billybopp
Everything posted by billybopp
  1. I do know. Springfield leather has python and several other skins... Both print and "real". And you are still first rate dick. You COULD have approached people's confusion by saying something like. "I could have been more clear with my question" . But you did not. Instead you decided to insult anybody that asked. Your disdain for video or anybody (other than Hank) who tries to make one.... Or for that matter anybody that looks at one is very well known by anybody that has been here for any length of time. So you decided to express that,once again, and use that as an insult. I have seen you repeatedly shut down anybody else's opinion, whether right or not because it does not fit within your incredibly narrow mindset. Not cool. If anybody else finds my language or opinion here insulting, I apologize to you but I had to speak my mind. It has been brewing for a while now. If any mod feels my commentary inappropriate, feel free to remove it. JLS. You are a dick.
  2. You're SUCH a DICK.
  3. Well darn. I'm 1500 miles too far away to drop by. Especially if you throw in a few pounds of steaks and burgers with that hide!
  4. This is not really closer, but a different angle. If I remember right, the 'keeper loops' are 3/8" and loop through holes in the front of the bag, sewn in at the center. The straps are 1" wide and the tabs are cut from the ends of the straps and sewn on about half-way around. Straps didn't really need to go all the way around, but I liked the look. The gussets are 3/8" purple-heart wood (if I had known how hard that stuff was I would've chosen something else! They were really hard to shape with hand tools only!). - Bill
  5. This is just held by friction, and is working well after a couple of years use. - Bill
  6. If you're making your pattern on paper, just mark a line where you want our stitches to run before fully marking out the pockets then press your stitching chisel or pricking iron along the line. It's then pretty easy to see just where you can mark out your pockets. If it's somebody else's design, you can do the same and just adjust the size. - Bill
  7. I'd stock up enough to keep going until I left CA. - Bill
  8. Probably the best way to avoid that odd stitch length going over a card-slot tab is to cheat a little in the design stage! Make the card slot tabs a little bigger, or smaller, so that your chisels straddle the edge top and bottom. In most cases it will be a very small adjustment, but will get your stitch length spot-on. You can do the same for the over all size as well. Pre-planning makes assembly easy-peasy. Or at least easier-peasier. - Bill
  9. Leather does tend to wrinkle when you bend it in two directions as in a U shaped gusset. Some leathers are more cooperative than others. Skiving can help, but if the curve is tight a relief cut (V-shaped cut) is a very effective method. Without some special measures, the stitch length will change in the curve. If you maintain the stitch length on the outside the inside will become shorter, or if you maintain the inside length will become longer. Most choose a shorter inside stitch, and for some projects that's perfectly acceptable. There is a workaround that allows both inside and outside to stay the same, but it takes a little work and a little thinking. You'll mark a consistent stitch length on both outside piece and on the side panel. They'll match up as normal on the straight part, but when you come to the curve there will be more holes on the outside than the inside. You'll use a few double stitches on the inside to make up the difference. Use an awl to make your holes at an angle and hit your inside marks when they get out of line - first making your angle a little forward and then a little backward to make a double-stitch when things get too far out of line. I can't think of a better way to describe it - but that's what you do! - Bill
  10. You may want to check out stitching chisel reviews by @Dangerous Beans (Nigel Armitage)'s youtube channel. There is a LOT of good information there and a LOT of chisel reviews. https://www.youtube.com/channel/UC8urn9l3pybW5LztUa6zbOA -Bill
  11. By golly THAT'S customer service! LOL
  12. Yes they did! Amongst other changes. - Bill
  13. In certain circles, this Santa already has a bad reputation. In a good way, of course. Love the video!! Oh, I certainly agree about the luxury market and whole-heartedly support it. But there's luxury, and then there's excess, followed at some distance by extreme excess. I'm pretty sure that a bag that expensive ventures into extreme excess. - Bill
  14. 90% isopropyl works fine for me. The amount to dilute depends on the end-color you are looking for, so kind of impossible to say just how much. I'd start with 50/50 and go from there trying out on scraps of the same leather you will be dying. - Bill
  15. Once you find your own personal style of tooling - or even if you like tooling, it can be worth upgrading tools. The nice thing about having a collection of lesser tools, too, is that the ones that don't fit your style STILL get occasional use, and you'll have them for those rare times! As for swivel knives, as long as the body fits your hand and operates smoothly, they're pretty much all fine. The blade is the part that makes a difference, and as long as that gets sharp and doesn't need excessive sharpening that's good to go too. -Bill
  16. Tandy tools went from being good to bottom of the barrel for many years. Now, in the face of some of the crap coming at us out of China, they're not looking so bad again, particularly for the price. Tandy's pro line are good for the price. Many of the regular Tandy craftools are perfectly serviceable and great to learn with. Some are fine to continue with! The quality of some tools is more critical than others. For example basketweave and geometric tools need to be aligned just right, so better quality tools are a must for those. others need to make very crisp impressions, so quality is more important there. Bevelers, and some others aren't so critical and less expensive tools work well from the get-go. Additionally, the tools you choose will depend on your personal tooling style. But you can't really know YOUR style until you've done some work. My suggestion is to start with inexpensive tools until you know which ones you use all the time, and then slowly replace those with better. The exception being those above geometrics, etc. where inexpensive tools will just lead to frustration. - Bill
  17. Well.... The dye will wear off with time. Fingernail beds and cuticles are difficult, but about the best dye remover that I've found is Dye-Gone II if you can find it. - Bill
  18. They can be used heated or cool. Usually cool works fine, but some leathers are a little more stubborn than others and require some heat. Here is a picture of some of my single and double creasers along with a strap example of how they're used. Most are CS Osborne, one unbranded, I also have some Gomph and others. -Bill
  19. That is an edge creaser. I have several of them in various sizes, and love 'em! It is used to place a decorative line a certain distance in from the edge of a piece of leather, mostly straps and such. The longer leg runs along the edge, and the shorter one makes the crease. It's a neat, attractive look. That said, tho, you don't necessarily have to use it for what it was meant. If the round fits over your edge, it may well do what you want! -Bill
  20. Not sure what you have there, but tokonole is nothing like the tragacanth that I have used. The gum tragacanth that I have used works OK for a little while, but eventually the edges wear and fibers come loose. That does not happen for me when I use tokonole, it makes a nice tight gloss edge that stays that way. - Bill
  21. I'm rather fond of Tokonole for burnished edges. It leaves a nice very slick durable edge. - Bill
  22. I have no idea of when it might have been made, but I love the horse legs! -Bill
  23. I agree that's the result of mass communication. Here in the US, regional accents are still there, but they're MUCH toned down from what they used to be. There was a time when some regions accents were darn near unintelligible to others, and I remember meeting older folks when I was a kid that I used to have to ask them to repeat a couple of times to make out what they were saying. Not so much now, tho. - Bill
  24. Try LeatherWranglers ... https://leatherwranglers.com/shop?olsPage=products%2Fsplitterblade-osborne86&page=3 - Bill
