Everything posted by dikman
How to remove rusted seized needle plate screws?
dikman replied to Kryptonite's topic in Leather Sewing Machines
The other one that a lot of people swear by is 50:50 Auto Trans Fluid and Acetone. -
Seiko STW-8B - question on servo with needle positioner
dikman replied to katit's topic in Leather Sewing Machines
If you look at a consew 206 manual you may be able to relate some of the adjustments to yours. -
You didn't mention before that you may have been considering a CB3200. If you had then you would have been advised to buy that in preference to the others, as the only thing they all have in common is that they're industrial sewing machines! The 3200 should be a good fit for what your wife wants to make.
- 10 replies
- mercury m120
- singer 211g
(and 1 more)
Hmm, "ultimate for leather"? I'd be wary of anything that salesman might say. No, can't be converted to a walking foot. Don't get me wrong, it can probably sew leather ok, within it's limitations, but I think for your wife you'd ideally be looking at a walking foot. That Singer should be good for 3/8" under the feet, I'd guess that the Adler is the same. The Adler looks like it's been resprayed.
- 10 replies
- mercury m120
- singer 211g
(and 1 more)
Fraying thread - it looks to me like something is catching one of the strands, check the feed dog, hook etc for burrs or rough spots. The takeup spring may not be set correctly, allowing slack thread which the hook can catch or the needle may pierce. It's the most likely culprit to me. -
Knife sheaths could be a struggle with those machines. As for the Viking gear, just how thick is it? The Singer doesn't have reverse but will have the advantage that parts and feet will be cheaper and possibly more readily available. The United isn't a walking foot. Adler I'll leave for others with more knowledge of their capabilities. You will probably need to factor in a servo, however, regardless of what you buy.
- 10 replies
- mercury m120
- singer 211g
(and 1 more)
Holster Patterns 'n' MORE stuff
dikman replied to JLSleather's topic in Gun Holsters, Rifle Slings and Knife Sheathes
The sound quality on that video of Sam's is poor (very bassy). -
The steel frame looks pretty reasonable, whether you re-paint it depends on how pretty you want it to look. Ditch the table top if it's warped, either make a new one (lots of posts about doing that), buy one or keep looking for a used one going cheap that you can adapt. The chain/pedal is used instead of a knee lift, but it looks like the bars and pivots to connect it are missing from the rear of the machine. I have an STH-8BLD, a slightly different model but I suspect some of the adjustments for timing could be the same (and the missing lift pieces). You should be able to find that manual (mine is 2.7mb, so too big to upload). I believe the machine may be similar to a Consew 206, the manual for those is readily available, and also the manuals for the Singer 111 series (111W153, for instance) may also be useful to understand setting the needle. -
Seiko's are nice machines and judging by those photos $200 is a very good price. It shouldn't be too hard to find a manual for it. Looks like it probably just needs a good cleaning, oiling and adjusting. As for the epoxy, my guess is either the safety clutch had a problem or someone decided to stop it working by gluing it up solid! -
Now I can see what you mean. That stand looks really nice, it would be a shame not to use it (I don't know how easy it would be to find a genuine Adler stand). If it will work with an adapter plate then I reckon you should give it a try.
If you're going to slow the machine right down then to a large extent that negates the need for a positioner as you can control the needle position fairly easily. You should be able to set any needle positioner for either stopping up or down, usually the controls will be "buried" in the menu system of the servo, so not just a matter of pushing one button. Some servos may allow you to set the pedal so that if you heel down on the pedal the needle will rise if the default is stopping needle down. Also, be aware that some needle positioners may not work if a pulley reducing system is also used. -
Mexican loop holster... And belt
dikman replied to Stetson912's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I reckon he'll love it! I'll bet all his friends will want one too.- 23 replies
- mexican loop
- belt
(and 1 more)
Welcome Steve. Photos are always nice, then people can see what you're referring to with the stand.
To set the stitch length lift up the lever to the setting you want then loosen the screw on the left and slide it up until the metal behind the screw touches the lever (you'll know what I mean when you try it) then tighten the screw. Now if you lift the lever all the way up for reverse it will return to your preset stitch length.
Most interesting. No measurements, he just eye-balled everything. That leather sounded pretty hard when he was bevelling the edges!!
- 14 replies
- union lockstitch
- sew leather
(and 1 more)
Doesn't really matter what is used as the clutch is obviously not disengaging completely.
Can you identify this Pfaff walking foot?
dikman replied to MrBurns's topic in Leather Sewing Machines
That label on the switch might just be referring to its maximum switching capacity. -
Has the brake got enough tension on it and is the clutch completely disengaging when you take your foot off the pedal?
What should I look out for when buying a Durkopp 291?
Quite a bit of machinery there! I'm also curious what the more knowledgeable folk on here will advise. Me, I would only have it if someone gave it to me as if something went wrong with it I reckon it could be an expensive nightmare to fix. And if that was the only machine you had and were relying on it...... -
" Try sewing a while with only one hand to guide the work and you'll realise why very few industrial machines were intended to be powered by hand" . When I got my 117 working it seemed like a great idea to fit a handle to the large pulley I fitted, so no motor needed. It didn't take me long to realise that unless I could grow a third hand it wasn't very practical.
Chris, it's all good fun...... Brian, maybe you could start a "new" career designing 3D files for those of us who are mentally challenged.
I'm not. Unfortunately 3D printing requires a fair bit of effort to sort out, as you're finding out. I suspect that for most it's either too daunting a prospect or they don't have the time. Brian, sorry to hear you've been on the sick list, hope you're on the mend.
Very nice, Peter, I like it! I shall file that idea away for future use.
Mexican Loop Holster
dikman replied to Forester's topic in Gun Holsters, Rifle Slings and Knife Sheathes
That's a bit different. I like the "floral" design on the front, a very clever use of stamps. What colour is the dye? -
Machine Choice Heavier Than A Juki 1541S
dikman replied to stickandtin's topic in Leather Sewing Machines
There's no hope for you now..........
