Everything posted by Uwe
A photo of what you're looking at (especially the name/model plate) would really help us gather information about the machine.
- 14 replies
- sewing machine
- sewing
(and 2 more)
The big C-shaped distance rings in the video are used to adjust hook-to-needle distance. The number of shims required for proper hook-to-needle distance will vary from machine to machine. Your machine may be fine as it is. You may need to add some shims to get the hook-to-needle-distance just right. In hook timing position (needle has risen 4mm from bottom) "the hook should be as close as possible without touching the needle." The distance rings are available from Weaver. You probably only have to do this adjustment once, because it's very unlikely to go out of whack with normal use. The little spacer shims with the numbers on them are used to adjust needle guard position relative to the needle. The number on the shim corresponds to the needle size in NM (Number Metric). You'll need a full set of these little spacers (also available from Weaver) if you plan to switch needle sizes. The needle guard actually IS supposed to touch the needle without pushing it out of the way. If the needle guard is not touching the needle, it's not protecting the hook. If it's pushing the needle too far away from the hook, it will cause skipped stitches. If you're off by just one size, it's probably not a super big deal or problem. The Adler 205-370 uses needles up to Singer size 28. Here's how to match up the sizes (based on Singer info): Singer size = Number Metric Singer 23 = 160 NM Singer 24 = 180 NM Singer 25 = 200 NM Singer 26 = 230 NM Singer 27 = 250 NM Singer 28 = 280 NM I do plan on making an Adler 205 use and service video over the next month or two, once I get comfortable making the adjustments myself.
You should not be afraid to adjust presser foot force. It's an easy one, helps minimize marks on veg tan leather, and you can't do much wrong. The presser foot needs to have enough downward pressure to hold the material in place and keep the material from lifting up with the needle as it ascends. If the material lifts up, the thread doesn't form a loop for the hook to catch and skips a stitch. There's nothing to go terribly wrong here. The only real potential issue with that adjustment is if you loosen that screw way too much so it comes out of the threaded hole and the spring sends it flying across the room. Give it one turn at a time and hold on to it.
The "safe" thing to say is "Don't turn the wheel backwards," because it may cause stitch problems and can indeed break something in certain situations. It really varies by machine. In general, sewing machines are designed to spin only in one direction to do actual work. I think it's okay on most machines to turn the wheel backward to adjust needle position a little while it's above the material. It depends on where you are in the stitch cycle. Don't turn the wheel backwards to bring the needle up from the bottom position. If you turn the wheel backwards while the needle is down, you may cause it to skip a stitch because the thread loop formation for the hook to catch is tricky enough as it is going forward. Also, don't turn it backwards more than a quarter turn, and certainly don't try to "undo" a stitch you already made by turning the wheel backwards because that's just not how it works. If there's no thread or material in the machine, some machines will spin happily in either direction, others, not so much. It really depends on the machine and how it's designed. Some parts (e.g. needle guard vs needle) may slide past each other on one direction, but catch in the other direction. So it depends on how your machine is adjusted, too. If there's thread in the machine, you can cause trouble by thread catching on something and binding things up, then if you push too hard some fragile part might break or go out of alignment. If you feel any resistance at all, stop.
If your machine doesn't want to get started, it's likely because it's geared for speed and doesn't have enough torque at low speeds. What's under the table? Ideally you'd have a servo motor with a small pulley and a speed reducer. Worst case is a clutch motor with a big pulley.
The shims are available from Weaver for $12/ea. Adding reverse to 205 machine that doesn't already have it does not seem like a financially feasible undertaking in my mind. You'd be better off selling your MO and buying a 205-370 instead. Compare the Parts list for Durkopp Adler 205-MO version to the more common Durkopp Adler 205-370 model to see which parts have the same part number and are thus interchangeable. It does not look like the presser feet are interchangeable with other 205 models, for example. The MO model is kind of a one-trick pony (i.e. mocassins), whereas the 205-370 is a more versatile, general purpose type of machine.
