Johanna
Moderator
Everything posted by Johanna
  1. Everyone who responded or PMed is added in. Holler if you have any problems. ~J
  2. Caught up. Sovran81- merged your 2 accounts. ~J
  3. All the PMs were added as soon as I saw them, and everyone here has been added too.
  4. MAINTENANCE AND TIPS FOR THE COBRA CLASS 3, 4, & KING COBRA, PRO 2000, ARTISAN TORO 3000, 3200,4000, Cowboy 3500, 4500, TECHSEW 5100, SEW PRO 44L, KINGMAX, MASTER LOCK, JUKI 441. AND OTHER 441 STYLE MACHINES Thread 1) Make sure that the thread you are using is not dry, old, or damaged by the elements. Keep thread in a plastic bag to help protect it. Make sure that the thread does not untwist, if so, then the bonding agents have evaporated or weren't very good to begin with. Threading 2l Make sure that your machine is threaded correctly. Breaking thread, skipping, fraying the thread, and tension problems will occur if your machine is threaded incorrectly. Take up lever 3) The take up lever has 2 functions: to give the thread enough slack so the hook can carry the thread around the bobbin case, and, after the hook releases the thread, allows the thread to pull up into the leather. Check spring 4) The check spring maintains tension on the thread as the take up lever returns to the top position. Needles 5) The needle must be installed correctly. Make sure that the long groove is on the left, and the scarf is on the right. Needles are tempered, so after usage, they lose their temper and become weak. A weak needle will bend or break easier after losing its temper. When the needle breaks, it could cause damage to the presser foot, needle plate, feed dog, or shuttle hook, so make sure that you change your needle every 12 hours of actual sewing. Also, make sure that you use the correct size needle for the thread and thickness of leather that you are using. lf you are using too big of a needle, then at times, the thread will travel up and down inside the hole that the needle punched resembling a tension problem. lt is all relative. The heavier the leather, the heavier the needle and thread. The lighter the leather, the lighter the needle and thread. Tensions 6) The thickness of the leather that you are sewing will dictate the amount of tension that you will need. You should loosen the tensions for lighter leather. Your tensions work in conjunction with each other, so you should loosen or tighten both tensions when adjusting them. You should never loosen or tighten more than 1 full turn at a time. lf you run into a problem with your tension and you are not sure which way to turn or you just can't seem to get your tension back where they were, then it is time to recalibrate them. This is a simple task. To re-calibrate your tensions, remove both knurled tension nuts completely, then put them both back on the machine until they just come in contact with the tension spring and stop. Sew a test piece. You will probably find that the stitch is toose, but this is what we want. You are now able to adjust your tension by tightening them both 1 turn at a time untilthe stitch pulls up. You may also experience bobbin tension problems. lf you have tightened the bobbin tension as far as you can, and stillthere is not enough tension (the bobbin thread is visible on top of the leather), you may have to clean out under the bobbin case spring. After hundreds of yards of thread pass under the bobbin case spring, microscopic fibers of thread, along with leather dust and other debris, start to collect under the bobbin case spring causing the spring to spread and give false tension. lf this is the case, then you will have to remove the spring, clean out the debris, and may have to bend the spring to put more pressure on the thread which will give you more tension and allow you to be able to adjust your bobbin tension as well. You may have to purchase a new bobbin case spring if re-shaping your existing spring does not work. Shuttle Hook 7) lt is very important that your shuttle hook is in excellent condition. lf your hook has burrs, or scratches, then you must buffthem offto make your hook smooth again so the thread will pass over the hook with ease. lf your thread is fraying, then a burr is most likely the problem. The thread will pass over the burr and then get caught, causing a couple of the strands to break. You should run your finger nail over the top, sides, under, and at the point of the hook when feeling for burrs. The shuttle hook travels in the race assembly. You should clean out the race assembly frequently. The race assembly must be clean, smooth, and oiled to assure the best sewing results. Needle Deflector 8) The needle deflector is located in the shuttle hook area. lt actually deflects the needle to protect the point of the hook. The needle will brush against the deflector moving the needle slightly to the left of the point of the hook. lt also keeps the needle straight, assuring that the loop made by the thread is consistent. Presser Feet Timing 9) Both Presser Feet should rise to the same height as they alternate walking. The procedure to assure that your presser feet are walking correctly is to turn the hand wheel towards you until the point of the needle is even with the plate or feed dog. At this time both presser feet should be down. The needle, and both presser feet should meet at the plate or feed dog at the same time. lf this is not the case, then loosen the adjusting screw and make the adjustment. The adjusting screw is located on the far right side on the back of the machine. lt is an Allen Head screw. Presser Feet Height 10)The presser feet height is determined by what you are sewing. For the most part, the height is set at medium to high. This will allow most applications to feed (whether thick or thin) without getting caught on the feet and impeding the motion of the feed system. lf you are manufacturing one item, like belts, where the thickness is constant, then you would set the height to accommodate the belts thickness. This adjustment is in the back of the machine, and is sometimes referred to as the "banana slide" adjustment. Hook Timing 11)To set the timing for the hook, first remove the needle plate and in some cases, the feed dog. This will allow you maximum vision. Set the stitch length to zero. Put a new needle in the machine. Raise the presser feet to the up position. Turn the hand wheel towards you untilthe needle is in the lowest position. Continue to turn the hand wheel untilthe needle comes up 3/16" , this measurement is critical. At this time, the point of the hook should be even with the needle and approximately 1/8" above the eye of the needle, and in the scarf of the needle as well. To adjust the shuttle hook, remove the round cover plate on the front of the machine located in the lower right hand side. After removing the cover plate, look inside the machine and you will find the black Allen Head bolt that holds the hook driving shaft. You may have to turn the hand wheel to get a better view of this bolt. Loosen the bolt and you will be able to physically turn the shuttle hook while it is in the machine. Turn the shuttle hook to the correct setting, 1/8" above the eye and then tighten the bolt. This may take more than one try. Tip: A quick way to check if your machine is out of time is to lower the needle. Just above the screw that holds the needle in place, is a hole that you can look into and see the top of the needle. Loosen the screw, then drop the needle until it covers half of the hole and try sewing. lf the machine sews properly, then you will have to advance the shuttle hook about 1/32" .lf it still does not work, the lower the needle again, until the top of the needle is even with the bottom of the hole, and then try again. lf this corrects the problem then you will have to advance the shuttle hook about 1/16". lf your machine still does not sew properly, then retime your machine based on the instructions above. These adjustments may vary depending on the machine. These instructions offered in this tutorial may not be absolute, because there are other factors that could come into play, but are a good starting point. Thank you, Steve For more info, please call: Leather Machine Co., lnc. 1-866-962-9880
  5. Caught up again. All PMs were added shortly after getting them, and all requests here and in the other thread are approved also. Fair warning- bad jokes!
