BDAZ
Everything posted by BDAZ
  1. Ever get annoyed when trying to make cutting lines or punching marks on finished leathers? Here's your answer. This marking pen leaves a very visible mark on the grain side of finished leathers and then easily rubs off with pressure from your finger when it is no longer needed. Try it today and make your lines easy to find. How can they get away with that! Totally deceptive advertising! Cya! Bob
  2. I have been using these and they are visible and easy to see, BUT Tandy claims the mark will just rub off. This has not been my experience on the grain side. Anyone have better luck removing the marks? Thanks! Bob
  3. Yikes! How did that happen!? I'm glad that she recovered. Thanks all for the feedback. I have never had arm or shoulder problems and I am just starting to realize the enormity life changing event that happened on Saturday. I will have to completely rethink how I do leather work, play music, .almost everything I took for granted. Luckily my left shoulder, which hit the bridge first, appears just bruised and swollen, My right shoulder is severely limited and took the brunt of the fall. BTW I had a 3 way allen key in my jersey pocket and I got stabbed with it and required 4 staples. I should have stayed in bed! I see the Ortho on Thursday and I'll know more afterwards. Thanks again for the information and kind wishes! Cya! Bob
  4. Why I left Salem!! That's my apartment and my no parking signs on the pile of snow I shoveled! Check out Mr. Dooley's Irish Pub on a Sunday. Cya! Bob
  5. I started with standard natural vegetable tan \. Cya! Bob
  6. If you are looking for a way to really darken leather in a more natural way, look up vinegaroon. I use that in combination with olive oil..sort of a salad for the leather. If you want to "age" leather, a few days in SW sun will do the trick. I had to match a mandolin strap to much older guitar strap for a customer. # days in the sun plus some neatsfoot made it look 15 years old. Cya! Bob
  7. On my machine the thread is wound COUNTER CLOCKWISE when inserted into the bobbin holder. Cya! Bob
  8. Boston is fabulous....In Summer! Winter..not so much. I spent the pas few winters in Salem...This past year I had enough. Play some of the Irish bars in Boston, the North Shore and The Vineyard. Hope to get back this summer. Good luck with your projects! Cya! Bob
  9. Try the Schmetz 18 or 19 and see if there is a difference. Make sure you are threading the machine properly. BAck off the upper tension completely and then add tension in 1/2 turn increments until the knot is centered in the material. Hope that helps Bob (Former Surrey Resident)
  10. Try RJF. I have ben very happy with his leather as are most folks. It is drum dyed veg tan or natural. Cya! Bob
  11. BDAZ
    Rune set
    I also noticed them on E-Bay when I was looking for Celtic Alphabets. Seems like they were around $100. http://www.ebay.com/itm/Craftool-Leather-Tooling-Celtic-Runic-Alphabet-stamp-set-discontinued-SCA-LARP-/321350513191?pt=LH_DefaultDomain_0&hash=item4ad1fbb227&nma=true&si=gUqkG84y0tRLL%252Bdig6K5HSAyroI%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557 Snooze, Ya Lose! Cya! Bob
  12. Most probably pot metal. Cya! Bob
  13. Thanks! I have been scheduled for sports medicine for next week. I was going to call my arm surgeon Monday (I had cubital tunnel a couple of years ago) but surgeons like to cut and if I can get an objective diagnosis that may avoid surgery, I'm up for that! Thanks again Bruce, that's just what I needed to hear! Cya! Bob
  14. Maye today but the R&R on a Rolls Royce refereed to the makes of these hand made cars many decades ago. When each died the letter went from Maroon to Black. Cya! Bob
  15. Just got back from the hospital after a head on with an iron pedestrian bridge at 20 MPH. I ht a patch of sand and it didn't end well for me or the bike. I was knocked out and I spent day in the trauma unit. To every ones amazement there were no broken bones in my 66 year old carcass. It does look like I have badly damaged my right rotator cuff and possibly my left as well., though not nearly as bad. Has anyone had rotator cuff issues and how did effect your leather work? Especially tooling and cutting. I am backed up at the moment and this is all I need! I have had to cancel all my music gigs for the foorseable future! Thanks! Bob
  16. Great idea! bob
  17. That's all you NEED to know..keep paddlin' And then there's Banjo Patterson... Bob
  18. I purchased a black double shoulder and another from a well known quality supplier, and Roger's blew then out of the water for color, depth and consistency. Cya! Bob
  19. Mine had my company name, City, Sate and USA (I sell overseas) and website. It's big enough so the web site is legible which for me is the most critical information so word of mouth can generate more sales. I usually but the mark on the back of an item so it's visible but not obtrusive. Hey ! Mercedes put's their mark in the front and no one complains! Cya! Bob
  20. It's a banjo strap.. Cya! Bob
  21. I hid a snag on a one piece strap I am making. The very end of the strap, which will be stitched into a loop is a lot spongier than I had initially thought. Must be from the neck as the strap was cut along the back. I can't reinforce the area with another piece of leather as the thickness of the leather at the loop is critical. I could possibly glue some fabric as a reinforcement and to prevent stretching or possibly use some liquid to strengthen the leather..but not sure what. Worst case I'll use cordura but I wonder if anyone has any ideas? Thanks! Bob
  22. http://www.use-enco.com/CGI/INSRIT?PMAKA=890-8803&&cm_mmc=Didit-_-SEM-_-GglProd-_-GglProd&003=18299132&010=890-8803&gclid=CO3w8PG2sb4CFYlafgodO0IASA Cya! Bob
  23. I don't get what the 2K pot in series is doing for you. unless you are using that as a fine adjustment once you have the 100K set to an approximate speed. I did a very crude test and figured on my system (remember it's also about pulley sizes) 60 SPM equates to around 60K Ohms. I like the idea of moving the pots off the motor and accessible without sticking one's hands past the belts and pulleys. For those who are analog challenged here's a chart: When I have the log pot installed I should get 50% of the knob rotation controlling the first 10 ohms, so I doubt the second pot is necessary. It would be with a linear pot. Such a simple fix for a significant issue. Cya! Bob