- 2 replies
- adler
- needle shims
(and 2 more)
The presser feet in the belt video have special ridges at the bottom that help press the thread into the leather. The harness feet are skinny and have a very small footprint - they're more likely to leave marks, just like high-heeled shoes on a wood floor. Other feet styles with bigger flat/smooth bottoms are available and yes, you can adjust the foot pressure (see manual for details) to dial in the least amount of pressure that still holds your material securely in place. There'll be a fair amount of trial and error involved to find settings and accessories that work for your specific application.
cjsamples: Bummer about the file incompatibility. You could try downloading a trial version of V-Carve Pro to at least open the file and look at it and perhaps export to different format, but I'm not sure how limited the trial version is. I could send you the ShopBot code text file, but it's not really editable. I created the file in V-Carve Pro, so I don't really have another CAD version. Perhaps I can export to some standard AutoCad style DXF file, but I doubt it would not have the pathing info, which is important. DrmCa: Yes, I do have access to very cool and wickedly expensive tools, but only if I pay my $150/month membership fee at TechShop (which I can afford only once every couple of months, unless people actually start buying stuff I make there, haha).
- 181 replies
- diy sewing table
- industrial sewing table
(and 3 more)
You can download PDF versions of the Durkopp Adler 205-370 Owner Manual and the Durkopp Adler 205-370 Service Manual from my website. I haven't seen the Weaver DVD, but heard comments that it doesn't go into great depth. Reading the manuals will get you started on the right path. I've used size 415 bonded polyester thread without any trouble using size 27 needles. I made a little sewing demo video using this combination some time ago: I took the bobbin area apart for a different video on changing out the presser foot: This machine uses little spacers for different needle sizes to adjust hook-to-needle spacing. Make sure you use the right combination to get good results (e.g. use the "250" spacer for the 250Nm/27 size needle). The spacers are available from Weaver and other retailers here at LW or online. $500 is a total bargain for that machine if it is serviceable. I have a few presser feet and accessories for the machine in my ebay store and I'm finalizing work on a flatbed table attachment, just in case you're looking to spend all that money you saved with your initial purchase.
thesergeant: Those are beautiful tables! Love the veneered table to make use of the leftover pieces - you have some serious shop skills and a great eye for design and color! Now I'm all motivated to give my own Pfaff 130 a nice, permanent home like that rather than being hidden away in a cabinet. Nice photography, too. cjsamples: I've uploaded the V-Carve Pro file for my Consew 225 table top here: http://uwe.net/CAD/Consew225_v2.crv You'll have to tweak it to fit your hinge design and corner pads. You'll also have to separate out the top and bottom cutting paths for two shopbot runs.
- 181 replies
- diy sewing table
(and 3 more)
Great little winder setup! Very inventive and great use of existing parts and materials. I especially appreciate little details like the paint can cap protective cover and the little tool holder. The skull-and-bones cover for the hole is a nice, touch, too :-) Well done!
Thanks for the additional pictures and manual graphics. Amazing how many different models of that class of machines exist that are 90% identical! I was able to make my Consew 225 sew 9mm of veg tan leather after I adjusted hook timing and needle guard. I did not go into presser foot timing since mine seemed fine. I documented my little adventure in three videos:Hook Timing, Needle Guard, Sewing Demo: For some reason it won't embed this third video of the sewing demo: The adjustment details for your machine may vary by a fraction of a millimeter here and there. Use the numbers from your service manual if you have it (if you do, please post a PDF here - we're always looking or manuals it seems!). Otherwise, the Consew 225 number are a great starting point.
Yes, in general the inner presser foot is supposed to get to the material before the needle enters and let go of the material only after after the needle exits. Your machine may be able to sew reliably with those materials, but it will need to be timed/adjusted very well. Breaking needles means something is off, and it may be more than just the inner presser foot timing. I'm not really familiar with the 239 model and online documentation is very limited. The walking foot mechanism looks a lot like the Singer 111 and Consew 225 class of machines. Chances are good that the inner (vibrating) presser foot timing adjustments works the same. Look at the "Timing of the vibrating presser foot" section on page 8 of the Consew 225 manual and see if your mechanism on the back looks/works the same. You say the rest of the timing is great. Do you know it's great or do you just assume it's okay because it makes a nice stitch when it's not breaking needles? If you need to sew at the limits of what the machine is capable of, timing and adjustments really do have to be "perfect", not just "good enough to make a stitch." Post some pictures of the back and underside (hook area) of the machine when you get a chance. It'll help figure out what's going on.
Contemplating A Puritan Stitcher: Vamping, Staying, Fairstitch ?
