hope they don't wear them with the wedding dresses) so you need to put something over the antique. Normally, supershene is the finish of choice before applying antique. far as the back side, if I'm not dying them, all I do is apply sno-off or a wax mixture I have and melt it in with a heat gun. Prevents the sweat from your skin penetrating very much (you will be hard pressed to make the leather completely waterproof)
				iPad Pro sleeve
Halitech replied to Shed's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Dip dying is a good idea. I will sometimes use an airbrush but I find if I go in a circular motion instead of straight lines, I don't get as streaky of a job. You could have "beefed" up the protection factor by putting a liner of foam between the liner and the outside. I use kitchen drawer liner on some of my items. It's about 1/8" thick and soft so you can double it up if you want/need to. -
	Decided to use a few parts that were given to me by my parents old friend. The leather is 2-3 oz which is why I lined it with the mission grain pigskin. I couldn't believe how easy it was to install the segma snaps. It was like I breathed on them and they were installed. Compared to the tandy pieces I've used, these ones are a dream to work with, shame they are no longer made like this. The leather is new, everything else was from the 60 year old stuff
				First Axe Mask completed
Halitech replied to KurseD's topic in Gun Holsters, Rifle Slings and Knife Sheathes
if you have any doubts, pick up or use a small air brush and spray on thin layers and then you shouldn't have to worry about it -
it doesn't "eat" the dye but if you don't let it dry really well and buff it till your arm falls off, it will move the pigment around that is sitting on top of the leather -
	I'm there and awake now
- 100 replies
	different tanneries, different weights, different areas of different hides will all react differently. Best you can hope for if you are dying yourself will be close.
				64 year old wallet interior
Halitech replied to Halitech's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I have the log letter craftaid as well. This stuff is a treasure trove of patterns and things- 7 replies
- 64 year old
 - wallet
					(and 1 more)
I've got an email into the local tandy dealer to see if he can find out when it may have been sold for sure. If they can verify it, I may put it on ebay and see what I can get out of it for the unused one- 7 replies
- 64 year old
 - wallet
					(and 1 more)
	how much for 5 of the black bellies with shipping to nova scotia canada?
I have 2 more of the liners plus a bunch of craftaids designed for that size wallet. There was also a craftaid for what looks like log letters in 3/4" size. I'll probably sell them in a show if I can- 7 replies
- 64 year old
 - wallet
					(and 1 more)
- 7 replies
- 64 year old
 - wallet
					(and 1 more)
	From the bag of goodies I had dropped off yesterday, the first item I decided to do. A 64 year old wallet interior from Tandy leather that had an original price tag of $1.20. I married it to a plain black back and did the Mexican round braid on the edges. Just wanted something basic to go along with the age :D
- 7 replies
- 64 year old
 - wallet
					(and 1 more)
	Ahh okay was hard to make out so wasn't sure if it was a brand or your initial or what it was. I've made changes midway through a build as well and sometimes you have to and be damned the tooling you already have done
	very nice work and the natural color really looks good. Only suggestion would be to move the oval with the initial? up an inch or so so it's not hidden by the buckle.
	if you do a first burnish with just water, most dyes will still penetrate. Once you do it with gum trag, it's almost like sealing it with wax and you'll have a hard time getting it to dye.
				Show off
The oldest book I can find a date on is 1958. That was 13 years before I was even born lol There are also 4 different craftaids for wallets and 2 different 3/4" letters, 1 is even in log cabin style so I'm gonna have to try that one out I took a quick look and there is a swivel knife in there with 3 different blades, including 1 that looks like it's brass, a sharpener for the blades, an edge creaser and more. I'll get a pic tomorrow when I can lay things out on the table. -
				Show off
He didn't want anything for the stuff, just wanted to pass it on to someone that would use it
