Everything posted by Halitech
first, neats foot oil isn't a finish second, latigo is already about as water resistant as leather gets third, your question has been answered a few times so a search would have found your answer
this is the leather they used https://www.tandyleather.ca/en/product/assorted-double-shoulders-5-oz?sSearch=9048-60 it's 5oz so anything from 4-6oz should work fine.
use a ruler and an awl to make a straight line, then punch with your irons and finish making the holes with your awl. If you are using pricking irons, they aren't designed to go all the way through (just in case you weren't aware )
looks good and will get better as you practice. Far as the stitch grover, it's more important to have something to get the line straight then it is to grove out the leather.Depending on your style, you may or may not use it after you get it. I started out using it and now, I never touch it. Are you using an over stitch wheel, pricking irons or stitching irons to mark your spaces?
Can leather be tooled after resolene has been applied?
Halitech replied to thekid77's topic in Leatherwork Conversation
unless you can get the resolene off, or have access to an unfinished backside, not going to happen. The resolene will stop the leather from absorbing water which is needed to tool. You may get it to soak in from the back but even then the tooling won't be as crisp as you would probably hope for -
Welcome to the insanity lol Good luck with staying dry and there are lots of helpful people around here willing to help. Looking forward to seeing your progression
not sure what carat essence is but neatsfoot oil is not a finish. A finish is something like resolene, tankote and supershene. And if you want better quality products, start with better quality leather. Springfield leather is one, weaver leather another, or go big and order direct from the tanneries
@Mattsbagger there is a chart at the bottom of the page. 1.4mm is 3.5oz Usually splits are what they use to make suede/prints/etc so they put an artificial top on 1 side of the rough side
I'd be interested in helping out but what's her budget amount? Not going to spend time to only make a dollar after materials are paid for.
Welcome to the insanity called leather working The classic double shoulder you are looking at is, as suggested by the category it is listed in, is finished so it will not accept tooling, dye or any other finishes. The other one will. And like cj, I've had good luck with my leather purchases from tandy but I always go in and pick over the leather to get what I'm looking for instead of having them ship me whatever.
Sleeve for a Yeti style tumbler
Halitech replied to Sofaspud's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
the tri weave is the hardest to master but once you get it, all others are easy. I like your color combination and your letters. Only thing I would point out is the ends where you laced it together. On the next one, put your edges together and make sure they are the same size before you start doing any carving or tooling so you don't have 1 corner sticking out and not being inline with the other edges. -
use double sided tape or glue the pieces together first. Then punch/stitch
Depends on just how crooked they are. If it's just a little bit, you could. If it's a lot, probably not
dye the purse black jk but so far, I've not found anything to remove it
Coin Purse Designs
Halitech replied to Sheilajeanne's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
cutting it out, that's the easy part. Getting all the fold lines in the right place, that's the hard part :/ -
Coin Purse Designs
The only 2 things that come to mind for me are these: https://www.tandyleather.ca/en/product/squeeze-frame and these: https://www.etsy.com/ca/listing/498438190/vintage-tooled-leather-coin-purse-with?ga_order=most_relevant&ga_search_type=all&ga_view_type=gallery&ga_search_query=leather coin purse&ref=sr_gallery_26 -
for belts and holsters, the 8/9 is all you need. For wallets, you will want 4/5 for the backs and 2oz for the inside or you'll be sitting on a really thick item. I bought the cheap one from tandy and it works great for items under 3" wide
I'm sure Chief and Rohn and a few other oldtimers will be glad to hear that about the lace so they can stop using it after 40 years. If your lace is brittle, maybe it's a problem with your lace as some people use it on holsters for every day carry and they don't have an issue with it breaking. I thought maybe you had an issue with transitioning from a single layer to 2 layers on a corner or just don't like doing corners at all.
neatsfoot oil is not a finisher, it simply adds oils back into the leather that dying and tooling removes you want leather that is flat on the flesh side. If it's hairy or stringy, it's lower quality. See NVL's response about armour all I use Aussie conditioner and beeswax mainly and sometimes tan kote or resolene
couple of questions 1. where did you get the leather 2. how thick (weight) is the leather 3. if you apply some neatsfoot oil to it before dying, does it get softer 4. does it get stiffer after you apply the armour all?
if I'm getting your question, you're looking for info on the stiffener inside. Tandy, SLC and others all carry a bag stiffener. It's like a waterproof cardboard and not that expensive
- 3 replies
- structured bag
- reinforced
(and 2 more)
not sure it's the right way but I got an acrylic paint pen from Elmers that I use to paint the edges. I let it dry then use a thin,wet piece of fabric on a plastic paint scraper to rub off the excess. Then I paint the actual letter
- 15 replies
can't find them on the site I ordered them from but you can get them from http://www.brubachersharness.ca Part # is 1028-34N and I paid 75cents each for them