Uwe replied to Uwe's topic in Leather Sewing Machines
So while I'm waiting to get my hands on some needles and awls I decided to make a new throat plate for my Puritan. The original showed a fair amount of battle scars and the little blade inserts needed to be replaced. It turns out the WaterJet at my TechShop can do incredibly detailed work with great precision on its huge 6'x10' work table, cutting the three 0.07" wide slots quite nicely. The new throat plate made from 304 stainless steel should last a while. I'm also guessing that the cost of the replacement inserts of the original is higher than my entire throat plate. I'll find out this week when they get back to me a with a quote for several Puritan parts. -
Quick Question For Anyone With A Singer 95 Or 96 Class
Uwe replied to Marcusstratus's topic in Leather Sewing Machines
Good point Tom. The marked gears have just been pre-worn at the factory (e.g. run them for a while with some polishing compound). It's probably a good idea to always mark gear mesh positions before separating any two gears, so you can put them back exactly as they were before you separated them. -
Many gears on sewing machines (and other machinery) are machined to mesh with specific opposing gear teeth. There's often a factory marking on the gears that tells you which tooth on one gear is supposed to match up with wich valley on the other gear. If you assemble the gears with an offset in the tooth alignment, the gears will probably still work, but they'll be noisy. I noticed that issue when I was timing my Adler 67. I made a mention of it and show the gear markings around the 4-minute mark in my hook timing video: Your gears may also be machined to mesh with specific opposing teeth. Look for markings (often just an ink dot or pencil marking that may look random at first). If the mark disappeared during restoration, you can try shifting the gears one tooth at a time and see if the noise gets better. The noise was very obvious with my Adler 67 when I accidentally got the gears mis-meshed. -
All three machines you are looking are good designs, but not identical. If they work well and you can afford it you can't really make a wrong decision with any of these. The two 269 machines have a very different cylinder arm design from the 69. The 69 has a horizontal hook, smaller bobbin, small arm (good for getting into tight corners inside a bag), feed dog goes back and forth but not up and down, and it can be set up for special synchronized binding operations. The 269 has a vertical hook, larger bobbin, descending feed dog for full compound feed, but the arm diameter is considerably larger and it is not as versatile for binding operations. Which design is better suited to your needs depends on which features are important to you. I have a Durkopp Adler 69-373 and it is a very nice machine for my needs, but I like the 269 design as well. I made a flatbed table attachment for my DA 69 to sew flat pieces.
What Affordable Sewing Machine For 9/10 Oz Leather
Uwe replied to Exzette's topic in Leather Sewing Machines
In terms of actual machine suggestions that can sew that kind of leather and fall in that general price range, the only recommendation that comes to mind are the Singer 111W155 and Consew 225/226 class of machines. These machines are frequently available used in various degrees of use/abuse. They are actually capable of sewing fairly thick leather if they are set up properly. I did a little video some time ago sewing thick veg tan leather on my Consew 225 after adjusting it as good as I know how: Here's the video on how I adjusted it, to give you an idea of what you have to do (or pay somebody to do): -
If you find a machine for under $500 that sews two or more layers of 10oz veg tan leather well, you are very lucky indeed. Many sellers will claim their machine will sew anything perfectly, especially if they've never used it themselves. Make sure you see machine actually sewing what the seller they claims it will sew, before you buy it. -
Without seeing any pictures, I'm guessing the two machines are nearly identical (except color perhaps and which country they were made in). Durkopp and Adler became one company ("Durkopp Adler") in the 1987. Machines built around that time may have only had a change in name and perhaps paint color. Later, some production was moved to the Czech Republic and later yet, to China for certain models. The Adler 269-373 is a fine machine if it is in good condition. All other things being equal, there's really no reason to pay twice as much for a machine just because it was built after the two companies merged. Older may be better, actually. If the Adler 269-373 says "Made in Germany" it is more desirable than a newer DURKOPP ADLER made in the Czech Republic ("Made in Czech Republic") or China (no "Made in . . ." statement at all on the machine), not only because build quality MAY be better but because resale value WILL be better. GOOGLE TRANSLATE VERSION: Sin ver ninguna imagen , supongo las dos máquinas son casi idénticos (excepto el color tal vez y en qué país se hicieron in). Durkopp y Adler se convirtió en una empresa ( " Durkopp Adler " ) a finales de 1987 . Máquinas construidas alrededor de ese tiempo pueden sólo han tenido un cambio de nombre y tal vez la pintura de color. Más tarde, parte de la producción se trasladó a la República Checa y, más tarde , sin embargo, a China para ciertos modelos. El Adler 269 a 373 es una máquina bien si está en buenas condiciones . Todas las demás cosas son iguales , no hay realmente ninguna razón para pagar el doble por una máquina sólo porque fue construido después de las dos empresas se fusionaron . Mayor puede ser mejor , en realidad. Si el Adler 269-373 dice " Hecho en Alemania " es más deseable que una DURKOPP ADLER más reciente realizada en la República Checa ( "Hecho en República Checa " ) o China (sin "Hecho en . . . " La declaración en absoluto en la máquina ) , no sólo por la calidad de construcción puede ser mejor , sino porque el valor de reventa será mejor.