  6. I think you have three hours to do your own editing. I'd probably change that to 24 hours, but last time I looked I couldn't find the setting. Once upon a time a very good leatherworker was an active member here and posted a lot of useful info and great pics. Then one member made him angry and he sat up all night deleting everything he'd ever posted, leaving big holes in the threads and conversations that were then meaningless. He felt bad about it a week later, but there was nothing that could be done. All his collected wisdom was gone from the forum. And that is why mods do the extreme editing. Thanks for understanding. ~J
  7. All caught up again. Those that PMed me were admitted within a few hours of the request, so if anyone is having problems, holler. Thanks!
  8. Everyone that Pmed me was added a few hours later. I just added the rest of you. You should see the NSFW Adult section near the Marketplace on the main page. You have to be logged in to view it. Thanks everyone!
  9. Johanna
    ACE 8892
    Very nice!
  10. Did you notice Nik Wallenda's shoes? They were custom made for him by his mother of elkskin.
    1. LNLeather
      LNLeather
      Well I had to search for that one - and learned some interesting facts and a new word... Those shoes look Might comfy. This kind of supple footwear gave him maximum protection and proprioception.
    2. tkirwan
      tkirwan
      did he survive the walk??
    3. Dwight
      Dwight
      Thanks, Johanna for the laugh, . . . sometimes my eyes don't focus right, . . . and I swore your post said elf skin, . . . and I was wondering which little elf donate skin for the project, . . .
  11. omg, just reading his emails made my eyes bleed. Cease all work for this guy, cut your losses and threaten to report him if he bothers you again. You had waaay more patience and grace than most of us would have had in those circumstances. Wow. Just wow. ~J
  12. Ironically The Leather Factory was started by disgruntled Tandy employees, and Hidecrafter was founded by Tandy's George Hurst. Springfield Leather was once a Tandy store, and Kevin was one of the top managers they ever had. He bought his store when Tandy shut down the retail outlets in the late '90s. Independent stores (like SLC, Zack White, Standing Bears etc) have to have so many dollars worth of Tandy inventory to be considered a "dealer" and get to use their logo and be included in some advertising. Tandy used to make most of their stuff- I got to tour their facility in 1997 and saw the ladies with the huge thumbs from making lace, the craftool line, the clickers and the lines where kits were assembled, the Pro-Dye lab and so forth. As store managers, we were encouraged to court prison, hospital and camp sales because you could spend all afternoon with a customer who wanted to make a holster, and that wasn't as good for sales as the institutions, even though they got wholesale pricing. Any leather store is only as good as the people that work there. When you find a supplier that works with you and gets you what you need, stick with them and shout their praises from the rooftops to keep them in business. ~J
  13. Sign in a leather shop: "I can make anything with enough of my time and enough of your money!"
    1. Show previous comments  3 more
    2. chancey77
      chancey77
      CLASSIC! Also here sometimes at 8-18 but maybe not on monday tuesday wednesday thursday or friday...maybe you should call and make an appointment:)
    3. Genyfer Belle
    4. bizbeblu
      bizbeblu
      From an old mechanic: "You can put a rocket engine in a submarine if you have enough time and money."
  14. Caught up again. I did all the PM requests as soon as I got them. ~J
  15. Because this one forum is open to unregistered members (guests) and the restriction is necessary because of spam.
  16. It's really important to have things in writing, but I don't think you need to lose sleep over this clown. If he takes you to small claims court he's going to sound ridiculous. You were smart to box it up and send it back- some customers and jobs are not worth keeping.
  17. We do the adult area so that no one sees adult items unless they've asked to be included in that section. We keep the main board "family friendly" because we want to encourage parents and teachers to use this site for leatherwork education and resources. I'm caught up again on PMs and requests here. Welcome to the dark side!
  18. Gotcha all in there. The jokes are terrible, but the coffee is fresh.
  19. Caught up again here and with PMs. Let me know if anyone else wants in!
  20. All caught up with requests here and PMs. Let me know if you aren't seeing the NSFW area at the bottom of the main forum page. ~J
  21. I got you a few days ago, Wink. Look by the Marketplace area on the main board. Holler if you have any problems.
  22. Added you and the other 7 members that PMed me. Have fun!
  23. Added you too olds cool.