It looks very much like a copy of the Juki DU-1181N, which runs about $1,300 new with a table and servo motor (plus shipping which can be substantial). This machine does not have needle feed, but bottom and upper feed may be all you need. The central pump lubricating system can be troublesome if you sew really slow all the time - the pump needs to run at a certain speed to keep oil moving. But for $425 it looks like a perfectly good starter machine in very clean condition. Manuals and parts like different presser feet should be readily available from Juki part bins, but they may be harder to find in aftermarket sources - the feet seem less common than other models. The nice solid wood table (not a particle board weakling) and decent servo motor alone are worth $200 in my mind. Go try it out and see if you like it and if it works with material you're planning to sew. If it's okay, go for it. Decent new-ish industrial walking foot sewing machines don't get any cheaper than that, really.
Flatbed Table Attachment For Adler 69 Machines
Here are a couple more detail shots of my flatbed table attachment for the Dürkopp Adler 69 class of machines, for the LW archives. -
Thanks for offering to check your stash, pcox. My Puritan's needle/awl shank size is 0.086". The one awl I have is 1-7/16" long. I measured how deep the needle and awl are seated inside their holders, and the closest distance between top and bottom holder during the cycle. Per the manual, there should be a gap of 1/16" between awl and needle at this timing point. I calculated how long the needle should be based on this info. So, if I did my calculations right, the needle should be close to 1.97" long and have a 0.086" shank. Any "size" will be fine for testing, I eventually plan to sew with about 207 size thread. Here's a little scale drawing I made to help me figure this out: I do really like the concept of needle/awl machines, so I'm gonna try hard to make this one work. Less sure about the chain stitch yet, I tend to lean towards lockstitch machines. -
"This one's different" is my take so far on the Puritan- and I'm sure people still say that about me sometimes, too. Very few things work the way I expect them to. The handwheel turn away from you, this being a first for me. The chain stitch and needle/awl thing takes a little while to digest. I still haven't figured out how you actually start sewing a stitch with thing (not I have any needles, mind you.) None of the youtube video show this, actually - they're already in the middle of everything. The manual also does not give even a hint. I'm guessing people "just know" or at least used to know these things. Right now I'm leaning towards bringing the needles up and then manually wrapping each thread into the needle hooks and holding on to the thread while I turn to pull down the needles. I'm still not totally sure which exact model I actually have. I think there's some fluidity since you can change things over from one model to another in the field. Mine appears be "transitioning" - it's mostly a "Three-Row Vamper BX 3/32", with a few mismatched parts. The BX 3/32 should have three stitch rows spaced 3/32" apart (pitch) with small shank needles (.086" shank). There are five elements that need to have matching pitch: 1. The needle holder below the needle plate 2. Needle brace/castoff holder 3. The needle plate 4. The presser foot 5. The awl holder at the top They all need to be synchronized with the same pitch of either ALL 3/32", or ALL 1/8" spacing between the three stitching rows. Mine has everything 3/32" pitch, except the needle holder which has a pitch of 1/8". This combination will never sew three rows of stitching, but it'll sew a single center row of stitching just fine, apparently, which is how the machine has been used for a while. I tried to order some needles and awls today and called Puritan (how much could they possibly be, right?) Nice fella answered and he had a few questions that had me take the digital caliper to the machine afterwards. So it turns out that needles are $8.25 EACH and awls are $8.60 EACH, with a minimum purchase of ten needles/awls. So I'll be out around $170 just to get a single pair of needle and awl into this machine (center row) just to see if it will make a stitch. I'll have to get a new needle holder with the right pitch to attempt triple-row stitches. I'm almost afraid to ask how much a needle holder is. Like I said, this one's different. Does anybody by chance know if these needles and awls are unique to Puritan, or if I can substitute other needle/awl brands (e.g. Campbell Randall)? If this post seems to lack organization and direction, that's because I have none when it comes to this machine. I don't even know what my next step should be right now. I'm gonna let it simmer for a few days before tackle it again. I also need to sell a couple swing-down guides and presser feet on ebay so I can afford to buy needles and awls, haha! -
Here's a quick sneak peek at my Adler 69 version of the flatbed table attachment. Proper glamour shots to follow later this week.
